    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 05-11-2016, 07:22 AM   #2806
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Davidka View Post
It's not actually Clay, most Midwest tracks are Triple sifted topsoil. It's been changing the past few years. It used to be unnecessary, then it provided a couple of 10th's.
It was super high grip when it was in the small room (you raced here back then, at the Spektrum race). Slicks, wheelies, it was like running on modeling clay.
That was a fun bull-ring
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 05-11-2016, 02:48 PM   #2807
Guch's Avatar
Default lay down body vs. stock 3.0 body
I see the lay down conversion uses a new body. Can someone clarify if a lay down body will fit a stock 3.0? Will a stock 3.0 body fit a lay down converted buggy? Comments on the details of why each body is different would be helpfull.
22 3.0,Orion R10/DPS 7.5,Orion 4600 shorty, Airtronics M12,Spektrum S6270
SCT410.3,RX8.2/Pro4 4600,XP DS1015,SMC 7200
If guns are ever outlawed, then I'll be an outlaw!
Guch is offline   Reply With Quote
Old 05-11-2016, 03:05 PM   #2808
Trader Rating: 14 (100%+)
Sorry if this has already been asked but it seems that the mip puck sytem has been discontinued. What do are you guys doing to lighten up that area other than cut gears.
Or what other puck system might work?
Josh Pease is offline   Reply With Quote
Old 05-11-2016, 03:36 PM   #2809
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
The stock body is cut for the stand up trans and motor plate. The laydown body is not cut in the back and includes the hole for the slipper. The stock body would probably fit the laydown but then the spur / motor is more exposed, the laydown body won't fit the std without some cutting.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 05-11-2016, 03:36 PM   #2810
Super Moderator
They are working on a 3.0 puck system.
Old 05-11-2016, 04:50 PM   #2811
Thanks Matt. I dropped the other brand to drive the losi got all the other stuff but couldn't get a puck system was kinda bummed
Old 05-11-2016, 05:04 PM   #2812
Kewlbug's Avatar
Trader Rating: 59 (100%+)
2.0 and 3.0 axles are the same, 2.0 pucks should work? Though I thought I saw MIP was working on a better system.
B rad
8ight 4.0 - 8ight-E 4.0 - TC7.1 - 22 2.0
Kewlbug is offline   Reply With Quote
Old 05-11-2016, 07:15 PM   #2813
2.0 pucks work with no problem.
TimmE is offline   Reply With Quote
Old 05-11-2016, 08:08 PM   #2814
Guch's Avatar
Default MIP
I just looked at MIP's website and the 2.0 system is still for sale. It is the shiny system. Is the shiny system the polished aluminum axles for stock racing or are the axles chromed steel for mod.?
Old 05-11-2016, 08:47 PM   #2815
thecman26's Avatar
Trader Rating: 98 (100%+)
The shiny system is for mod, the bi-metal is the lighter stock units.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 05-11-2016, 09:05 PM   #2816
I'd rather run mod but no one at our local track ever wants to run mod they all want to run stock and 98% run ae cars with everything you can do to them like the one I just ditched.
All the 2.0 aluminum puck stuff has been discontinued. Guess I'll wait until late the new system is out.
Thanks for the reply's everyone
Old 05-11-2016, 09:57 PM   #2817
Originally Posted by Frank Root View Post
22-24mm is the range I'd try to stay in. 21-23mm with HRC front and rear
Wow really that high? I've been running mine down at 17-18 mm still with lrc blocks and been quite happy with it. Have got racing this weekend so will lift it up and see how it goes...
rally stylz is offline   Reply With Quote
Old 05-12-2016, 12:06 AM   #2818
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Been running the 22 3.0 laydown on my local track here with some pretty good success. Our track is like OCRC, but it can get dusty and dry. I made a rear turnbuckle change tonight and really liked it for our current layout which has some step downs after a fast sweeper. Keeps the rear pretty planted. Really easy to drive and consistent.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 05-12-2016, 05:52 AM   #2819
Andrew Gray's Avatar
Which Yokomo green rear spring are you using? The big bore, yatabe, or yokomo "x"?
Retired & Washed Up. TLR Supporter For Life
Andrew Gray is offline   Reply With Quote
Old 05-12-2016, 06:02 AM   #2820
Things may be different with LRC, but running the HRC front and rear with ride height that low is no good. It was very unforgiving in that I had to land with both left and right tires at exactly the same time, or I'd upset the car and possibly tumble. I found that for the stock chassis on carpet, running HRC all around and getting the ride height up around 21 mm was the best. Maybe it was having the suspension geometry closer to what it was designed to be, I don't know. I imagine slamming it down to 17 mm really changes the geometry.
Callaway is offline   Reply With Quote
