    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 12-04-2016, 10:11 PM   #3856
Originally Posted by intense82 View Post
TLR338004 tagged discontinued on amain ??
I'm sure they are repackaging it like the laydown dirt conversion. I'm sure they are going to take out the aluminum hubs and stuff to make the conversion cheaper like the dirt conversion just announced.
LosiMadMan is offline   Reply With Quote
Old 12-05-2016, 10:20 AM   #3857
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Yes.
Not repacking anything. Sold out of TLR338004, and now have fresh inventory of TLR338005 coming in.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 12-05-2016, 11:03 AM   #3858
Originally Posted by Frank Root View Post
Yes.
Yes used the wrong words, but that's what I meant. Because it seemed the price was the biggest complaint, I figure that is what the change is for. The chassis with both mounting options also.
Old 12-05-2016, 02:20 PM   #3859
Does anyone run the laydown on carpet with their rear hubs reversed? If so what's the benifit?
Old 12-05-2016, 02:23 PM   #3860
MNiceGuy's Avatar
Yes.
I might be missing something here but aren't 338004 and 338005 for different applications? Isn't the first is the carpet/very-high traction laydown with the raised diff and hubs where the latter is the dirt laydown with 'standard' geometry?
22 3.0 Laydown | 22T 2.0 | 22T 3.0 | 22-4 2.0 | XXX-T MF1 | XX4
MNiceGuy is offline   Reply With Quote
Old 12-05-2016, 03:11 PM   #3861
338005 is the new dirt lay down kit that's cheaper than the old carpet conversion because it leaves things out like the aluminum hubs. The old carpet conversion is discontinued and there will be a new carpet conversion kit that's cheaper like the new dirt laydown. "This is my theory because I don't think it's been announced yet." Or maybe a carpet specific car . I would have said no to that but with the release of the spec kit maybe. There are a ton of carpet tracks opening up and some tracks that have converted to carpet, so maybe.
Old 12-05-2016, 03:14 PM   #3862
TLRacing
Frank Root's Avatar
Yes, they are for different applications. Based on the "dirt" tranny sales, it's pretty clear which is what people are really after, which is why we've moved on to TLR338005.
Old 12-05-2016, 03:28 PM   #3863
tsair's Avatar
How long before we see transmissions mounted on some kind of "eccentric ring", allowing you to infinitely adjust the height and angle between the diff and the motor.
VDT: Variable-Dialed-Transmission
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 12-05-2016, 04:32 PM   #3864
So there is just not going to be a carpet laydown? Just the gear box I assume?
Old 12-05-2016, 04:59 PM   #3865
That's what it sounds like. And really, I think that's easily the right move. I need both laydowns, but I would have preferred doing it this way and having the stand up option on the same chassis. I would have then bought the carpet laydown and hubs as an add on.
Callaway is offline   Reply With Quote
Old 12-05-2016, 05:42 PM   #3866
I only race on carpet so it doesn't bother me. I still think the gear boxes are on the high end of the pay scale though. Having the option to switch is always nice
Old 12-05-2016, 07:31 PM   #3867
Schumacher has been doing that for a while.
TimmE is offline   Reply With Quote
Old 12-05-2016, 07:49 PM   #3868
Yeah, the machined delrin is pricy. But it is the best you can get.
Old 12-05-2016, 09:09 PM   #3869
Yeah I understand that, but why is it needed? All the other kits have come with plastic gear boxes. Does it add an advantage? They have had plenty of time to create a plastic mold for the gearbox. Maybe I just don't understand it's advantages. Weight, strength??
Old 12-05-2016, 09:16 PM   #3870
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
The machined parts were to fill an immediate need. If you wanted a true molded part it takes a lot of time to get the mold, test it, change the mold, etc etc.
Machine is so much easier, except on an economies of scales that is. While molding plastic is ultimately cheaper once the expensive part is complete (the mold itself) machining is simply having a machine cut it out for you. That takes money, as does the material it is made out of. Add that to the low count of production and you can see where the cost comes from.
Machining something = extremely quick, but expensive.
Molding = much slower, cheaper in the long run.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
