    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 02-25-2016, 02:30 PM   #2176
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by RedBMaster View Post
Yes, it obviously works on the 3.0. The point is the Exotek rack was designed and tested with the original 2.0 spindles. When TLR released their steering rack they updated the spindles to what is on the 3.0 and as you noticed the 22 SCT 2.0 and any other TLR 22 that comes with the TLR steering rack.
I think they better question to ask is why spend $35 on an old part when proper setup will gain you more, and other racers will readily be able to replicate your setup. Nothing like someone asking you why your car is so fast and your like, well you have to spend an extra $35 on top of an already top of the line vehicle to make it fast. Its misleading and unnecessary. This isn't the 2.0!
Hi, Correction on the confusion on the steering rack- the new 1580 Steer Rack set is drop in fit for the 3.0 (and drop in for converting the TLR nylon steering rack set as well). It is the same geometry as the TLR steer rack set;
http://www.exotekracing.com/22-3-0-s...2-0-22sct-2-0/
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 02-25-2016, 02:51 PM   #2177
Trader Rating: 21 (100%+)
Originally Posted by KBRacing View Post
Sorry but where ..... ??
The neck of the ball stud. If you add a 1mm spacer then the ball cup will be at the same height as a standard. Without it the ball cup will be 1mm lower
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 02-25-2016, 02:52 PM   #2178
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Its the silver-ish ball stud on the steering rack that has the tie rod that connects to the spindle.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 02-25-2016, 03:23 PM   #2179
KBRacing's Avatar
Ok, Thanks.......
Team
KBracing
Konrad Berger
Denmark
KBRacing is offline   Reply With Quote
Old 02-25-2016, 04:24 PM   #2180
Orion_2kTC's Avatar
Originally Posted by Frank Root View Post
The drastic weight reductions help make the last 5% of improvement to maximize performance. If the first 95% is not yet covered, then no need to go after the last 5%, unless you have the money and want to .... I love titanium
Well yeah, but you've been racing constantly for YEARS Frank! Lol
Orion_2kTC is offline   Reply With Quote
Old 02-26-2016, 02:02 PM   #2181
RedBMaster's Avatar
Oh nice!
The OP mentioned the v2 mount which is clearly from the 2.0, and they also mentioned "improved" ackerman. So, not what he was talking about, but good to know there is some bling out there for those who want it! Still, not a effective tuning aid.
Follow, race proven, Prolix RC on facebook: https://www.facebook.com/ProlixRC/
RedBMaster is offline   Reply With Quote
Old 02-27-2016, 12:43 PM   #2182
RedBMaster - My bad, I was mistaken. I digress. Thanks for clearing all that up!
Here's my car. I will post pics of the completed build later or tomorrow. It's complete now but I'm not around to take some updated pics. Lots of upgrades. Will run mod buggy (7.5t) on med-high bite clay, carpet, and astro.
lyons238 is offline   Reply With Quote
Old 02-27-2016, 03:24 PM   #2183
XXXDad's Avatar
Trader Rating: 195 (100%+)
All you need is a 24K Trinity
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 02-27-2016, 03:31 PM   #2184
true, that would match better, do you know if the 24k is any better of a motor?
Old 02-27-2016, 07:48 PM   #2185
BRSracing's Avatar
Trader Rating: 53 (100%+)
Really like the color there.... is it more yellow or gold? hard to tell from the picture,
BRSracing is offline   Reply With Quote
Old 02-27-2016, 07:59 PM   #2186
its more yellow but it changes in different light. in daylight it looks sort of goldish but you can tell its not gold. then in a darker room with unnatural lighting it looks more like a yellow/gold anodize. its reallt a cross. but thank you man i took a lot of time to piece everything together. i took my time building this kit as i am a perfetionist. i will post final pictures when i get the chance its done now just finishing a few things after some testing.
Old 02-27-2016, 08:01 PM   #2187
BRSracing's Avatar
it looks great, mine has been my favorite build
Old 02-27-2016, 08:04 PM   #2188
thank you! i think the colors go well, especially with the TLR tan the yellow matches. I dont like when people put the blue nuts and what not. I don't think blue anodized fits these cars well. I like black, orange, yellow, gray ,etc. i also painted the body purple, so it matches good with the d4 motor and the yellow, since purple and yellow are complementary colors. Though I will be getting the JC Finisher body and doing a better paint job.
this build was my favorite also besides a few gripes:
- front and rear arm bind - but id rather a tad tight than loose
- alum front pivot block bind with the set screws
- front spindle/caster one side isnt recessed so is easily stripped because the king pin can not be screwed all the way in
and i think thats a bout it?
but yeah its been awesome, i cant wait to dial this thing with the mods that I have chosen.
Old 02-27-2016, 09:22 PM   #2189
Trader Rating: 8 (90%+)
Damn I would love a showroom build like that but I run on an outdoor track and the cars get pretty beat up
juicy74 is offline   Reply With Quote
Old 02-27-2016, 11:16 PM   #2190
yeah i hear you. i run on mostly indoor clay, carpet, and outdoor astro so i can build a shelf queen and race it without too much worry.
