TLR 22 3.0 Race Kit Thread!
#721
I had this same thing happen to me too, but I didn't discover this until I was at home, read your post, and then checked. At the track, the car did have a slight push to it, but I wouldn't attribute it to the car just yet with brand new tires and an overly watered down track.
Did you refill with oil and then bleed them, or did you bleed out what was already in there? I refilled mine and had to bleed them a couple times to get minimal rebound, but am left with some head space that concerns me.
I've been doing my shocks this way for a while now and don't suffer with rebound coming back during a race day and I can only think it might be something to do with a vacuum over time if you've bled out more oil than was needed and it draws in air perhaps
#722
Rebound on race day
Out of interest do you build and bleed your shocks with the shock bottoms fitted so as to ensure only the full amount of travel is used when bleeding out the excess oil.
http://www.clearcoproducts.com/pdf/l...pansion-SF.pdf
#723
I may be wrong, but a lack of air (space) is what causes rebound. If you don't bleed the shocks, the shaft has nowhere to go in the shock and is pushed out. So, to start with zero rebound and end up with halfway is peculiar.
Here is a thought. I know almost nothing about this but seems to me that on race day you are building heat in the shocks from running on the track. When you built the shocks they where at room temp, so it only makes sense that when it heats up it take up more volume and hence would push the shock shaft out a bit more on the rebound.
#724
Curious if anyone else had to tighten the slipper screw significantly -- almost bottomed out?
Diff is broken in. Not barking. Front wheels are lifting about 3-4 inches.
It works, but seems odd that we have to pinch the spring down that far.
#725
With another week with the silicone oil on the x-rings, they'll fit the shaft a little tighter and it'll be harder to suck the air. Ultimately, I'd still go with building at the track.
#726
Somehow you have air coming into the shock (or pressure has just increased). Your overall oil volume (oil mixed with air) has gone up since you built the shocks. Shock rebound should be checked before you run on a semi-regular basis. (i check mine once per race day on the weeks I don't rebuild)
#727
Here is a thought. I know almost nothing about this but seems to me that on race day you are building heat in the shocks from running on the track. When you built the shocks they where at room temp, so it only makes sense that when it heats up it take up more volume and hence would push the shock shaft out a bit more on the rebound. Here is a chart, I don't know how to read it, but maybe someone smart can figure it out....lol.
#728
A zero rebound emulsion build will have negative pressure at extension. It'll suck in air eventually. This setup has the smallest amount of air in it at the onset. It might hold adjustment longer with a bladder since that allows for a larger air bubble above the oil.
Theoretically, your optimum setup would be to bleed & set rebound when the oil is already emulsified with air, just after a run. In a matter of a couple of minutes, the air separates from thr oil and reconstitutes the "bubble" so thisthis would be hard to achieve.
I usually bleed for no rebound and allow the shock to acquire its air on its own. This usually results in a consistent 1/2 rebound. Since this is something I can rely on, I don't tune with rebound.
#729
iam soo happy i just got my buggy see you guy later
#730
#731
Fill & cap the shock (work out air bubbles 1st), open the bleed screw, compress slowly and replace the bleed screw with the shock at the top of its stroke. Reassemble with spring and let the car sit on a stand with the shocks fully extended. They'll draw in the air and usually settle at 1/2 rebound after they draw in air.
What I like about my method is that it is repeatable and consistent.
#733
Just finished up my build and put mine on the track for the first time, haven't put a transponder in it yet but it feels very predictable and smooth!
Parts Etc:
Parts Etc:
- Hobbywing Xerun 3.1 Stock ESC
- Reedy Sonic Mach 3 17.5T Motor
- Orion 4500mah 100C Shorty Lipo
- Spektrum SRS4210 Rx(This would not have fit in 2.0 car!)
- Savox 1258TG Servo
- TLR Aluminum Driveshafts
- 10mm Hex Front Axles (To use wheels from 2.0 car)
- JC Gold Dirt Webs
#734
Parts Etc:
Parts Etc:
- JC Gold Dirt Webs
#735
What's the weight difference in the light weight body?
