    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 02-17-2016, 08:38 PM   #2071
bigbenmbx7t's Avatar
I'm having a lot of front end push problems on carpet with my 3.0. I'm running the stock springs with 45wt in the front 40w in the rear. Basically box setup with the rear shocks at the outside hole on the rear a-arms and the fronts in the stock position. I've tried moving them around but the best has so far has been there. I took the wing down a line so I'd have a little less drag hoping to keep more weight on the front. I'm installing my gear diff this week for Saturday plan on running the Diff at 5k. Slipper isn't crazy tight. Proline wedges with cut down wheels up front and pin points in that back. I'm open to any suggestions if someone else has had the same issues and found a setup fix. Thanks!
bigbenmbx7t is offline   Reply With Quote
Old 02-17-2016, 09:58 PM   #2072
Jpdanger's Avatar
On or off power push? If it's an off power push, make changes to the front of the car. On power push, make changes to the rear of the car. Judging by the 45wt oil, I guess and say it's an off power push.
Petitrc has several carpet setups and after looking at those you're way too heavy in the oil. Take a look at the setups and see if any of those help you.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 02-17-2016, 10:14 PM   #2073
It's all on power, under hard breaking its pushy in the hairpins but that's just me trying to rush corners. I saw some of their setups I'll try one. Thanks.
Old 02-17-2016, 10:37 PM   #2074
klowne's Avatar
I am curious as to what would be suggested for the typical spare parts for one to keep handy in the box for race day. Any list or hints would be greatly appreciated.
klowne is offline   Reply With Quote
Old 02-18-2016, 12:00 AM   #2075
Default Ae guy
I'm an ae guy and was just wondering how people really feel about this car and if it's worth switching all wheels and parts to a TLR I don't want to be dissapointed. Thanks guys
Rckid19 is offline   Reply With Quote
Old 02-18-2016, 12:36 AM   #2076
RC10B4_Mafco's Avatar
Trader Rating: 15 (100%+)
Send a message via MSN to RC10B4_Mafco
I have a 22 2.0 and I also run those proline carpet tyres (but on high grip, dry astroturf) and have an on-power push problem. I have plenty of off-power steering. I have decreased front droop, stiffened up the rear and many other things, all with no success. I have a funny feeling the problem is the proline front tyres. They are a very hard compound, therefore allowing less bite into the carpet/astroturf and hence taking away steering. But off-power steering is not a problem because you have more weight over the front end, allowing the front tyres to bite harder. I am going to try some schumacher staggered ribs probably within the next week and I'll report back.
RC10B4_Mafco is offline   Reply With Quote
Old 02-18-2016, 12:56 AM   #2077
PIHGUAM1's Avatar
Not that I have broken anything yet, but suggested spares would be arms, rear shock tower and rear camber mount. Oh, tires and batteries because you just wont want to stop driving it.
PIHGUAM1 is offline   Reply With Quote
Old 02-18-2016, 05:01 AM   #2078
Flip boy's Avatar
It's really good out of the box with no hop ups, comes with the adjustability that you have pay extra for with your associated. Not every car will suit your driving style but if your curious then should indulge
Flip boy is offline   Reply With Quote
Old 02-18-2016, 05:36 AM   #2079
tom yfz's Avatar
Trader Rating: 26 (100%+)
This is my best turf set up to date.
I run the Pro Line carpet tires also.
The springs are Associated, and the front stroke is 21.5mm.
I haven't measured the rear stroke yet, will do that tonight.
Good luck
tom yfz is offline   Reply With Quote
Old 02-18-2016, 08:12 AM   #2080
slakr's Avatar
Trader Rating: 28 (100%+)
Originally Posted by MantisWorx View Post
the 2wd version uses plastic main gear the 4wd version uses aluminum. that is the only difference.I went with the srx4 (aluminum version) because it for sure has the updated o'rings which do not leak, the older SRX2 difs leaked really bad. I am sure they updated both but if for some reason you end up with an older stock SRX2 diff, it will leak. the new O rings are clear. i started with 2 gears and 12k and it is perfect on high bite /slicks track. Sven had 10k in his the other night and felt that it was a bit too low. i was told to start with 15k but only had 12 on hand.
Just received the 2WD gear diff from Desoto... included the black O'Ring
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 02-18-2016, 08:43 AM   #2081
I was far from disappointed.. Coming from a former AE guy.
I just wish I could get to the track more often to drive this beast!
Rabidtrout is offline   Reply With Quote
Old 02-18-2016, 09:09 AM   #2082
Davidka's Avatar
Trader Rating: 75 (100%+)
Depends on your expectations. I don't think anybody would honestly that the 3.0 vastly outperforms the B5m because it doesn't, so if you're hoping for a car to get you from the middle of the field to the front, you may be disappointed. If you're looking to try something new and want a very durable car that runs well and doesn't need any hop-ups, maybe not.
You can use all of your B5's rear wheels (might need to ream the axle hole slightly) but you'll need new fronts.
Old 02-18-2016, 10:02 AM   #2083
Default Rear hubs - Aluminum v. Plastic
I came across this tonight and wanted to share...
I had been running the aluminum rear hubs w/ 3mm of spacers. I switched back to the stock rear hubs and immediately noticed some rub on the ball cup. After measuring the height of the hubs I found out the stock hubs are 1mm taller. Going down to 2mm of spacers did the trick - you might want to measure your own hubs if you're switching between the two.
toddmanley is offline   Reply With Quote
Old 02-18-2016, 11:35 AM   #2084
Mudcat981's Avatar
Good to know.
Gene Hobbs - "Misplaced Texan"
TLR 22 3.0SR, TLR 22T 3.0, TLR 22 3.0 (Standard & Laydown)
TLR 22 2.0, TLR 22T 2.0, TLR 22-4 1.5
AIRTRONICS, HOBBYWING, ORION, SAVOX, TRINITY
LUNSFORD, JCONCEPTS, SCHELLE
Mudcat981 is offline   Reply With Quote
Old 02-18-2016, 02:36 PM   #2085
The offset is completely different, isn't it?
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
