    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 01-30-2017, 08:17 PM   #4261
Originally Posted by Troubles Dad View Post
I believe the 338004 is the complete carpet conversion, and the 005 is the conversion without the rear hubs? So correct me if I am wrong, but have you tried contacting TLR or even Frank Root on this thread, that would be in my opinion a lot easier if them parts are even available, but I would think they are
The newer one (ending in 5) is the dirt laydown. The original one was the carpet laydown. The new one has the standard height diff, meaning the standard hubs are correct so no need for new ones. The new one also has a slightly thicker body.
Callaway is offline   Reply With Quote
Old 01-31-2017, 07:36 AM   #4262
Trader Rating: 171 (100%+)
thank you for the info, as was looking for laydown conversion and could not figure out why they wanted 50 dollars more for the 04 number, as I was thinking I seen a different part number for the dirt laydown, so whats the real difference between the two??
We go to have fun, that is why we go
Grand Cities R/C Club member
Ecrt.5 on 4s pack= 82 mph
Ecrt.5 on 6s = broken parts
Troubles Dad is offline   Reply With Quote
Old 01-31-2017, 08:13 AM   #4263
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by OriginalDonk View Post
I see Dakota's CRCRC setup for the 22-4 2.0. Don't see the 22 3.0. Any chance that's available to post Frank?
I just followed them up to ensure it gets posted.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 01-31-2017, 08:32 AM   #4264
TLRacing
Frank Root's Avatar
It is actually up there, you just need to clear your cache.
Old 01-31-2017, 10:16 AM   #4265
Frank did you see the discussion above about replacement parts for the laydown conversion?
Some of the parts have the same part number that relate to the overall laydown conversion, obviously if you needed a new motor plate you wouldn't want to have to buy another full laydown kit. Any ideas on the individual part numbers?
daz_75 is offline   Reply With Quote
Old 01-31-2017, 02:57 PM   #4266
johnny44's Avatar
Originally Posted by RCJer View Post
I've been searching this thread and will still keep doing so, but i just got a used but almost brand new 22 3.0 with the dirt laydown. I was wondering what all spares do you guys recommend having with you. Our track has an ok supply but i want to make sure i have the basics in my box. thanks!
RCJer,
So you know our track shop has had everything I have broke and more. Even had stuff I ordered before I knew they carried it.
Nick and Steve are awesome about helping out.
johnny44 is offline   Reply With Quote
Old 01-31-2017, 02:58 PM   #4267
johnny44's Avatar
Thanks daz_75 for the shout out to Frank.
Old 02-02-2017, 01:28 PM   #4268
skrichter's Avatar
Send a message via AIM to skrichter
Originally Posted by skrichter View Post
To even further confirm the speculation a 4.0 is being developed...
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 02-02-2017, 04:07 PM   #4269
Default Front spindle set
Just purchased these and it didn't come with any chart stating which is better for what track. Any hints on where to find this info. Thanks in advance
tlr224 is offline   Reply With Quote
Old 02-02-2017, 04:52 PM   #4270
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
There are really 2 types. 1 and 2 are the same except 2 has a lower mount for more adjustability for bump. 3 is the standard setting.
1/2 seem to lengthen the tie rods just a bit compared to 3 which gave me more high speed but less low speed.
K_King is offline   Reply With Quote
Old 02-02-2017, 06:38 PM   #4271
I'd say so. The question is... do I go ahead and start offloading my 3.0 rigs now? I wonder if this will be a more incremental change than the change from 2.0 to 3.0 was. Oh well. Time will tell!
Old 02-02-2017, 07:28 PM   #4272
If they come out with a new kit it will be based on the current design. It will use the 3.0 parts and have things like the laydown tranny, shocks in front of the arms in the rear ect. I doubt they will go ground up only a year after the 3.0 came out.
LosiMadMan is offline   Reply With Quote
Old 02-02-2017, 07:30 PM   #4273
tony montana's Avatar
Trader Rating: 65 (100%+)
I agree. Maybe a 3.1 car. I don't think there is a need for a whole new design
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 02-03-2017, 05:08 AM   #4274
My guess is it will be released as a new version of the 3.0, much like they did for the 3.0SR.
3.0DL and 3.0CL, you heard it here first...
jmitchell is offline   Reply With Quote
Old 02-03-2017, 08:20 AM   #4275
xyzracer's Avatar
I agree, still think it will be 3.0 based but it appears they already named it the 4.0 based on the screenshot for the 4.0 chassis that was posted earlier. I am betting a carpet and dirt version as well...
xyzracer is offline   Reply With Quote
