    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 01-19-2016, 10:02 PM   #1681
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Medicinal Coma View Post
What piston setup are most using? I see a lot of set ups are using 1.6 front and rear. Is that what most are using on here? Or staying with the kit setup of 1.5 in front and 1.6 rear?
Thank you for any replies.
Seems like a lot have been liking 1.6 front and 1.7 rear. This is what I am running ATM, as is most of the team heading into the Reedy Race tomorrow.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 01-19-2016, 11:08 PM   #1682
Team Pink's Avatar
Trader Rating: 20 (100%+)
I have really liked 1.6 in front and 1.7 in the rear as well. I have also really liked Schelle Racing's 4 hole 1.5+1.1 piston in the front and 4 hole 1.6+1.1 in the rear. The overall feeling is really close between the two combinations with the 4 hole pistons providing slightly more pack.
Team Losi Racing/ Spektrum/ Horizon Hobby/ JConcepts/ Hobby Star/ Schelle Racing
Team Pink is offline   Reply With Quote
Old 01-20-2016, 07:24 AM   #1683
onadcr74's Avatar
I take it the 1.6 and 1.7 combo is with 30wt all the way around?
"Car was dialed, to bad it was the wrong number."
onadcr74 is offline   Reply With Quote
Old 01-20-2016, 10:14 AM   #1684
Team Pink's Avatar
I've been running 32.5 front, 30 rear with good success.
Old 01-20-2016, 11:12 AM   #1685
STLNLST's Avatar
Trader Rating: 19 (100%+)
Anyone have the part# for just the aluminum bones for the 2wd buggy? I've found them for the trick but Noe the buggy.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-20-2016, 01:30 PM   #1686
Bobby Z's Avatar
Hey Frank. What will this change vs the stock Pistons?
Bob Zahn
Sponsored by TLR - Horizon - Spektrum - Orion - AKA
Bobby Z is offline   Reply With Quote
Old 01-20-2016, 01:36 PM   #1687
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
TLR332005.
I'm not sure if they are made available separately from the whole driveshaft kit. That part number returns zero on horizon. I googled it though and Stormer has a few sets.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-20-2016, 02:22 PM   #1688
STLNLST's Avatar
Originally Posted by Matt Trimmings View Post
TLR332005.
Must not be a top seller as it's discontinued from A-main as well. Thanks for the help.
Old 01-20-2016, 04:15 PM   #1689
Would those bones work with the titanium rear axles?
TimmE is offline   Reply With Quote
Old 01-20-2016, 04:35 PM   #1690
Team Pink's Avatar
I'm going to assume you are referring to the Protek RC ones? If so, yes they should fit no problem.
Old 01-20-2016, 08:49 PM   #1691
HollywoodRC's Avatar
Ok, I have searched this entire site trying to figure out what wheels and tires go together. Grrrrrrrrrrr. 2.2, 2.4 60mm, 61mm. I like DE Racing, AKA, and Pro-Line wheels. Do they make wheels for the 3.0. I know they made them for the 2.0, but I'm having trouble finding them for the 3.0. Anyone know the part numbers for any of these? Last, what tires go with this wheels? I feel like such an idiot.
HollywoodRC is offline   Reply With Quote
Old 01-20-2016, 09:45 PM   #1692
rcus3r's Avatar
It will make your buggy $14 more expensive . Sorry, couldn't help myself.
Had an extra pair from when I bought the 4 pack for my SCT, so I tried them. Went up in oil 2.5wt to make the damping ratio similar. Couldn't tell the difference. But I am far from an expert!
I guess it is a tuning option. It either feels more or less damped, at a smaller increment than just changing oil weight.
I spent a night at Holiday Inn Express...
rcus3r is offline   Reply With Quote
Old 01-21-2016, 03:40 AM   #1693
Bobby Z's Avatar
Thanks for your reply. Some comedic relief is welcome.
I expect the bigger Pistons could do a few things vs the stock setup. I'll try it out this weekend and hopefully confirm what I think it will do. I ran this setup on my 2.0RM with great success on our outdoor, dry and slippery track. In that situation it made the car so much easier to drive and soaked up bumps and had a lot more traction.
Bob Zahn
Old 01-21-2016, 05:17 AM   #1694
Originally Posted by drepus View Post
Some folks who have tried have the Losi 22 rtr gear diff have had a little binding some have not. If yours does bind here is how i fixed mine.
Only takes a minute to accomplish.
https://www.facebook.com/groups/22em...9/?pnref=story
do you have any links that are do not require facebook to view?
rekim is offline   Reply With Quote
Old 01-21-2016, 05:49 AM   #1695
Andrew Gray's Avatar
Hey Clint, I don't think they sell just the bones, but # TLR332002 is the complete aluminum driveshaft set.
Retired & Washed Up. TLR Supporter For Life
Andrew Gray is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
