    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 12-09-2015, 07:16 AM   #856
Davidka's Avatar
Trader Rating: 75 (100%+)
Originally Posted by RedBMaster View Post
I've been running my front ride height super low to generate enough steering to the point where I've bottomed out the shock collars. I've also dropped my ride height to help mitigate traction rolling.
I plan to put 2mm shock limiters all around to combat traction rolling, but I'd like to hear what others have done to add steering from the stock setup.
More info:
What surface do you race on?
What is the rest of the setup (shock positions, camber links, etc.)?
Do you have any drag-brake in your ESC settings?
I ask the last question because if you're lowering the front that much, I question if you're getting a normal amount of weight transfer from to rear when you turn in.
Old 12-09-2015, 07:31 AM   #857
HotRod127's Avatar
Trader Rating: 14 (100%+)
i saw Maifields setup on the site just now, I'm an idiot, I know I prolly should've looked before I asked.
Kyosho RB6.6/ Kyosho ZX6.6/ Kyosho RT6/ Kyosho America- Peak Racing Products- Team Orion- AKA
HotRod127 is offline   Reply With Quote
Old 12-09-2015, 08:19 AM   #858
tipperjackson's Avatar
Trader Rating: 16 (100%+)
Here is the link to Maifields set-up if you don't want to go looking for it.
http://www.tlracing.com/ProdInfo/Fil...yPlex_2015.pdf
Slower is Faster!....Don't forget to have fun, your racing Toy Cars.........!
Losi 3.0 E Truggy~Losi 3.0 E Buggy~Losi 3.0 Buggy~Losi 22-4~Losi 22 2.0~Losi 22 1.0
tipperjackson is offline   Reply With Quote
Old 12-09-2015, 08:26 AM   #859
skrichter's Avatar
Send a message via AIM to skrichter
Interesting he is running a brass kick and aluminum front camber block
Thanks for getting this up quickly Frank!
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 12-09-2015, 08:32 AM   #860
shadowracer24's Avatar
My build went together great yesterday with no issues except for one. The new hinge pin that goes into the caster block, what the heck tool size fits in that thing. Have a box full of tools and not one fit it. Lol. Anyone know what size tip that is?
shadowracer24 is offline   Reply With Quote
Old 12-09-2015, 08:33 AM   #861
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
1.5mm is what I used
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 12-09-2015, 09:17 AM   #862
Jpdanger's Avatar
His setup sheet lists Kyosho springs, but the Redrc.net Chassis Focus pictures show him using red and yellow springs.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 12-09-2015, 09:48 AM   #863
Trader Rating: 309 (100%+)
The front wing evolution has began.
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 12-09-2015, 09:54 AM   #864
On the setup sheet, what is the difference between spindle ball stud (standard/low mount)? Is that when you mount the ball from the bottom side? Then add 2mm? I also have the same question for akerman low mount.
greener74 is offline   Reply With Quote
Old 12-09-2015, 10:03 AM   #865
Super Moderator
Standard: http://www.amainhobbies.com/rc-cars-...lr6025/p195537
Low Mount: http://www.amainhobbies.com/rc-cars-...234000/p255547
The low mount has a shorter neck (by 1mm I think). It is mounted in the same way as shown in the manual, the car comes with the low mount studs for the spindle / rack.
Old 12-09-2015, 10:05 AM   #866
Ahhh, I didn't know those existed. Thanks.
Old 12-09-2015, 11:08 AM   #867
HotRod127's Avatar
What is everyone's wiring situation looking like, I'm about to do that tonight, but need some visuals. I have a r10.1 pro, s6240 servo and a r204gf reciever. Pics would be great, thanks guys.
Old 12-09-2015, 11:10 AM   #868
vito's Avatar
no shims for a savox 1257
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 12-09-2015, 11:10 AM   #869
bcablig's Avatar
Trader Rating: 97 (100%+)
If you have Facebook, check out 22 Empire. This question has been asked several times on there and lot's of pictures already posted.
bcablig is offline   Reply With Quote
Old 12-09-2015, 11:18 AM   #870
HotRod127's Avatar
don't have facebook, but i guess i can see what i can do
