    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 05-25-2016, 07:52 PM   #2941
https://www.amainhobbies.com/exotek-...xo1651/p498369
Just received mine today in the mail.
Rocket-RC also makes one. I believe his is 13g
https://m.facebook.com/rocket.rc.parts
Medicinal Coma is offline   Reply With Quote
Old 05-26-2016, 04:53 AM   #2942
Questions?? Side cover not fitting with direct drive
Hi guys
I have fitted the new TLR direct drive to my 3.0, and have noticed now that the standard side cover over the spur/pinion no longer fits, it fouls on the spur.
Im running the 72T spur.
Has anyone else found this or have I done something wrong with fitment??
masepaulmase is offline   Reply With Quote
Old 05-26-2016, 07:15 AM   #2943
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
The gear cover doesn't fit? Installing the direct drive should have no impact on that part. I'd go back and double check what you did.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 05-26-2016, 10:21 AM   #2944
Mudcat981's Avatar
Originally Posted by masepaulmase View Post
Hi guys
Did you remove the red spacer?
Gene Hobbs - "Misplaced Texan"
TLR 22 3.0SR, TLR 22T 3.0, TLR 22 3.0 (Standard & Laydown)
TLR 22 2.0, TLR 22T 2.0, TLR 22-4 1.5
AIRTRONICS, HOBBYWING, ORION, SAVOX, TRINITY
LUNSFORD, JCONCEPTS, SCHELLE
Mudcat981 is offline   Reply With Quote
Old 05-26-2016, 11:48 AM   #2945
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Hi guys
You don't use the red spacer when installing the direct drive.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 05-26-2016, 06:56 PM   #2946
It's the spacer I did the same thing and then double checked my work and took it out.
TLR 22 3.0 / DEX410V5
ddsmech1 is offline   Reply With Quote
Old 05-26-2016, 08:54 PM   #2947
steelers82's Avatar
Frank, I'm wondering if I can run your stock nats set up with the exotek lay down conversion or is it completely different geometry than the tlr one? and if so whats a good set up for the exotek lay down transmission? I run at ocrc and coyote hobbies...any help would be appreciated, thank you.
John 3:16 " For God so loved the world that he gave his one and only son,that whoever believes in him shall not perish but have eternal life"
steelers82 is offline   Reply With Quote
Old 05-26-2016, 10:05 PM   #2948
3srcracing's Avatar
Must have the worst luck, new laydown coming out? Right after I spent $170 on the laydown... Crap man haha.
A Main Hobbies | Protek R/C | Team Powers R/C | Cheater Racing
3srcracing is online now   Reply With Quote
Old 05-26-2016, 10:26 PM   #2949
Mudcat thanks a lot, no I refitted it, I didn't realise it wasn't required.
Thanks again.
Old 05-26-2016, 10:56 PM   #2950
Thanks Frank, appreciated.
Old 05-27-2016, 04:49 AM   #2951
STLNLST's Avatar
Trader Rating: 21 (100%+)
What lay down free you speaking of
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-27-2016, 05:27 AM   #2952
LOL I saw this on Facebook. I haven't even ran my laydown conversion yet (tomorrow). New conversion is a conversion for the conversion! Getting hard to keep up!!
3DRCRACER is offline   Reply With Quote
Old 05-27-2016, 06:20 AM   #2953
Woulvesbaine's Avatar
Which new laydown are you referring to?
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 05-27-2016, 06:27 AM   #2954
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
there is only one TLR laydown, the other is made by exotek
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 05-27-2016, 06:32 AM   #2955
Not a new conversion. It is a optional transmissiom case that does not have the diff raised. Allows you to run a higher ride height with the correct geometry. for lower traction surfaces and should allow the car to land better due to the extra travel of the suspension
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
