TLR 22 3.0 Race Kit Thread!
#2911
Frank
I saw on your stock nats setup that you mounted the kick shim under the block. Could you give some details on that? Does this mean you are putting the block then the kick shim then the bumper? I am guessing to raise the roll center?
#2913
I ran my exotek laydown this weekend for the first time and I loved it. It was on clay with slicks and all I did to my setup was change out tranny for the laydown and raise the front spindles 1mm. The car rotates better and I was able to run what were my normal "hero" laps times with a lot more consistency and with out having to push hard. The only con was the track fired up the AC with out adjusting moister and the track started drying out at the end of a run and then the car was loose but not undrivable. One of the local pros told me to raise the roll center in the rear and it would help with that so I will give that a try next race
#2917
not going to be on here much i just lost my dad to cancer iam just going to try and keep my mind on rc
#2919
Will 3.0 body fit 2.0?
#2921
http://www.rctech.net/forum/attachme...d-img_3690.jpg
What front camber block is that you are using? And why if you don't mind me asking.
Thank you……...
Thank you……...
#2925
Anybody have some 22 3.0 setup tips for Outback Raceway in Chico, CA? My boys might be running in the Rookie class for the JC Summer Indoor Nats.
I am especially interested in what is a good tire choice.
