    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 12-14-2016, 06:28 AM   #3946
Originally Posted by Bmans5 View Post
That's What I was told at my LHS today...then maybe I have it by the weekend...or next weekend. Can't wait
So since we race Carpet Spec 17.5 here, I should be looking to get a discontinued laydown kit, but the spec racer has a chassis that is lightened, so by going that route I would be loosing on a lightened chassis, correct?
Any chance a lightened laydown conversion kit is in the works? or maybe the chassis in the spec is setup so it can use the laydown transmission from the get go?
The spec racer is supposed to come in under weight, even with electronics. So you should have to add weight to bring it up to minimum legal weight. Adding a heavier chassis would help bring the weight up, and it's adding the weight as low as you possibly can. May be a good idea, especially since the laydown will practically eliminate traction roll on carpet (in my experience) and let you keep much higher corner speed.
Callaway is offline   Reply With Quote
Old 12-14-2016, 08:16 AM   #3947
TonyWest's Avatar
Trader Rating: 50 (100%+)
I will have the dirt laydown tomorrow
WALDORFRC.com
301-932-9193
Team Associated / AKA / Byrons Fuel / Futaba
TonyWest is offline   Reply With Quote
Old 12-14-2016, 09:04 AM   #3948
LBR_Frank's Avatar
Originally Posted by Frank Root View Post
Any day now, hopefully tomorrow.
omg omg omg omg omg
I have mine on order as well. can't wait! Then I can finally change my sig 😎
TLR 22 3.0 Spec-Racer (Album)
17.5 Tekin Gen 3
Tekin RS Gen 2
Spektrum S6240
LBR_Frank is offline   Reply With Quote
Old 12-14-2016, 09:18 AM   #3949
TonyWest's Avatar
The 22 3.0 Specs are now in stock.
My shop has some on the way.
WALDORFRC.com
301-932-9193
Old 12-14-2016, 09:43 AM   #3950
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
No lightened laydown in the works. Yes, you'll want TLR338004 for carpet.
Originally Posted by jmitchell View Post
Frank, any idea on when the new dirt laydown conversion kits will be available?
They are now.
Originally Posted by LBR_Frank View Post
omg omg omg omg omg
Shipping today.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 12-14-2016, 04:28 PM   #3951
Bmans5's Avatar
Thanks For the info Frank
Bmans5 is offline   Reply With Quote
Old 12-15-2016, 07:20 PM   #3952
Bmans5's Avatar
Just confirmed with my LHS I will have it end of next week....the day before X-mas.
Going to put a bow on it and tag saying from my kids to me, so when the wife sees it there is no way she can get mad....cause the kids bought it for there dad
Old 12-15-2016, 09:08 PM   #3953
TLRacing
Frank Root's Avatar
Smart Man
Old 12-17-2016, 09:44 AM   #3954
F N CUDA's Avatar
Trader Rating: 30 (100%+)
22 3.0 Spec Racer
Got it yesterday afternoon 1 pm
Thanks OCRC Raceway!
Built it yesterday afternoon
Tested it yesterday afternoon 5pm
Raced it yesterday evening 7pm
Just as I expected, another TLR kit, out of the box, dialed.
So glad they test here.
Medium to hi bite clay.
Good job, great idea for the stock class!
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 12-17-2016, 10:58 AM   #3955
TLRacing
Frank Root's Avatar
Originally Posted by F N CUDA View Post
22 3.0 Spec Racer
I'm so glad you like it Cuda! Hopefully I'll see you soon!
Old 12-17-2016, 04:25 PM   #3956
Absolutely lame question but I can't keep my aerial tube from falling out if the hole, tightened the grub screw as far as possible although it just spins near the bottom
What am I doing wrong?
daz_75 is offline   Reply With Quote
Old 12-17-2016, 04:54 PM   #3957
Are you talking about the antennae tube and screw? The screw usually just bites a little into the plastic on the side of the tube. I have tried some aftermarket tubing that was slightly smaller in diameter, which didn't bite or hold as well. You may be able try a different brand of tubing, or use something like shoe goo to help assist (don't worry, shoe goo can be taken off later if desired). You might even be able to coat the outside of the tube with some super glue (or tire glue) to build up the surface area and make it larger, enabling the grub screw to dig in a little more. Hope some of this helps, if I understood your question correctly (and there are no lame questions).
StadiumRC is offline   Reply With Quote
Old 12-17-2016, 05:08 PM   #3958
You did understand thanks for the reply I'm using the kit tube so would have thought it should be OK
Wonder if I've over tightened it and it's damaged the actual housing some how???
Really need to get and antenna less receiver
Old 12-17-2016, 05:22 PM   #3959
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Don't tighten the screw all of the way to the bottom. Most tubes have the wire inserted in the bottom so you have a small gap between the start of the tube and the chassis. So if you tighten the screw all of the way down then it might not be making enough contact to keep the tube in place.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 12-17-2016, 07:39 PM   #3960
klowne's Avatar
Another way to do it , that I seen someone doing and now I do. I take a piece of the 3m hook and loop secure tape. I cut it to fit on my receiver and then take the antenna and slowly wind it through that to secure it and place that on top of the receiver. This keeps it nice and tidy and out of the way.
http://www.bond-tape.com/3m-dual-lock-fastener.html
Here is a link to it. If you need a picture of it on the receiver I can get you one.
Last edited by klowne; 12-17-2016 at 07:40 PM. Reason: putting in link to the product I am talking about.
klowne is offline   Reply With Quote
