    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 06-06-2016, 04:35 AM   #3046
SC10CHAMP's Avatar
Default Stock spur
Hi everyone. Was just wondering if there is a 72t hds compatible spur gear for the 22 3.0? I looked it up and the only low tooth spurs I could find were for the direct drive system. Help would be appreciated. Cheers.
SC10CHAMP is offline   Reply With Quote
Old 06-06-2016, 06:38 AM   #3047
Trader Rating: 36 (100%+)
I believe 76 tooth is the smallest spur gear possible with the HDS pads, 72 and lower i know you have to use the non-hds spurs and pads.
nitrousdave is offline   Reply With Quote
Old 06-06-2016, 11:48 AM   #3048
HBRob's Avatar
Trader Rating: 61 (100%+)
Send a message via Skype™ to HBRob
**Privateer** - Getting Out 11/12/16
TLR 22 3.0 | TLR 22T 2.0 | TLR 22-4
Fantom Racing | Hobbywing | Futaba
#ocrcarmy
HBRob is offline   Reply With Quote
Old 06-06-2016, 01:56 PM   #3049
SC10CHAMP's Avatar
Thanks nitrousdave. Appreciate the help. Cheers.
Go hard or go home
Old 06-07-2016, 10:56 AM   #3050
ryan432greening's Avatar
Is the kick shim mod universally beneficial or only when used in combination with the laydown conversion kit?
I'm driving outdoor on medium bite currently so the laydown conversion isn't on my short list until we go back indoors.
B-Main Racing
TLR 22 3.0, 22-4 2.0, 8ight-E 4.0, 8ight 4.0
GFRP M1
ryan432greening is offline   Reply With Quote
Old 06-07-2016, 11:04 AM   #3051
Mudcat981's Avatar
The kick shim mod is for HRC. You do not want to use this with outdoor tracks, carpet or indoor laydown conversions only.
Gene Hobbs - "Misplaced Texan"
TLR 22 3.0SR, TLR 22T 3.0, TLR 22 3.0 (Standard & Laydown)
TLR 22 2.0, TLR 22T 2.0, TLR 22-4 1.5
AIRTRONICS, HOBBYWING, ORION, SAVOX, TRINITY
LUNSFORD, JCONCEPTS, SCHELLE
Mudcat981 is offline   Reply With Quote
Old 06-07-2016, 11:30 AM   #3052
Roger that, I did the mod while installing a new bellcrank set, I will undo those changes with some spare parts I have.
B-Main Racing
GFRP M1
Old 06-07-2016, 06:11 PM   #3053
Jpdanger's Avatar
I use an AE 72t spur that I had lying around. The HDS pads will need a slight trim, but it works.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 06-08-2016, 09:40 AM   #3054
ta_man's Avatar
Trader Rating: 151 (100%+)
Or just use AE pads.
ta_man is offline   Reply With Quote
Old 06-08-2016, 05:30 PM   #3055
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i use the entire ae slipper...
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 06-08-2016, 05:44 PM   #3056
Trader Rating: 113 (100%+)
Does the losi laydown body fit with the exotek laydown box?
Breeze is offline   Reply With Quote
Old 06-08-2016, 09:47 PM   #3057
Yes it does. It has to sit a little bit further back to get the shaft in the pre cut hole. You also have to trim a little off the back for the arms not to rub
fantomdude is offline   Reply With Quote
Old 06-11-2016, 03:01 AM   #3058
So how good does this rocket handle out of the box on a medium grip dusty track? Im about to put mine together and was wondering if there are any mods I should do?
junior91 is offline   Reply With Quote
Old 06-11-2016, 07:11 AM   #3059
It's pretty damn good, I'm liking the 4-gear transmission outdoors for some more rear grip. Other than that, I went up one size on both front and rear pistons to soak up some bumps and am using low frequency springs.
Old 06-11-2016, 12:51 PM   #3060
HollywoodRC's Avatar
Originally Posted by fantomdude View Post
Exotek designed the tranny for the stock hubs. The diff is raised slightly for running at lower ride height. So My guess and from what I have seen in running It. The exotek would be closer to the TLR dirt laydown tranny rather then the one in the laydown kit. So you may see better performance from regular roll centers. Some one did post in a previous post that they e-mailed Exotek and they said that the +3 hubs would work with their tranny.
Ok, I got the Exotek all installed and decided not to modify the front kick plate and add the +3 rear hubs to move up the roll center 3mm. Now, the question is how low, with just the Exotek leydown tranny, can you make your ride height?
I understand using the TLR laydown kit the +3mm rear hubs and the front kick plate mod is needed to move the roll center up so you can run a lower ride height. So, I'm thinking that I can go down a few mms using the Exotek, but not sure. Any thoughts from you jeti masters out there?
HollywoodRC is offline   Reply With Quote
