    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 06-23-2016, 08:01 AM   #3106
Like Kraig said it is all about what motor and how your track is. I run a Tekin gen 3 17.5 with can timing at 50 and 75/32 for gearing, and that is what I run on outside dirt track and indoor clay. Penn01 you asked about hubs, and I moved them forward to have 1mm in the front and 3mm in the rear and it did help rear bite and forward drive.
jdutch03 is offline   Reply With Quote
Old 06-23-2016, 09:43 AM   #3107
rregl0612's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Kraig View Post
There are a lot of variables like what motor are you going to use, what timing is it set at, how big is the track, what type of traction level is it. But people will still throw out gearing suggestions not knowing this information.
I have a Motiv motor, timing between 40-50 on the can, track is 100x48ish, grip is on the high side but not damp dirt/clay, and I would start at 70 spur 28 pinion based on that information.
100 x50 sounds about correct for my usual track. Pittstop hobbies, surface is mainly clay. Smooth and medium bite. Grooves but doesn't hold rubber.
I'm running a hw 3.1 stock. And a amain eco 17.5 motor at 35-45 timing dependant on straight, and needed torque for track conditions. Ie jumps our of corners. I don't fall into the weight weenie category. Still run a slipper, but do degrease my bearings.
And thank you, settings seem close so I'll give that a try to start with
rregl0612 is offline   Reply With Quote
Old 06-23-2016, 12:23 PM   #3108
cokemaster's Avatar
Trader Rating: 18 (100%+)
Originally Posted by Racecarguy View Post
Where do you get the shims from?
Go to page 137 to see the different options.
Fleet:TLR 22 3.0, XB4 16, Mugen MBX7RE
ESC: Viper, Tekin, Airtronics/Sanwa
Motor: Novak, Tekin, Trinity, Scorpion
Radio: Airtronics M12
cokemaster is offline   Reply With Quote
Old 06-23-2016, 02:05 PM   #3109
Thank you very much jdutch03
PENN01 is offline   Reply With Quote
Old 06-23-2016, 09:11 PM   #3110
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
Not everyone has the same page setups. Just link to the post through the number in the upper right corner.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies, Sweep Racing
WillS is offline   Reply With Quote
Old 06-24-2016, 05:55 PM   #3111
Is anyone running the exotek laydown with a gear diff?
raceyz is offline   Reply With Quote
Old 06-24-2016, 06:06 PM   #3112
HollywoodRC's Avatar
I am running the Exotek but with a ball diff. I have to say it is awesome. I went from the B Main to TQ in my quals. The buggy just hooked up for me. I have a gear diff but haven't tried it yet. All the Losi guys at our track are running ball diffs.
HollywoodRC is offline   Reply With Quote
Old 06-24-2016, 07:35 PM   #3113
Not all of them.....
3DRCRACER is offline   Reply With Quote
Old 06-24-2016, 09:49 PM   #3114
Did your gear diff fit in the exotek case good?
Old 06-25-2016, 07:08 AM   #3115
I don't have experience on the exotek since I use the Losi conversion but I would assume the gear diff should fit the exotek no problem though. I've been using a gear diff almost since I got the car only because its easier for me since I came from 8th scale. I started with the Losi gear diff but did not like the quality of it so I switched to the Serpent diff. Its a huge improvement over the Losi rtr diff. Been running 2k in it at Thornhill. I had to remove the thin shims in the Losi gear diff to get it smooth. The pins that hold the outdrives in were biting into the shims and creating binding issues. Unfortunately the pin length is the same as the diameter of the o-ring and the outdrive/pin can be pulled out of its slot in the drive gear. I tried a longer pin but the slot in the drive gear would have taken more tooling than I was willing to do. At that point the outdrives were already getting sloppy in the diff. Easier to order the serpent diff.
Old 06-26-2016, 12:23 PM   #3116
With the TLR lay down conversion kit, what rear hub ball stud hole are most using with the +3 alum hubs? Are they the same as the reg 22 alum hubs with the 2 inner most holes on each row being extra ones compared to the standard hubs? Set ups call for "A " ball stud hole. Is that middle hole front row of the hub, if your comparing it to the standard hub?
Any help would be greatly appreciated. Call me VERY confused.
I believe somewhere I remember reading Frank stating he would start with the middle hole in the back row.
Medicinal Coma is offline   Reply With Quote
Old 06-26-2016, 03:38 PM   #3117
Team Pink's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Medicinal Coma View Post
With the TLR lay down conversion kit, what rear hub ball stud hole are most using with the +3 alum hubs? AE they the same as the reg 22 alum hubs with the 2 inner most holes on each row being extra ones compared to the standard hubs? Set ups call for "A " ball stud hole. Is that middle hole front row of the hub of your comparing it to the standard hub?
Middle hole back row seems to be what most people are running with he laydown. This would be the equivalent to the "A" ballstud hole.
Team Losi Racing/ Spektrum/ Horizon Hobby/ JConcepts/ Hobby Star/ Schelle Racing
Team Pink is offline   Reply With Quote
Old 06-26-2016, 05:02 PM   #3118
Thank you for your help TP it is greatly appreciated.
Old 06-27-2016, 07:00 AM   #3119
Hasi's Avatar
Could you tell me what part number it has?
I'm searching for just the diff 'body' for a friend's 22 1.0 but I can't find it anywhere on the tlracing website. Seems like it won't be sold anymore?
Need a spare after some years.
Onroad: Tamiya TT-02, Tamiya TA-02SW, Xray T2'008
Offroad: Asso B5, Asso SC5M, Asso B64D, Tamiya Avante 2011 Re-Release
Trucks: Tamiya Mercedes SK 2638 6x6, Tamiya Mercedes 3553 8x4 heavy haulage, Tamiya Mercedes Arocs 8x4
Hasi is offline   Reply With Quote
Old 06-27-2016, 09:03 AM   #3120
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
http://www.losi.com/Products/Feature...rodId=LOSA2953
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
_AMA_
