    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 01-20-2017, 11:31 AM   #4186
johnny44's Avatar
Originally Posted by greener74 View Post
Everything depends on what you are trying to accomplish. I know guys that run direct drive with 13.5 on carpet. Then there are guys like me who have never run direct drive. And I use the 70t spur for the 22 2.0 that uses the old style slipper pads.
https://www.amainhobbies.com/team-lo...63883?v=216080
https://www.amainhobbies.com/losi-sl...-compatibility
I'm not sure if that is for one pad, or if there are two in the package. Seems pricy for just one.
I'm trying to get to a 70/25 on my 13.5 with the direct drive, if that is possible?
What else is needed to run the 22 2.0 slipper set up on the 3.0, and does it work as well? Since TLR is claiming the 3.0 to be Heavy Duty slipper?
johnny44 is offline   Reply With Quote
Old 01-20-2017, 12:01 PM   #4187
For the 2.0 slipper all you need is 2 old style slipper pads and the 70t spur that use the old pads. it works well enough for me. 17.5 and 13.5
Losi has a 69t direct drive spur, that would be close enough. They recommend 70-30 for 17.5 and I run 70-35. So that 70/25 isn't set in stone.
greener74 is offline   Reply With Quote
Old 01-20-2017, 12:10 PM   #4188
If you want a slipper and a spur around 70t, I recommend the Avid slipper. Way better than the old 2.0 slipper.
Callaway is offline   Reply With Quote
Old 01-20-2017, 12:21 PM   #4189
LBR_Frank's Avatar
Is there something special about the 70/25 combo? Can you just create the same approximate FDR with the 69T direct drive spur and the right pinion? Sorry I am way off point, I need more coffee lol.
TLR 22 3.0 Spec-Racer (Album)
17.5 Tekin Gen 3
Tekin RS Gen 2
Spektrum S6240
LBR_Frank is offline   Reply With Quote
Old 01-20-2017, 12:30 PM   #4190
johnny44's Avatar
Originally Posted by LBR_Frank View Post
Is there something special about the 70/25 combo? Can you just create the same approximate FDR with the 69T direct drive spur and the right pinion? Sorry I am way off point, I need more coffre lol.
I'm sure I could... But I wanted to try what the manual states for the 13.5T motor gearing. And the DDS says recommended 17.5T and not made for the 13.5T!
Old 01-20-2017, 02:11 PM   #4191
Davidka's Avatar
Trader Rating: 75 (100%+)
The only real difference are the friction rings. I switched to the 2.0 rings and never looked back. I really only use the slipper to protect the diff, not for any kind of traction control (17.5 racing).
Old 01-20-2017, 03:05 PM   #4192
Trader Rating: 62 (100%+)
I, and many other people run direct drive in 13.5 with no issues. Unless you're on a very small track you should start your gearing around 72/28.
TEKNO RC * TLR * EXOTEK
patrick is offline   Reply With Quote
Old 01-20-2017, 04:25 PM   #4193
Rafiki94's Avatar
I have converted my 3.0 front axle to the 2.0 to save on buying more front tires. Now TLR discontinued the lug screw. What do I use now? Any Ideas?
TLR22 2.0
TLR22-4
TLR22T
TLR22 3.0
Rafiki94 is offline   Reply With Quote
Old 01-20-2017, 09:47 PM   #4194
F N CUDA's Avatar
Trader Rating: 31 (100%+)
A button head screw or a longer screw thru from the backside with a locknut should do it
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 01-21-2017, 02:37 AM   #4195
That's a bit annoying but there are plenty on ebay
daz_75 is offline   Reply With Quote
Old 01-21-2017, 07:06 AM   #4196
Davidka's Avatar
Hex screw with an alloy socket-type washer. A little less convenient than being able to jse the same 7mm wrench on all 4 wheels but certainly not the end of the world.
Old 01-21-2017, 07:57 AM   #4197
CCristo's Avatar
Trader Rating: 55 (100%+)
Send me a PM with your mailing address and I'll give you some titanium axles so you can use standard nuts. I no longer need them and they are just sitting in my spares box....
Chris Cristo
Pro-Line RacingHobbywingMIPBOOMrcFutabaPT RC Racing Oils
CCristo is offline   Reply With Quote
Old 01-21-2017, 03:38 PM   #4198
Rafiki94's Avatar
PM sent I am always willing to take free stuff, But I am willing to pay for them, Thanks
TLR22 2.0
TLR22-4
TLR22T
TLR22 3.0
Old 01-21-2017, 08:58 PM   #4199
Bmans5's Avatar
So 2 races in and loving my SR, haven't changed a thing from box setup and its the easiest car to drive (at least for me). But the time has come to change things.... my laydown kit arrived the other day.
Alot of the setup sheets I see are for mod setups, anyone have a good 17.5 laydown carpet setup or could point me to one?
Bmans5 is offline   Reply With Quote
Old 01-22-2017, 08:10 AM   #4200
johnny44's Avatar
Thank Everyone for your feedback and ideas. After race day at the track yesterday and talking with the guys and taking your info into consideration. I went with the schelle slipper, which is very similar to the Avid slipper.
Next question: Is this the size thrust bearing for our buggies? [2.5x6x3]
Thank You again
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
