    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 08-16-2016, 06:50 AM   #3346
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by brad996 View Post
Frank I have been looking on the TLR site and i don't see the laydown dirt trans case could you give me the part number
1 page back
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-19-2016, 01:21 AM   #3347
Trader Rating: 137 (100%+)
Originally Posted by jonski View Post
That's the only reason...and I want TLR aluminum 67mm driveshafts because I don't want to put the MIP system on my car.
Me neither.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 08-19-2016, 10:14 AM   #3348
Default Binding Laydown/Dirt Transmission
For those of you working with the laydown and laydown dirt tranny - this question's for you. I recently built up both these cases and find that neither seem as smooth as I'd hope (bearings are smooth and clean). Are there any tips and/or tricks to help? Or is a bit of breaking in required to smooth up the transmission.
From what I have done so far I do see things get really bound if screws are over-tightened.
-Thanks, Todd
toddmanley is offline   Reply With Quote
Old 08-19-2016, 10:21 AM   #3349
Woulvesbaine's Avatar
Originally Posted by jpcopeland1 View Post
Me neither.
Titanium drive shafts would be nice. Or would they create additional wear on the outdrives? Maybe titanium shafts with steel pins?
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 08-19-2016, 10:50 AM   #3350
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
-Thanks, Todd
Other than cleaning up bearings and using a lubricant on them, I used protek white grease on the gears. Smooth as can be if not the smoothest TLR transmission to date.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies, Sweep Racing
WillS is offline   Reply With Quote
Old 08-19-2016, 11:20 AM   #3351
Team Pink's Avatar
Trader Rating: 20 (100%+)
-Thanks, Todd
Good morning Todd. Couple things I look for is to make sure the bearings are smooth. If smooth but slightly dry, I'd do a drop of bearing oil to see if that helps. If running ceramics I really like Schelle Black Diamond oil as it works really well. Lastly like Will said put a little grease on the gears. I use just the grease that comes in the kit. A little goes a far way.
Team Losi Racing/ Spektrum/ Horizon Hobby/ JConcepts/ Hobby Star/ Schelle Racing
Team Pink is offline   Reply With Quote
Old 08-19-2016, 01:10 PM   #3352
What wheels are you guys using for carpet tires? There is a carpet track opening soon and need wheels and tires for it.
jdutch03 is offline   Reply With Quote
Old 08-19-2016, 03:22 PM   #3353
-Thanks, Todd
If using the gear diff, you can shim it and that allows you to tighten the screws all the way down with no scrubbing.
I discuss it here
http://www.rctech.net/forum/electric...l#post14344273
LosiMadMan is offline   Reply With Quote
Old 08-19-2016, 03:39 PM   #3354
We use Dboot carpet tires at our local carpet track. Some people also run the gone bananas foams.
Old 08-19-2016, 04:26 PM   #3355
I was running the new dirt tranny bone dry - a little grease did the trick.
Old 08-20-2016, 05:39 AM   #3356
Schumacher mini pins and cut staggers are the go-to here. I ran the new JConcepts pin downs and swaggers last weekend though and they are easily my new favorite. Just remember that for either of those front tires (and for Proline wedges as well), they are meant to go on a narrow wheel, so cut the inside rib off a regular wheel before mounting them.
Callaway is offline   Reply With Quote
Old 08-20-2016, 11:59 AM   #3357
So we are cutting down the inner area of the wheel to fit the tires, so what is the best way thou have found to trim it down?
Old 08-20-2016, 04:37 PM   #3358
JsK
JsK's Avatar
Lexan scissors.
Trim the inner section off the fronts, rears are good to go.
No foams in the low profile fronts.
Soft open cell foams in schumacher rears.
JsK is online now   Reply With Quote
Old 08-20-2016, 04:56 PM   #3359
I wouldn't want titanium for my driveshafts, titanium is a brittle metal so it may just split before it would bend, and in that application it is useless because a thicker aluminum shaft will be about the same weight and strength and cost less. Titanium makes sense in screws and turnbuckles because it strong and light for it's density, but in something that you can make very thick, aluminum is just a cheaper, lighter option.
Ready, fire, aim!
RC8.2e- 150a 2200kv HW + 1283sg
rcbuggies is offline   Reply With Quote
Old 08-20-2016, 08:32 PM   #3360
thecman26's Avatar
Trader Rating: 98 (100%+)
Why not carbon fiber driveshafts?
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
