    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 02-10-2016, 07:44 AM   #1981
Trader Rating: 23 (100%+)
Originally Posted by Callaway View Post
Dirt Webs, Ions, and Electrons are the go-to around here. Or so I'm told.
Basically, I just wonder if 2.4" rear and 2.2" up front will be really unstable or if it won't be that big of a deal.
Shouldn't be a big deal, front and rear are fairly independent.
Sponsors- Team Losi Racing, Pro-Line, Orion, Nitrotane, Horizon Hobbies, Avid
electrickid is offline   Reply With Quote
Old 02-10-2016, 07:56 AM   #1982
Mudcat981's Avatar
Originally Posted by nttdemented View Post
Can anyone please measure their front spring lengths for me? I bought a set for a different application and I'm not sure of their length.
44 mm
Gene Hobbs - "Misplaced Texan"
TLR 22 3.0SR, TLR 22T 3.0, TLR 22 3.0 (Standard & Laydown)
TLR 22 2.0, TLR 22T 2.0, TLR 22-4 1.5
AIRTRONICS, HOBBYWING, ORION, SAVOX, TRINITY
LUNSFORD, JCONCEPTS, SCHELLE
Mudcat981 is offline   Reply With Quote
Old 02-10-2016, 08:20 AM   #1983
Trader Rating: 21 (100%+)
The 2.4 in rear will give you less side bite. Only ran this in high grip and I would recommend changing the inserts to aka or use dirt techs if you can't get them
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 02-10-2016, 08:21 AM   #1984
Davidka's Avatar
Trader Rating: 75 (100%+)
Chances are bar-flys aka chainlink or typos will work as well. With minimal tread, compound and prep are the bigger part of it. May take longer to break in.
Old 02-10-2016, 08:25 AM   #1985
RedBMaster's Avatar
Yeah, Dirt Webs and Electrons are the "go-to" tire around here too. Then again most of the people around here don't run clay tires, when that's all I run. If you can swing it, I'd definitely pick up set.
Follow, race proven, Prolix RC on facebook: https://www.facebook.com/ProlixRC/
RedBMaster is offline   Reply With Quote
Old 02-10-2016, 08:25 AM   #1986
I just ordered some from BeachRC.com earlier this week. They were in stock and shipped. I haven't broken mine, but I like having spare shock towers front and rear.
Thanks but they are out of stock too! My friend broke his and now I'm paranoid.
TimmE is offline   Reply With Quote
Old 02-10-2016, 08:33 AM   #1987
RedBMaster's Avatar
I had a similar issue with JC 2wd Front Clay Smoothies, ended up finding a new set on eBay.
Old 02-10-2016, 10:08 AM   #1988
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by STLNLST View Post
Why the stiffer spring up front in stock and did the heavier rear oil take out a little roll?
For the front spring, I drive much harder in stock, and it just gave me a little more safety. The rear oil won't roll less, it'll just roll slower.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 02-10-2016, 10:15 AM   #1989
I checked those out, but they're all backordered on all my go-to places. Next year I need to stock up before indoor season starts. Probably doesn't help that the dirt webs were the spec tire at Reedy the other weekend. I'm sure that sucked up the supply.
Callaway is offline   Reply With Quote
Old 02-10-2016, 10:50 AM   #1990
TLRacing
Frank Root's Avatar
They are just the most popular tire for indoor racing, and struggle to keep up with supply this time of year...
Old 02-10-2016, 01:50 PM   #1991
On Dustin Evens Reedy set up it says rear spring rate 1.94. Anyone know what spring that is? A TLR LF gray is 1.96. That's the closest i can find.
Dale.0 is offline   Reply With Quote
Old 02-10-2016, 03:32 PM   #1992
Vinny Cancilla's Avatar
yokomo green
Serpent Srx8
Serpent America: Triton engines/ Nitro pro.Fuel/ Rc Addiction products : Vp pro Usa/Dialed-Rc
Barnstormers: Chester, NY, N.Y.. IRH Lindenhurst
Vinny Cancilla is offline   Reply With Quote
Old 02-10-2016, 03:47 PM   #1993
Davidka's Avatar
They're so close I wouldn't bet that the duff would be detectable. I would be surprised if the springs can be manufactured accurately enough to guarantee batch tolerance that tight.
Old 02-10-2016, 04:27 PM   #1994
Originally Posted by Mudcat981 View Post
44 mm
Great! Thanks for the input!
nttdemented is offline   Reply With Quote
Old 02-10-2016, 04:32 PM   #1995
goehm's Avatar
Trader Rating: 44 (100%+)
Originally Posted by RedBMaster View Post
I've been running the two gear setup with 15k for over a month now and its perfect. I've got another guy that started using the same setup this last weekend and loved it.
So this is Serpent diff with 15k, using only two gears... what sort of track is this? Clay/carpet - med/high? Thanks!
--GO!
Come visit G's RC Raceway / Shippensburg, PA / www.GSRC.us
goehm is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Diggin420
