    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 04-25-2016, 11:19 AM   #2671
Mudcat981's Avatar
Originally Posted by Brandon1977 View Post
I used to have a 22 2.0 that I ran a Tekin RS with a 10.5t system in. Is that a good system to run in the 3.0? I've been out of racing for about a year now
Nothing as far as ESC and Motor choice has changed between the 2.0 and 3.0. Except that the 3.0 can handle the power better.
Gene Hobbs - "Misplaced Texan"
TLR 22 3.0SR, TLR 22T 3.0, TLR 22 3.0 (Standard & Laydown)
TLR 22 2.0, TLR 22T 2.0, TLR 22-4 1.5
AIRTRONICS, HOBBYWING, ORION, SAVOX, TRINITY
LUNSFORD, JCONCEPTS, SCHELLE
Mudcat981 is offline   Reply With Quote
Old 04-25-2016, 11:39 AM   #2672
Casper's Avatar
Trader Rating: 33 (100%+)
I have noticed with the confidence I have with the 3.0 putting power down to the ground I have wanted more power with the 3.0. Not because it was needed but because I have confidence to use it!
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 04-25-2016, 04:15 PM   #2673
HBRob's Avatar
Trader Rating: 61 (100%+)
Send a message via Skype™ to HBRob
Received my Exotek 3 gear laydown setup yesterday and did a very quick, easy install. Other than drilling and countersinking 3 holes went together very easily. Case is a piece of art and is super free once installed.
Giving it a day of setup testing tomorrow. Will report back.
**Privateer** - Getting Out 11/12/16
TLR 22 3.0 | TLR 22T 2.0 | TLR 22-4
Fantom Racing | Hobbywing | Futaba
#ocrcarmy
HBRob is offline   Reply With Quote
Old 04-25-2016, 10:24 PM   #2674
gokarter64's Avatar
im really interested in giving the case a try, i may have to order one in a day or two. i wish they could make a non laydown version for us clay guys, i loved the mip box on the b5m and really wish the 3.0 had something similar, nothing beats aluminum or machined delrin for accurate and free flowing transmission cases
Cars: TLR 22 3.0 Mod, Mugen MBX7 ECO, TLR 22 3.0 Stock, TLR 22-4, TLR 22T 2.0
Electronics: Airtonics, Orion, LRP, Xpert, Maclan
Goodies: Exotek, Avid, Raw Speed, Jconcepts, MIP . Paint By: Double Deuce Designs
gokarter64 is offline   Reply With Quote
Old 04-26-2016, 10:58 AM   #2675
vito's Avatar
i saw a fb post the lay down kits are on there way
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 04-26-2016, 05:36 PM   #2676
Trader Rating: 131 (100%+)
hey, just curious on how your testing was today. I installed mine yesterday and haven't had the chance to run laps
skyline1015 is offline   Reply With Quote
Old 04-26-2016, 06:41 PM   #2677
I am very curious as well. Also will you be running it in 17.5 or mod?
cjcoffroad is offline   Reply With Quote
Old 04-26-2016, 09:41 PM   #2678
tsair's Avatar
Are you guys getting the laydown for carpet or are some of you running it on high-grip clay?
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 04-27-2016, 04:05 AM   #2679
Hi, I have a question for Frank about his Reedy race setup. Is the sheet correct in regards to the oils used in front and rear shocks?
Thanks, Warren.
71WOK is offline   Reply With Quote
Old 04-27-2016, 06:24 AM   #2680
HBRob's Avatar
Default Exotek
So I was pretty happy where this ended up and I'm going to leave it in. Changes from my stock setup were lowering the car 1mm all the way around, went up 1 spring in the front, and removed the outside stud spacers on the Hubs in the rear. Also slowed down steering speed a bit to even out the response.
Running this with 17.5 on ocrc clay - medium high bite.
As expected it had a ton of steering and rear became a bit loose due to the weight transfer to the front. Changes above got it back to where I like it. Was able to match my fast lap time from a race night in practice so should be dialed under normal race conditions. Track was a bit loose and dusty (lots of 8th scales running yesterday).
As stated earlier build was great and case quality was amazing.
Old 04-27-2016, 06:38 AM   #2681
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Thanks, Warren.
Don't forget that he's using 1.7 Pistons in the rear and 1.6 up front. It may look odd to have heavier oil in the rear but you need to look at the whole setup.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-27-2016, 09:16 AM   #2682
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Thanks, Warren.
Yes, it is correct.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 04-27-2016, 11:05 AM   #2683
gokarter64's Avatar
i have my exotek transmission on the way, i emailed them about he possibility of an aluminum one for the dirt guys and he said if people showed enough interest they would do it.
so if you guys like the idea feel free to email exotek about it.
i used the mip box on a b5m and was very impressed by how freely the transmission rolled. for stock class making your car light really isn't the big deal, its all about reducing rolling resistance and rotating mass as much as possible as well as cooling your motor so you can throw some crazy gearing on it.
i also finally got the time to go racing, its been over a month since i last raced and i was a little rusty. but i ran my 3.0 in stock for the first time and i am very impressed with the car so far. i am running the dakotah pend reedy race setup with some spring and oil changes and so far i am really enjoying the way the car feels currently.
the yz2 body fits pretty good on there, im liking how it feels on the track as well
Old 04-27-2016, 11:30 AM   #2684
TLRacing
Frank Root's Avatar
TLR already has "dirt" diff height gear boxes on order and in production. This will be an add-on part to the laydown conversion to have the diff as a 'standard height'. They won't be here for a while, but it is definitely in the works so don't sweat it
Old 04-27-2016, 03:09 PM   #2685
My laydown conversion shipped from Horizon today, cant wait!
solly is offline   Reply With Quote
