    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 10-24-2016, 05:39 PM   #3676
tony montana's Avatar
Trader Rating: 65 (100%+)
Mine really isn't that loud. But I only have about 8 packs threw it so far. I'm not getting the steering or corner speed out of mine so far thou. It's kind of weird, it's kind of loose and doesn't have the steering that I had when running stand up. I know it's all in the setup, but any suggestions? Setup now is front shocks associated white spring, 1.6 piston, 32.5 oil. Rear low frequency white spring 1.7 piston 30 oil. Standard plastic rear hubs middle hole 2mm washer. 3.5 degrees rear toe. Rear hubs spacing is middle. Middle hole on tower and middle rear arm for shocks. Front end is basically stock.
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 10-24-2016, 06:43 PM   #3677
Losi Chaser's Avatar
R/C Tech Charter Subscriber
Originally Posted by GasserX View Post
whats the best way to reduce dirt laydown transmission noise? I have used the black grease on the gears and it didn't help much. Is my case screwed together too tight?
If you're racing mod don't be stingy with the black grease. Wouldn't hurt to check/clean motor bearings.
Losi Chaser is offline   Reply With Quote
Old 10-25-2016, 09:08 AM   #3678
Trader Rating: 23 (100%+)
Have someone watch the car when you drive, when I first tried the dirt laydown the front end seemed to dump to the outside wheel in the middle of the corner and I would lose steering. After I put on a stiffer front spring that feeling went away.
Sponsors- Team Losi Racing, Pro-Line, Orion, Nitrotane, Horizon Hobbies, Avid
electrickid is offline   Reply With Quote
Old 10-25-2016, 12:40 PM   #3679
Potoczak's Avatar
Trader Rating: 111 (100%+)
I'm going to be building a 22 3.0 with a laydown for 17.5 racing. Any recommendations on option parts to put on right away while building?? Also any good setups available for 17.5 on med to high bite clay track??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 10-25-2016, 07:17 PM   #3680
I would go with pucks and maybe some cut gears!
Old 10-25-2016, 08:40 PM   #3681
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
TLR lockout shaft.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 10-26-2016, 02:50 AM   #3682
Default Dirt laydown
Hi guys. Just ordered the tlr laydown and dirt case I run mod 8.5t on wet high high bite clay and super soft slicks. Can anyone give me any tips for set ups or goodies needed?
Cub86 is offline   Reply With Quote
Old 10-26-2016, 11:06 AM   #3683
Depending on driving style, Dakota or Maifields setups from nats are both good setups. Both setups run brass C blocks so I would recommend that, but other than that you are pretty much good to go.
Old 10-26-2016, 11:17 AM   #3684
GasserX's Avatar
electrickid, what are the brass c blocks?
LOSI 8E 4.0
LOSI 22-4 V1.5
LOSI 22 3.0 Dirt Laydown
GasserX is offline   Reply With Quote
Old 10-26-2016, 11:57 AM   #3685
Here you go, this is the TLR one, exotek makes one too. Little more weight behind the battery but in front of the diff.
http://www.horizonhobby.com/product/...30-p-tlr334035
Old 10-26-2016, 08:08 PM   #3686
klowne's Avatar
Got a few questions... seems my steering is sluggish at times any way to maybe make it a bit quicker? Also it seems when I go to get on the power the backend wants to come around pretty easily. I am running the standup on a clay track that gets dusty pretty bad at times. Any suggestions would be great. I lean toward the pressure points from jconcepts for rear tires. I am not getting the consistency that I got out of them last year on the same track. I am running 17.5 blinky.
Thanks for any help.
klowne is offline   Reply With Quote
Old 10-26-2016, 10:58 PM   #3687
Try lowering your rear roll centre by moving the rear camber block up using the supplied inserts.
Make sure your rear camber is no more than -1.5
Maybe do a shock rebuild. They may have taken on a little air
Space rear hubs forward 1 or 2mm
Also try 3.5 rear toe.
These will all help for rear traction.
If your still looking for more traction definently try the 4gear.
As for steering. I put my front shock in the inner hole on the tower and added 1mm of shims under inner ball stud to lower front roll centre. If I ever need more steering I just change the weight bias of the car.
ChrisUU is offline   Reply With Quote
Old 10-27-2016, 02:12 AM   #3688
I just installed the 30g losi brass hinge pin and 9g exotec lrc on rear. Up front losi aluminium pivot plate, brass 25 degree kick plate and aluminium front camber block. Also running 4 gear stand up and 10.5t motor. Car handles awesome on loose and medium & high traction dirt/clay. Well worth the upgrades.
I have a b6d, xb4 and sworks 104 evo and this is my fav car to drive!
Originally Posted by Dog Runner View Post
In the setups with the weighted hinge pin brace, is the better option the 24g Exotek option (this one: https://www.amainhobbies.com/exotek-...xo1651/p498369) or the TLR one that appears to be 30g (this one: http://www.tlracing.com/Products/Def...odID=TLR334035)
I'm assuming these are the same thing and just different weight? Or are they different parts altogether?
Any use for the rear/rear brace for another 9g? (this one: https://www.amainhobbies.com/exotek-...xo1654/p505837)
crowie03@gmail. is offline   Reply With Quote
Old 10-27-2016, 06:50 AM   #3689
klowne's Avatar
Thanks Chris I will give that a try to see how it does this weekend.
Old 10-27-2016, 10:23 AM   #3690
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
One thing - Pressure Points for 2wd are not the right tire for your track. You might need to just run or test some low tread dirt webs, or another type of tire. The PP's haven't been the best tire at any track I've seen or heard of, so this is probably some of the issue.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
