    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 12-09-2015, 12:29 PM   #871
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by HotRod127 View Post
don't have facebook, but i guess i can see what i can do
I was pretty happy with how mine came out.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 12-09-2015, 12:32 PM   #872
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
What motor is that?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 12-09-2015, 12:34 PM   #873
Super Moderator
Originally Posted by Wildcat1971 View Post
What motor is that?
Hobbywing
Old 12-09-2015, 12:35 PM   #874
Originally Posted by Matt Trimmings View Post
Hobbywing
cool. The new G2? or just a v10
Old 12-09-2015, 12:36 PM   #875
Super Moderator
"just" a V10. I like it so far...you know how much I race.
Old 12-09-2015, 12:41 PM   #876
Cool. Let me know when you are selling me your 22 3.0
Old 12-09-2015, 01:00 PM   #877
Super Moderator
Old 12-09-2015, 02:40 PM   #878
HotRod127's Avatar
Trader Rating: 14 (100%+)
Thanks alot Matt, that looks really good and clean
Kyosho RB6.6/ Kyosho ZX6.6/ Kyosho RT6/ Kyosho America- Peak Racing Products- Team Orion- AKA
HotRod127 is offline   Reply With Quote
Old 12-09-2015, 02:58 PM   #879
I plan to run 17.5 or 13.5 blinky, and the manual suggests a 70T spur. But it seems TLR does not make a 70T spur for the HDS slipper. What parts do I need to use the 70T spur? Thanks
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 12-09-2015, 03:01 PM   #880
Super Moderator
2 of these: http://www.amainhobbies.com/rc-cars-...osa3123/p15125
1 of these: http://www.amainhobbies.com/rc-cars-...63883?v=216080
The 70t spur is too small to be mated properly with the HDS pads.
Old 12-09-2015, 03:06 PM   #881
RedBMaster's Avatar
Originally Posted by Davidka View Post
More info:
What surface do you race on?
What is the rest of the setup (shock positions, camber links, etc.)?
Do you have any drag-brake in your ESC settings?
I ask the last question because if you're lowering the front that much, I question if you're getting a normal amount of weight transfer from to rear when you turn in.
Running high traction indoor clay with AKA clay slicks.
Kit setup, but changed to 32.5 rear oil.
Yes, but I always run minimal drag brake to keep up my corner speed. Adjusting this isn't in my interest tho. I use push brake where I need and the same drag break setup worked great in my 2.5 (Exotek CF chassis).
Now that Maifield's setup had been posted, I'll prolly start there.
RedBMaster is offline   Reply With Quote
Old 12-09-2015, 03:22 PM   #882
vito's Avatar
this i my 3rd losi 22 had a 2.0 and 1.0 kit love this car the build up was spot on
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 12-09-2015, 05:26 PM   #883
shadowracer24's Avatar
1.5mm is what I used
That's what I thought would fit but seems to small in my pins. Use mip tips so know they are good. Huh! Oh well no big deal just kinda weird.
shadowracer24 is offline   Reply With Quote
Old 12-09-2015, 05:36 PM   #884
Davidka's Avatar
Trader Rating: 75 (100%+)
If you're willing to go off the reservation, you can go this way too:
1 of these: http://www.amainhobbies.com/rc-cars-...62753?v=166400
1 of these: http://www.amainhobbies.com/rc-cars-...asc9603/p16646
Old 12-09-2015, 06:00 PM   #885
It's the cheaper route, but I think I will be crucified for that second part
TLR 22 3.0
Apex RC Proshop
