    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 04-21-2016, 05:32 AM   #2656
Goofy0319's Avatar
Trader Rating: 15 (100%+)
Is there any exploded view or anything that shows the installation of the 1mm option spacer for the rear axles?
www. facebook.com/fairviewrccars
Proline Pro-2 / TLR 22 3.0 / TLR 22-4 / Traxxas Son Uva Digger / Traxxas Grave Digger 30th Anniversary / Axial CPE Barbarian / Tamiya Clodbuster / AARMA Mojave
Goofy0319 is offline   Reply With Quote
Old 04-21-2016, 06:53 AM   #2657
xyzracer's Avatar
I'm not running it but I'm pretty sure you just slip it on the axle before sliding the axle into the hub bearings
xyzracer is offline   Reply With Quote
Old 04-21-2016, 07:11 AM   #2658
Here is a link to the pdf. It's on page 22, step B1. The spacer part # is TLR232008.
http://www.tlracing.com/ProdInfo/Fil...002_manual.pdf
This manual is the manual for the 2.0, which showed the optional spacer.
Wanderer77 is offline   Reply With Quote
Old 04-21-2016, 12:32 PM   #2659
HollywoodRC's Avatar
Does anyone know what the part number for the 67mm shaft is off hand? I had a dog bone pop out last week which never happened before.
HollywoodRC is online now   Reply With Quote
Old 04-21-2016, 12:46 PM   #2660
...correct answer below...
Old 04-21-2016, 12:49 PM   #2661
Well alrighty then....lol
Old 04-21-2016, 12:59 PM   #2662
Send a message via AIM to 4wd Racer
Originally Posted by Wanderer77 View Post
...its a running part change, no new part number...
Incorrect, part running change and kit running change are two different things.
In this case, the 67mm driveshaft is an new item, & will have it's own unique part number.
TLR232052 67mm driveshaft (for the 22 3.0 M)
TLR232008 66mm driveshaft (for the 22 2.0 R/M)
Team Losi Racing 22 3.0, 22.4, 22T 2.0, w/ Spektrum DX4R Radio & Servos, HobbyWing ESC & Motors, Team Orion Batteries & Chargers, LRP power supply. (Mod Off-Road Nationals Finalist)
Last edited by 4wd Racer; 04-21-2016 at 05:23 PM. Reason: Added both part numbers reference for both cars
4wd Racer is offline   Reply With Quote
Old 04-21-2016, 01:57 PM   #2663
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
http://www.horizonhobby.com/cva-driv...2-30-tlr232052
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-21-2016, 04:42 PM   #2664
Trader Rating: 8 (90%+)
Big crash?
juicy74 is offline   Reply With Quote
Old 04-21-2016, 06:22 PM   #2665
Stobert2012's Avatar
I know this question has probably been asked a lot... But, what front wheels are people using for turf/carpet? Or, are there wider turf tires for the stock front wheels?
Sponsor: US Army & Myself
Stobert2012 is offline   Reply With Quote
Old 04-21-2016, 07:20 PM   #2666
Schumacher cut stagger low profile on TLR rim. I cut the rim down to the width of the tire by cutting off the inner lip. Those tires are meant to be run without inserts, but one of the local fast guys cut down open cell inserts and put them in. He said it made the front end more consistent.
Callaway is offline   Reply With Quote
Old 04-21-2016, 08:39 PM   #2667
Thanks, bro, for the info.
Old 04-21-2016, 11:44 PM   #2668
Originally Posted by juicy74 View Post
Big crash?
Big Crash into the back of my buggy! DANG!
Old 04-22-2016, 06:03 AM   #2669
Goofy0319's Avatar
Thanks for the help!
Old 04-24-2016, 05:15 PM   #2670
Trader Rating: 14 (100%+)
Default Losi 22 3.0 system
I used to have a 22 2.0 that I ran a Tekin RS with a 10.5t system in. Is that a good system to run in the 3.0? I've been out of racing for about a year now
Brandon1977 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
