    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 12-01-2015, 06:35 AM   #586
RedBMaster's Avatar
Originally Posted by Matt M. View Post
the info i have is 21.5 mm front stroke, and a 31mm rear stroke
Frank, could you please update the first post with this info and the servo spacer chart. It'd make both much easier to find. Thanks man!
RedBMaster is offline   Reply With Quote
Old 12-01-2015, 08:53 AM   #587
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by tipperjackson View Post
I don't think there wouldn't be enough room for the slipper pad. Maybe Frank will chime in. I think they would have to re-design the slipper pad to make that happen.
Exactly, we can't make an HDS 70T.
Originally Posted by motorcitymatt View Post
I was using the very top level menu: "Support"->"Setup Sheets" and then looking for the 22 3.0 in the drop-down box list. It isn't there.
But what you have said definitely works. Sorry for the confusion. TLR just needs to update that drop-down box on their site to make it complete.
I've already asked, about 3 times...
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 12-01-2015, 09:01 AM   #588
Trader Rating: 119 (99%+)
Originally Posted by Speedychris22 View Post
Picking up the kit from my local hobby shop today. Any build tips?
Enjoy it. Its a great build. Suspension is a touch on the tight side on the front end, but I'm confident after just a couple packs it will free right up. I was very very impressed with how it went together. Excellent fit and finish
skoalisbad4me is online now   Reply With Quote
Old 12-01-2015, 10:59 AM   #589
vito's Avatar
you guys like to see the ups truck soon
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 12-01-2015, 03:09 PM   #590
Jpdanger's Avatar
I finished my build last night. I wouldn't say I disliked this build, but I will say this was my least favorite build yet. I couldn't screw the shock shaft end in enough to get the 21.5 stroke, so I had to add an additional 2mm of spacers in the shock. I had a few issues stripping screw holes in the plastic pieces without much effort and binding in the arms. However, those didn't bother me as much as the inconsistencies in the manual. No servo spacer info. No shock stroke info. I found that info here, but that should have been in the manual. I noticed there were a couple of instruction steps that assembled the step differently that the accompanying picture, such as shocks in a different location. The kit setup sheet has red front springs listed, but mine included silver springs. I was going to buy silver springs with my kit, but I'm glad I decided against that at the last minute.
I hope the instructional manual issues are fixed for future customers. Anyway, I am excited to get this car to the track and see what it can do. I built mine with the Schelle slipper system and a 69T spur. Otherwise, everything is set up according to the build and not the included kit setup at the back of the manual.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 12-01-2015, 03:29 PM   #591
TLRacing
Frank Root's Avatar
The build steps are the correct, not the setup sheet in the back of the manual (which has the mistakes). Those have been updated on the web site. We made a last minute change on the front springs, to dial the car in from testing, and we weren't able to get the manual updated in time.
The servo spacing, I have no idea how I missed that, but we'll get it updated. Spacing is the same as all other TLR kits/manuals.
As far as the shock stroke. The kit setup is, install the limiters as shown in the assembly steps, then screw the eyelets all the way in. Stroke is just a number that helps when you start unscrewing the ends, not a necessity to build to the kit setup.
What screw holes did you strip? Which power driver did you use? I haven't heard any comments from team drivers, or had any issues with my car. I know the drive I use well, and which clutch settings are appropriate.
Old 12-01-2015, 04:38 PM   #592
tipperjackson's Avatar
Trader Rating: 16 (100%+)
LOL.....I'm guessing the 400 ft lbs air ratchet.....
Slower is Faster!....Don't forget to have fun, your racing Toy Cars.........!
Losi 3.0 E Truggy~Losi 3.0 E Buggy~Losi 3.0 Buggy~Losi 22-4~Losi 22 2.0~Losi 22 1.0
tipperjackson is offline   Reply With Quote
Old 12-01-2015, 05:33 PM   #593
I have the front end done and I can tell you 4 screws so far have not even tightened up.
No power drivers used.
Josh Hohnstein is offline   Reply With Quote
Old 12-01-2015, 05:59 PM   #594
303slowdown's Avatar
Trader Rating: 21 (100%+)
I usually don't buy kits as soon as there released and I'm not really a losi fan but decided to order this kit. Is there anywhere to buy spare parts like arms or anything ? Do parts not get released at the same time as kits ? I cant seem to find any of the spares for this car.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 12-01-2015, 06:13 PM   #595
brian cox's Avatar
Trader Rating: 54 (100%+)
Horizon Hobby is showing all kinds of 3.0 parts in stock
Team Orion---Bradley Fine Line Design---AKA
brian cox is offline   Reply With Quote
Old 12-01-2015, 06:16 PM   #596
OK thanks , I thought they were just a distributor, I'll check them out.
Ryan Borgheiinck
Old 12-01-2015, 06:44 PM   #597
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
which 4..mine are tight..
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 12-01-2015, 06:44 PM   #598
Davidka's Avatar
Trader Rating: 75 (100%+)
Which parts? Are they the same as the last model?
Old 12-01-2015, 06:58 PM   #599
2 on the front tower, one on the top of the servo mount and one on a chassis side plastic piece.
Old 12-01-2015, 07:49 PM   #600
TLRacing
Frank Root's Avatar
I'm guessing the tower wasn't flush to the bulkhead, and those screws probably just aren't bottomed out.
The one on top of the servo mount, we tightened those from the last car, and mine have been super positive and not stripped at all.
It is a metric machined thread into plastic, no matter how "tight" the thread are, I could strip them all out if I tried. But building lots of cars, and knowing how to feel when the screw is stopping in the hole is pretty key.
