    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 12-08-2015, 02:37 PM   #841
Davidka's Avatar
Trader Rating: 75 (100%+)
Originally Posted by rcus3r View Post
It is not unreasonable to assume that some issues are self inflicted.
Not in this case. Josh is among the most experienced racers you will find anywhere. The region he races in is full of good, long time racers. Like he said himself, it's not a big deal, but the production & QC process should be checked.
Old 12-08-2015, 04:10 PM   #842
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
Originally Posted by 303slowdown View Post
This being my first TLR and probably my last, I thought I'd give my opinion. The shocks are the worst I've built (not sure if I got some bad xrings ) they leak just sitting on the bench. I've bled the front shocks four of five times and can not get the same rebound. The shock shaft pushed through the xrings like there not even there. Others have talked about stripping screw holes , although I didn't strip out any holes some are probably very close. Screwing on the front shock tower those screws barely get snug. This is the first buggy I've owned where the dog bone is so close to the edge of the outdrive that it's scary (can't be that hard making them even .5mm longer) I'm sure it wouldn't hurt handling. The body is a pain in the a$$ to get in on the front through the shock tower. Steering rack is pretty tight too, was also disappointed the rack wasn't aluminum but soft plastic . So far after building the 22 3.0 I am not impressed with it but I'll give it a shot and see how it drives before I make my decision to sell it.
your doing it wrong
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 12-08-2015, 05:01 PM   #843
(After typing this wall of text I realized I quoted you and the majority is not directly addressing you)
Regardless how long he has been racing, building kits, every plastic has it's release point once you go past a certain degree of seated and the threads you just cut give out. It took me about the first two screws to realize this plastic was not going to give me the normal amount of rotation past seated. For this new kit the plastic will not let you get another 1/2 turn once you feel it seat, I went for about a 1/4 turn and left it like that. I even went so far as to only give a couple rotations on each screw as it was producing a ton of heat on the screws. I didn't even attempt to use my screw gun as I knew it would just be pure frustration in the end.
When you come off in the manner he did, combative and know-it-all, all you are going to do is turn folks off that might other wise of listened to you, human nature. There have been a ton of threads on numerous forums where Co. reps ended up walking away do to folks treating them like their whipping post. For a moment, put yourself in the shoes of the guy who helped design this car, gets it to market, and you may not care for folks who dump on the product in what appears to be sour grapes kind of approach, some of your points are salient but some are not. I doubt many had problems building their shocks the first time with out the slightest leak to be seen.
In defense of some of his points I see as salient-
I would much rather see the Kyosho style glass reinforced plastic they use, stuff is tough as nails and takes screws much better over multiple insertions\removals with out giving up their threads. The TLR plastic seems more maliable than anything I have built over the last few years, heck I grabbed a few from the late eighties and the only thing that soft was the white nylon from my original RC 10.
Fasttrak is offline   Reply With Quote
Old 12-08-2015, 05:14 PM   #844
303slowdown's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Matt M. View Post
your doing it wrong
Well apparently losi kits build different from every other kits on the market. Thanks for your words of wisdom.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 12-08-2015, 06:34 PM   #845
Trader Rating: 29 (100%+)
Ok fresh start... lets all stop being so critical of each other, we are all racing buds. Im guilty as well so i apologize.
On another note, has anyone had time to test back to back the short and long VLA?
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 12-08-2015, 07:00 PM   #846
Davidka's Avatar
0.
I know this and Josh probably knows it better than both of us. The parts in question are not new, they're from the previous versions, which I own/owned and don't strip easily at all.
Enough has been said about it. I'm sure Ryan is having the vendor review the production part. For now, we'll just have to build carefully.
Old 12-08-2015, 07:08 PM   #847
Joel Lagace's Avatar
Hopefully first time TLR kit builders are building by hand and not using a electric driver or drill????
Hand build it a bit to ensure you know how much power you need to thread the car together..
About the steering rack.. I find if you make sure the steering posts are secured tight with lock tight from the bottom you wont have to screw down that hard from the top. infact i make sure to just get it snug enough that things are held in place but try not to torque the top down. use the lock tight on the top screws as well.. Also double tripple check your screw lenghts to make sure your not using to long a screw where the top and bottom touch in the middle of the post
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 12-08-2015, 07:49 PM   #848
tfrahm's Avatar
Send a message via AIM to tfrahm
Your tips are good, but I wanted to add an additional thought...
I suspect that some folks may not be installing the shims/washers (LOSA6356) that go on top of the upper ball bearing in the bellcrank. It is easy to miss that step or to perhaps get them in wrong, causing binding in the steering...?
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 12-08-2015, 07:52 PM   #849
tfrahm's Avatar
OH - another "tip" on the steering:
Double check that the "tophat bushings" (TLR231027) are installed properly - if installed upside down, it is possible to overtighten the screws and bind the bellcranks...
Old 12-08-2015, 07:54 PM   #850
yes the shims also just fly away if your not paying attention they are supper light. i had my 2.0 apart the other day and almost lost one
www.rcottawa.com
Old 12-08-2015, 09:57 PM   #851
STLNLST's Avatar
Trader Rating: 19 (100%+)
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-08-2015, 10:06 PM   #852
Originally Posted by tilimil View Post
My LHS doesn't carry Losi and I am going to place an order for spare parts. What parts are most likely to break that I should keep on hand as spares?
Could you guys kindly help out a noob here?
tilimil is offline   Reply With Quote
Old 12-08-2015, 10:21 PM   #853
Depends on how far you want to go with having a backup parts list available. I try and keep a set of front and rear arms. No real need for A-D blocks as this kit comes with aluminum and if you're braking those you should just buy a second kit for parts backup. Maybe a front and rear shock tower, rare but you can brake them if you get knocked out of the air on a large jump and pile drive either one into the dirt. At the far end I have seen guys brake all the steering components so a spare part of each of those is not bad and even the steering bell cranks and swing assembly. It just depends on how self sufficient you want to be and how much you are willing to spend.
Old 12-08-2015, 10:50 PM   #854
RedBMaster's Avatar
I've been running my front ride height super low to generate enough steering to the point where I've bottomed out the shock collars. I've also dropped my ride height to help mitigate traction rolling.
I plan to put 2mm shock limiters all around to combat traction rolling, but I'd like to hear what others have done to add steering from the stock setup.
RedBMaster is offline   Reply With Quote
Old 12-09-2015, 07:04 AM   #855
HotRod127's Avatar
Trader Rating: 14 (100%+)
I know Maifield is just starting to run the car, but Frank you have his setup from Omaha?
Just built my kit, only have to put electronics in it, but it went together great with no issues.
Kyosho RB6.6/ Kyosho ZX6.6/ Kyosho RT6/ Kyosho America- Peak Racing Products- Team Orion- AKA
HotRod127 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
