    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 11-12-2015, 07:18 AM   #211
RC10Nick's Avatar
Thanks for the vids guys! I was thinking about picking up a B5M but the 22 3.0 looks like it has all the right parts in all the right places as far as I'm concerned.
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 11-12-2015, 07:25 AM   #212
Nick,
I know your history with mid motor and what your style is and I believe that this is the car you should get. I am very much a mechanical design oriented person and from studying what Losi does vs the others, I prefer their suspension geometry. At least I did on the 2.0. I haven't seen a 3.0 yet.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is online now   Reply With Quote
Old 11-12-2015, 07:36 AM   #213
JourneyMan's Avatar
Trader Rating: 89 (100%+)
So Frank, what upgrades from our 2.0's should we keep and carry over? I want to make sure I pull all aluminum upgrades off of my 2.0 so that I don't end up re-buying them.
For instance:
Aluminum Front Camber
Aluminum Servo Mounts
Aluminum battery holder
STD Rear Alum Hex
Things I assume I will be parting with:
Rear Aluminum MM Camber Block
Rocket RC brass anti-squat block
30deg Aluminum front pivot??
JC front axle conversion
Thanks to - Jconcepts | Team Trinity/Revtech | Kal-gard
JourneyMan is offline   Reply With Quote
Old 11-12-2015, 08:09 AM   #214
Davidka's Avatar
Trader Rating: 75 (100%+)
For instance:
I think your list will look something like this:
Things you can keep:
STD Rear Alum Hex
JC front axle conversion (to use your old 10mm hex wheels)
Things you lose:
Aluminum battery holder (?)
Aluminum Servo Mounts (Frank confirmed the old ones don't work with the new car).
Old 11-12-2015, 08:11 AM   #215
Mudcat981's Avatar
For instance:
STD Rear Alum Hex
The servo mounts - no, they are different.
The Battery mount don't think so. whole new battery brace system.
Suggest you review the video on TLR. It explains the new updates and what is different.
Gene Hobbs - "Misplaced Texan"
TLR 22 3.0SR, TLR 22T 3.0, TLR 22 3.0 (Standard & Laydown)
TLR 22 2.0, TLR 22T 2.0, TLR 22-4 1.5
AIRTRONICS, HOBBYWING, ORION, SAVOX, TRINITY
LUNSFORD, JCONCEPTS, SCHELLE
Mudcat981 is offline   Reply With Quote
Old 11-12-2015, 08:14 AM   #216
For instance:
STD Rear Alum Hex
Frank did post a view pages back, whats needed to convert a 2.0 to an 3.0, so you can see, which parts are interchangeable...
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 11-12-2015, 08:14 AM   #217
STD Rear Alum Hex
Things you lose:
Davidka, you are correct Sir.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 11-12-2015, 08:40 AM   #218
JourneyMan's Avatar
Thank you for the quick answer guys!
Old 11-12-2015, 10:57 AM   #219
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Matt Trimmings View Post
I believe there was a IFMAR proposed rule change that stated all wheels had to be 12mm hex.
Correct.
That was the goal
For instance:
STD Rear Alum Hex
Keep:
STD Rear Alum Hex
Lose:
In between:
JC front axle conversion - You can use this as long as you can get the 10mm hex wheels, which will run out sometime next year.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 11-12-2015, 12:23 PM   #220
Trader Rating: 44 (100%+)
can't wait to get another losi this buggy looks awesome
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 11-12-2015, 02:02 PM   #221
losicorey's Avatar
Are the rear hubs the same as the 2.0?
losicorey is offline   Reply With Quote
Old 11-12-2015, 02:29 PM   #222
Casper's Avatar
Trader Rating: 33 (100%+)
The looked the same to me.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 11-12-2015, 02:30 PM   #223
TLRacing
Frank Root's Avatar
Yes
Old 11-12-2015, 02:43 PM   #224
tsair's Avatar
I've been thinking this over (ever since Nov. 5, lol), and decided the right thing to do is get both!
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 11-12-2015, 03:39 PM   #225
Trader Rating: 309 (100%+)
You can't do that, you must choose a side. TLR or AE army. Lol
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
