    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 01-26-2016, 01:42 PM   #1771
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by starspike View Post
Frank, will this: TLR234036 work with the 22 3.0? I hate those stupid set screws..
It should, but I'll admit I haven't not tried or test fit them.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 01-26-2016, 02:20 PM   #1772
Default Interpreting the Setup Sheets
Originally Posted by slakr View Post
Clint, thanks for all the info Sunday on your 3.0 experiences. One question I have for the group...still in learning mode.
When I read the setup sheets I'm getting a bit confused. For example, where details are noted for the "Camber Link", I see different setups and I don't know how to interpret the information. On Clint's setup I see "1A" - on the stock setup it's "2-A".
I think the numerical definition ("1", "2") refers to the position on the front or rear hub and the alphabetical definition ("A", "B") refer to the front or rear camber block. Is this accurate?
toddmanley is offline   Reply With Quote
Old 01-26-2016, 02:43 PM   #1773
brian cox's Avatar
Trader Rating: 56 (100%+)
better answer below..
Team Orion---Bradley Fine Line Design---AKA
brian cox is offline   Reply With Quote
Old 01-26-2016, 02:57 PM   #1774
Casper's Avatar
Trader Rating: 33 (100%+)
They fit on the 2.0 as they did not change the bulkhead I would have to assume it will work with the 3.0
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 01-26-2016, 03:25 PM   #1775
TLRacing
Frank Root's Avatar
Inside (camber blocks or shock towers) are numerical, with the lowest number starting closer to the center line of the chassis and counting up as they move away from the center line of the chassis.
Outside (caster block, hub) are alphabetical, starting with A closer to the center line of the chassis and progressing up (B,C,D, etc) as they move away from the center line of the chassis.
And, all of the locations are visually labelled on the setup sheets posted online and included within the vehicle manuals.
Old 01-26-2016, 05:09 PM   #1776
Mdawson1962's Avatar
You would have to drill the casters because the holes in the arms are bigger then the holes in the casters
Mdawson1962 is offline   Reply With Quote
Old 01-26-2016, 06:03 PM   #1777
STLNLST's Avatar
Trader Rating: 21 (100%+)
Frank beat me to it. I plan on making it out there sometime soon. That place has the best traction in Norcal. The 3.0 was so hooked up Sunday.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-27-2016, 07:26 AM   #1778
starspike's Avatar
Its for the hinge pins not the caster blocks.
TLR 22 3.0 ~ 22T 2.0 ~ 22-4 ~ 22SCT
Blue Groove Hobbies & Raceway
starspike is offline   Reply With Quote
Old 01-27-2016, 07:27 AM   #1779
starspike's Avatar
Thanks Casper! Going to have to pull one off my 22-4 and double check before pulling the trigger maybe.
Old 01-27-2016, 08:19 AM   #1780
Trader Rating: 49 (100%+)
Frank Any idea on when the Alum Servo mounts will be out?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 01-27-2016, 08:39 AM   #1781
TLRacing
Frank Root's Avatar
No precise date, we just received those first samples.
Old 01-27-2016, 11:27 AM   #1782
RedBMaster's Avatar
They work, I've been running then on my 3.0!
RedBMaster is offline   Reply With Quote
Old 01-27-2016, 11:59 AM   #1783
Exotek has servo mounts on their site now if you need some quickly.
RptrKlr is offline   Reply With Quote
Old 01-27-2016, 05:34 PM   #1784
Trader Rating: 137 (100%+)
Is anyone having this weird issue where the inside tire is lifting while taking really tight switchback or 180 degree turns? I cannot for the life of me tune this out.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 01-27-2016, 07:53 PM   #1785
L0RAX's Avatar
I'm using them as well . . . .
TLR 22 2.0 RM
TLR 22 3.0
TLR 22-4
Airtronics / Orion / SMC / Schuur
. . . now all I gotta do is learn how to drive . . .
L0RAX is offline   Reply With Quote
