    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 10-04-2016, 02:17 PM   #3586
Originally Posted by K_King View Post
Here's my current setup.
Dirt laydown setup?
psycho02 is offline   Reply With Quote
Old 10-04-2016, 08:15 PM   #3587
Originally Posted by awtwac View Post
Just finished building the 3.0 and the front castor blocks are binding. Browsed this thread and already made sure king pin screws were screwed in straight and are not too tight. Any suggestions for freeing it up? Thanks.
Run it. If everything is right and there's just a slight bind, it'll work itself out.
Callaway is offline   Reply With Quote
Old 10-04-2016, 08:26 PM   #3588
Anyone tried the Yokomo Yatabe Arena springs with the laydown conversion on carpet?
Old 10-05-2016, 04:23 AM   #3589
jonbrown's Avatar
Does anyone have a picture of how some of the team guys have modified the front pivot block and kick shim so the kick shim fits under the pivot block as per the setup sheets on tlracing.com
Also what is the idea behind doing this modification?
I have been told there is a video on TLR facebook but I'm unable to locate it, any ideas?
Jonathan Brown
X-Factory UK , Vampire , JConcepts , Avid , Exotek , RDRP
www.norfolkbuggyclub.moonfruit.com
jonbrown is offline   Reply With Quote
Old 10-05-2016, 05:01 AM   #3590
It's to raise the roll center in the front to match the geometry with the raised laydown transmission and +3 mm hubs in the rear. The simpler solution, although you have to buy something, is to use the front HRC aluminum pivot.
Old 10-05-2016, 06:36 AM   #3591
ryan432greening's Avatar
Here is Frank's video for the kick shim mod:
https://www.facebook.com/Team-Losi-R...6594021/videos
B-Main Racing
TLR 22 3.0, 22-4 2.0, 8ight-E 4.0, 8ight 4.0
GFRP M1
ryan432greening is offline   Reply With Quote
Old 10-05-2016, 05:34 PM   #3592
ta_man's Avatar
Trader Rating: 151 (100%+)
Why do people do that?
That's not "Frank's video for the kick shim mod" - it's a link to a whole bunch of videos not the one about the kick shim mod.
No matter how many "show more"s I did, I did not see a video title mentioning the kick ship mod.
Asking seriously: does Facebook not let you link to a specific video?
ta_man is offline   Reply With Quote
Old 10-05-2016, 05:51 PM   #3593
Weird, I attempted just to grab the one video that has the kick shim mod in it. It has a more generic title like "bunch of mods" or something like that and is 45-50 minutes long.
It's my understanding the kick shim mod is to raise the roll center when using very low ride heights like with the laydown chassis.
B-Main Racing
GFRP M1
Old 10-05-2016, 07:35 PM   #3594
Fabulous's Avatar
Trader Rating: 42 (100%+)
Hey Frank, now that the laydown conversion been out for awhile any chance on getting replacement parts? like the chassis? Maybe a standard weight body.
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Fabulous is offline   Reply With Quote
Old 10-05-2016, 08:13 PM   #3595
that is the big piss off. i own a 3.0 a 3.0 dirt lay down as well where are the parts.. Is tlr to busy to give support for the guys that support them or is it all about the up sell
Rozzy is offline   Reply With Quote
Old 10-05-2016, 08:48 PM   #3596
Wheel Nut's Avatar
It's on page 230 half way down. facebook.com/FrankRootTLR
When you get onto the facebook page scroll down about Quarter way and you should find it there.
Last edited by Wheel Nut; 10-05-2016 at 08:51 PM. Reason: Adjustment on facebook page
Wheel Nut is offline   Reply With Quote
Old 10-05-2016, 09:57 PM   #3597
thecman26's Avatar
Trader Rating: 99 (100%+)
What parts are you talking about? Anything specifically cause everything I am looking at for the laydown is in stock at amain....
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 10-06-2016, 03:39 AM   #3598
Fabulous's Avatar
My chassis is getting pretty worn on the bottom and would like to replace it. I don't see a part# just for a chassis. Also I'm not a fan on the ultra lightweight bodies either.
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Old 10-06-2016, 05:32 AM   #3599
thecman26's Avatar
Yeah I guess you'll have to let Frank chime in on that stuff. Not using a chassis protector?
Old 10-06-2016, 07:16 AM   #3600
awtwac's Avatar
Will do. Pretty happy with how the build went overall. Not quite as easy as the B6 I'm running, but vastly reduced slop compared to that car out of the box. Excited to run this thing in a few days.
awtwac is offline   Reply With Quote
