    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 04-30-2016, 07:25 AM   #2701
RC10Nick's Avatar
Would anyone who has done the exo laydown conversion be willing to send me your drill template?
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 04-30-2016, 07:41 AM   #2702
Davidka's Avatar
Trader Rating: 75 (100%+)
With transmission configuration being a focal point lately, has anybody explored a stock-specific 2-gear transmission? Seems like it might be possible with the small spur gears we're running.
Old 04-30-2016, 12:26 PM   #2703
Super Moderator
I've tried laying out a 2 gear setup a couple times, couldn't figure out a way to make it work with useable gearing. Spur had to be small enough to miss the out drive/axle, which then took too large of a pinion to reach. If someone can work it out I'd sure like to see it.
I doubt if a belt drive is the solution because of hysteresis losses in the belt. Maybe chain drive like the old Dominator or whatever it was oval car, that ran pretty free? Seems like a long shot, just trying to think of any possibility.
Dave H is offline   Reply With Quote
Old 04-30-2016, 02:06 PM   #2704
Davidka's Avatar
There was the old Team Pit-stop chain drive. Oval guys liked it. Was very free on the top end, but had a shoddy diff.
Belt has extremely low loss under load but the distance needed between pulleys and diff pulley diameter causes another set of compromises. I've always wondered how well a Schumacher KF could be made to work.
Old 04-30-2016, 05:58 PM   #2705
gokarter64's Avatar
hey frank, do you know when we will see the TLR334037 +3 rear hubs that are in the laydown kit available for purchase separately? i am building mine over time and would like to use them with my exotek transmission
Cars: TLR 22 3.0 Mod, Mugen MBX7 ECO, TLR 22 3.0 Stock, TLR 22-4, TLR 22T 2.0
Electronics: Airtonics, Orion, LRP, Xpert, Maclan
Goodies: Exotek, Avid, Raw Speed, Jconcepts, MIP . Paint By: Double Deuce Designs
gokarter64 is offline   Reply With Quote
Old 04-30-2016, 09:08 PM   #2706
Jack302's Avatar
Trader Rating: 21 (100%+)
Does the 22 1.0 or 2.0 wheels fit the 3.0?
What about other buggy wheels?
Jack302 is offline   Reply With Quote
Old 04-30-2016, 09:23 PM   #2707
ryan432greening's Avatar
They will fit if you install the 1.0 and 2.0 front axles. They have the hex size to fit the older wheels. This opens up the possibility to use aftermarket wheels like DE
B-Main Racing
TLR 22 3.0, 22-4 2.0, 8ight-E 4.0, 8ight 4.0
GFRP M1
ryan432greening is offline   Reply With Quote
Old 04-30-2016, 09:23 PM   #2708
And as for the rear, yes they are the same.
B-Main Racing
GFRP M1
Old 04-30-2016, 09:28 PM   #2709
gokarter64's Avatar
No, no, and no
The 3.0 wheels are just like the 2.0 wheels except for that they have 12mm hexes. Other manufacturers wheels will fit but the offset will be wrong and will make the car too wide on the front end
Old 05-01-2016, 08:21 PM   #2710
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
They shipped with the kits, not sure if we ran out already or not. I don't have any more info regarding dates than what is listed on the site.
Originally Posted by Kewlbug View Post
Frank-
Is the laydown body available soon?
or is it the same as the 330007 ultra lite..
Not the same as TLR330007.
Originally Posted by solly View Post
I got my laydown conversion yesterday and installed it, and ran it last night on the turf. Its a very nice kit, everything went together smoothly. The only issue i had was the screws to hold the battery strap were longer than what was listed in the instructions. The sheet said 6mm and my kit had 10mm screws so they stick out and are bit ugly but i will dremel them down to the correct height.
The car ran good with the little practice time that I got and i made some minor changes throughout the night. Im very happy with this kit!
I'm willing to bet you have 2 of the M2.5 x 6mm FH screws holding the aluminum tower mount to the back of your tranny case.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 05-01-2016, 10:08 PM   #2711
thecman26's Avatar
Trader Rating: 99 (100%+)
Well, I won one of these bad boys at a raffle this weekend. So it looks like I have some work reading this entire thread! I have been racing B5M's for last 2 years. I am really impressed with how this buggy looks on the track! Ya have to admit that body just looks sick! Looks like I will have to replace my tire fleet though as the offsets are way different, if there could only be an industry standard on wheel offsets it would make this a LOT easier! But that's neither here nor there. *subscribed*!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 05-01-2016, 10:44 PM   #2712
vr6cj's Avatar
Trader Rating: 124 (100%+)
Its just the front. U can still use other fronts but might be too wide legally. Rears same unless you got some swallow wheels on the outside. Then ive used a cone washer to make up the gap for the nut. I have way too many rear tires to just not use them for this car.
vr6cj is offline   Reply With Quote
Old 05-01-2016, 10:46 PM   #2713
thecman26's Avatar
Thanks!
Old 05-02-2016, 01:55 AM   #2714
Hi everybody I'm picking up a 3.0 and was wondering what is good to do setup wise right out of the box for OCRC. For example I've seen the +1mm on rear axle and stuff like that I just wanted to know what stuff is a "requirement".... Thank you👍🏼
Rckid19 is offline   Reply With Quote
Old 05-02-2016, 04:16 AM   #2715
BigPinion's Avatar
Trader Rating: 19 (100%+)
I'm loving this new buggy and I have only raced it twice on our local turf track. I'm getting ready to put an indoor clay setup on it and get a second kit to build a lay-down car for turf this winter. I love the look of the new body and a joy to paint (much easier than the 2.0 cab fwd bodies )
Pro-Line Racing Team Driver / Diehard-RC / XRAY
XRAY XB-2c '17 / XB4 '17
Diehard RC indoor Carpet Off-Road www.facebook.com/DieHardRC
BigPinion is offline   Reply With Quote
