    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 02-15-2016, 05:46 PM   #2041
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by MNiceGuy View Post
For those of you running a slipper eliminator, how does that affect the set up of the ball diff? I'm fairly new at this and of the mindset that the slipper should let go at some point before the diff begins to bark. With no forgiveness at the spur, how do you keep the diff from barking?
Also, for a very high traction scenario (i.e. soft pins on carpet), is it more worthwhile to switch to gear diff?
You NEVER want the ball diff to slip, and with stock you should have no problem keeping it tight enough to not slip.
The Serpent ball diff is MONEY! remove 2 gears and run 10-15 oil in it.
The LOSI dif also works well with 2 gears removed and 4k but i have yet to find an O ring to stop it from leaking.
MantisWorx is offline   Reply With Quote
Old 02-15-2016, 06:02 PM   #2042
drepus's Avatar
Originally Posted by nexxus View Post
My 22 is giving me no joy. Kit set up besides the 4 gear transmission to try and get some more grip. Car is very unsettled off jumps and tends to bounce around a lot, and finds every rut on the track, struggles between on power oversteer and off power understeer, I think I've placed dead last every time I've run it
Outdoor clay track low-medium grip, running rebar rears and vektor fronts. Fastest lap is 2-3 seconds down on the fast guys, Tekin RS Spec esc and 17.5 motor.
Nexxus, not sure if you still need help but I noticed you where running vektor fronts. I found these to be very aggressive sometimes and they may be leading to your on power oversteer. Try some ribs to smooth out the front end and make the car more stable for you.
Dave Henry
TLR/Losi Team Driver,Team Horizon,Spektrum,Dynamite,JR,Nitrotane,AKA,CRC,Pinnacle Hobby, racing since '86 (at least trying!)
drepus???? it's "superd" backwards since it was taken!
drepus is offline   Reply With Quote
Old 02-15-2016, 06:05 PM   #2043
cokemaster's Avatar
Trader Rating: 18 (100%+)
Default Serpent gear diff
Just following up Marcus with the Serpent gear diff. Both SER500485 and SER500192 will fit the car. I have run the car without shims, but strongly recommend shimming. As seen from the pictures the difference in width is 1.3mm, so you will need a set of 10x12x0.2mm or 10x14x0.2mm shims.
Fleet:TLR 22 3.0, XB4 16, Mugen MBX7RE
ESC: Viper, Tekin, Airtronics/Sanwa
Motor: Novak, Tekin, Trinity, Scorpion
Radio: Airtronics M12
cokemaster is offline   Reply With Quote
Old 02-15-2016, 08:02 PM   #2044
Mudcat981's Avatar
Default 2.2 vs 2.4 Tire & Wheels
Got my 22 3.0 down to stock weight. But was playing with tires and wheels and wanted to show the weight difference between the 2.2 and 2.4/
TLR Wheels & Dirt Webs on 2.2 = 1512gms
TLR Wheels & Electrons on 2.4 = 1486gms
Gene Hobbs - "Misplaced Texan"
TLR 22 3.0SR, TLR 22T 3.0, TLR 22 3.0 (Standard & Laydown)
TLR 22 2.0, TLR 22T 2.0, TLR 22-4 1.5
AIRTRONICS, HOBBYWING, ORION, SAVOX, TRINITY
LUNSFORD, JCONCEPTS, SCHELLE
Mudcat981 is offline   Reply With Quote
Old 02-16-2016, 07:24 AM   #2045
Do you have any specific brand/part number for the shims?
If your not first your last! Shake N bake!
FPMX772 is offline   Reply With Quote
Old 02-16-2016, 07:31 AM   #2046
MNiceGuy's Avatar
Great info!
Is there one diff preferred over the other? I'm at work now so can't look in-depth at both. At a glance, it looks like on is slightly more expensive and has different gears.
For those that are using this diff, what is the general starting point? 2-gears and 7K I think I saw mentioned earlier. Is that about right?
22 3.0 Laydown | 22T 2.0 | 22T 3.0 | 22-4 2.0 | XXX-T MF1 | XX4
MNiceGuy is offline   Reply With Quote
Old 02-16-2016, 08:29 AM   #2047
MantisWorx's Avatar
Great info!
the 2wd version uses plastic main gear the 4wd version uses aluminum. that is the only difference.I went with the srx4 (aluminum version) because it for sure has the updated o'rings which do not leak, the older SRX2 difs leaked really bad. I am sure they updated both but if for some reason you end up with an older stock SRX2 diff, it will leak. the new O rings are clear. i started with 2 gears and 12k and it is perfect on high bite /slicks track. Sven had 10k in his the other night and felt that it was a bit too low. i was told to start with 15k but only had 12 on hand.
Old 02-16-2016, 08:49 AM   #2048
cokemaster's Avatar
Not really. Just search for 10x12 shims at your favorite hobby shop. I would get the 0.2mm thought.
Old 02-16-2016, 09:40 AM   #2049
MNiceGuy's Avatar
Good to know. Really appreciate the info!
One more follow up:
Are there any other considerations to be made other than some shimming as mentioned above? Other than that is it a direct drop-in? The Serpent outdrives are compatible?
Old 02-16-2016, 10:33 AM   #2050
Trader Rating: 137 (100%+)
I always use Kyosho shims....
KYO96647 Kyosho 10x12mm Shim Set (0.1mm/0.2mm) (8) (ZX-5)
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 02-16-2016, 10:38 AM   #2051
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by ogmudbum View Post
Looks good!
Originally Posted by BRSracing View Post
Frank,
Does TLR have any plans to make smaller spur gears for the stock racers?
We have the 70T available now. The 76 is the smallest we can make to work with HDS pads. Something else might be in the works
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 02-16-2016, 10:44 AM   #2052
MantisWorx's Avatar
One more follow up:
Direct drop in just be prepared to go faster!
Old 02-16-2016, 12:55 PM   #2053
skrichter's Avatar
Send a message via AIM to skrichter
Frank - Can we get the Rumble setup from you or Dustin? I think small track racers would appreciate it!
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 02-16-2016, 01:30 PM   #2054
TLRacing
Frank Root's Avatar
Only if your small track has crazy/abrassive traction
Same as Dustin's Reedy Setup, up 2.5wt front oil and one spring stiffer.
Old 02-16-2016, 03:20 PM   #2055
Flip boy's Avatar
Thumbs up Rumble in the Rockies
Haha it was'nt abrasive till Sunday, you were a beast too
Flip boy is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
