    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 01-30-2016, 05:44 PM   #1846
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by tony2 View Post
Has anyone had any issues running AKA wheels? The wheel nut seems to bottom out on the axles at the end of the thread and during a run the wheel starts to come loose.
Is everyone running TLR wheels?
TLR wheels fit great. I've heard this about AKA wheels, but cannot confirm. We did not reference them when designing the car.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 01-30-2016, 07:10 PM   #1847
Davidka's Avatar
Trader Rating: 75 (100%+)
I do have a few sets of Jconcepts 12mm wheels that I'll have to bore out slightly because the axles on the 22 3.0 are just a hair larger than the wheels will accept.
Old 01-30-2016, 07:11 PM   #1848
Davidka's Avatar
I guess it could be solved with the TLR +.75 clamping hex.
But you are charging the width of the car and possibly taking away a little grip in the rear.
Assuming the AKA rims are the exact same offset as the TLR's..
Old 01-30-2016, 11:46 PM   #1849
Default finally got it dialed in !
Finally got it dialed in ! This is a great car once you get it setup!!!
TLR 22 3.0
(2)TLR 22 SCT (Handed down to my kids)
professorjason is offline   Reply With Quote
Old 01-31-2016, 06:49 AM   #1850
cokemaster's Avatar
Trader Rating: 18 (100%+)
What kind of options do I have for gear differentials. I have been told that I can use the RTR LOSA2954 or Serpents SRX diffs (need shims though). And what is everyones experience?
cokemaster is offline   Reply With Quote
Old 01-31-2016, 06:52 AM   #1851
i am using the losi one with shims and it still is not perfect. its close though, so i am hoping that some rubbing will wear down what is still touching. if not, i will just sell the truck.
i havent tried serpents srx, if you try it and have a good experience, please post up
rekim is offline   Reply With Quote
Old 01-31-2016, 08:31 AM   #1852
tony montana's Avatar
Trader Rating: 65 (100%+)
Got to run the car again yesterday, did mamage to qualify first in the B at our roar region indoor championships, got the win in the B and bumped to the A and ended up finishing 7th. Not a bad day, but I'm still struggling with the car. I still don't have the rear grip I'm looking for. And I'm running the same tires as the top guys. What I have changed from kit setup is 1.6 pistons all the way around, red front low frequency spring and 32.5 front oil and 30 rear. Oh and we run slicks. Now I also have a b5m lite. I threw it out in practice and it was money. I didn't have a transponder in my b5m so couldn't compare lap times but it felt like I could push the car harder and get on the throttle. As far as electronics I'm using a orion r10.1 and orion 8.5 geared with a 22 tooth pinion. Now I did have a 21 on it, so I geared it up to try to tame the bottom end a little. It helped a tad but still need more. I'm up for suggestions, I usually don't have setup issues, I can usually dial a car in
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 01-31-2016, 08:45 AM   #1853
Im currently running the Serpent gear diff with zero shims and zero issues.
If your not first your last! Shake N bake!
FPMX772 is offline   Reply With Quote
Old 01-31-2016, 09:11 AM   #1854
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by Jack Bonhomme View Post
I found the opposite to be true. The stock short VLA position felt lazy to me on corner entry and exit. Felt ok mid corner. When I switched to the long VLA position the car steered more aggressively into and out of turns. Guess this perception varies by driver and track conditions.
Exactly what we have come up with locally (about 6-7 cars), we are all running long vla, long upper link (at the hub), shock in the middle on arms and inside tower with orange springs. dirt glued clay on slicks. As a whole the car is dominating all classes
Personally all i really ever mess with now is the hub spacing, on a good warm higher grip day i use both shims at the bottom, cold day slippery i put the hubs in the middle.
Excellent car Frank, i have become almost unbeatable since the switch!
MantisWorx is online now   Reply With Quote
Old 01-31-2016, 09:14 AM   #1855
MantisWorx's Avatar
I have not tried the Serpent gear dif yet but i will say that removing two spider gears and crosspin along with 3-4k oils (PTracing actually has 3.5k) is money but it does leak no matter what i do out of the outdrives.
Old 01-31-2016, 09:58 PM   #1856
nexxus's Avatar
Trader Rating: 301 (100%+)
Are there any after market thrust bearings that will fit the ball diff? I really dislike these seperate bearings, and was wondering if something like a premade bearing would fit? My guess is something like http://www.hobbyking.com/hobbyking/s...ent_2pcs_.html
A800 / A800X Awesomatix
Fry crack corn and I don't care,
Leela crack corn, I still don't care,
Bender crack corn and he is great!
Take that you stupid corn!
nexxus is offline   Reply With Quote
Old 01-31-2016, 10:38 PM   #1857
STLNLST's Avatar
Trader Rating: 19 (100%+)
I run the Schelle ones in mine.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-31-2016, 10:39 PM   #1858
nexxus's Avatar
Are they preassembled?
Old 01-31-2016, 10:39 PM   #1859
Team Pink's Avatar
Trader Rating: 20 (100%+)
You beat me to it! The Schelle one's work great!
Team Losi Racing/ Spektrum/ Horizon Hobby/ JConcepts/ Hobby Star/ Schelle Racing
Team Pink is offline   Reply With Quote
Old 01-31-2016, 10:47 PM   #1860
STLNLST's Avatar
They are the same configuration as the link you posted
