Like Tree1Likes
Old 01-11-2016, 10:03 AM   #106
Jdubst13's Avatar
I just built one of these and noticed you can put the rear shocks either in front or behind the shock tower, the instructions call for behind the shock tower but some people run the shocks in front. What's the difference in performance?
B6D/B6/B5m
Jdubst13 is offline   Reply With Quote
Old 01-11-2016, 01:18 PM   #107
the incubus's Avatar
Trader Rating: 17 (100%+)
Like most cars with the option to mount shocks either in the front or rear of the tower, the front position will help steering as it places their mass further forward allowing the car to rotate a bit easier. In the Rear position it aides in increasing traction a touch for looser conditions. On the PRS1 however, shock positioning depends on which transmission layout you elect to run. If running Rear Motor, the shocks will be in front of the tower. If you go Mid-Motor, the shocks will sit behind of the tower. I don't recall seeing the shocks swapped around on the PRS1 with either motor configuration.
The best aesthetic feature of placing your shocks in front of the tower is that you'll no longer have to worry about cutting the notches out on your wing for shock clearance.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 01-11-2016, 02:46 PM   #108
markt311's Avatar
Trader Rating: 32 (100%+)
I have tried both and run mine on the rear most of the time, unless traction goes up a ton.
PR Racing Bellgate Distributors
Caster Racing Parts
311 RC Graphics
markt311 is offline   Reply With Quote
Old 01-11-2016, 03:41 PM   #109
Jdubst13's Avatar
Well considering the V3 is a mid motor only car and I'm running on high bite clay I think it's safe to say that putting the shocks behind the tower is the way to go.
B6D/B6/B5m
Old 01-11-2016, 03:45 PM   #110
Jdubst13's Avatar
Sounds like running the shocks forward is better suited for carpet and running them back is better for clay.
B6D/B6/B5m
Old 01-11-2016, 09:12 PM   #111
xxx-ntad2 racer's Avatar
Trader Rating: 24 (100%+)
Hey guys, just built my v3. Wondering if anyone has noticed any toe in bump steer on the car and if so, what did you do to get rid of it. Thanks
xxx-ntad2 racer is offline   Reply With Quote
Old 01-12-2016, 08:56 AM   #112
markt311's Avatar
I noticed the bump-in, I'm running 2mm of washers and the outside hole on the steering block. Mine still has bump-in, but the car drives good so I'll leave it.
Caster Racing Parts
311 RC Graphics
Old 01-12-2016, 09:00 AM   #113
markt311's Avatar
I ran mine shocks forward for stock, but my local track was also very high bite that weekend. It's definitely worth playing around with.
Just noticed you're from Vista, I grew up there. Graduated RBV in 97
Caster Racing Parts
311 RC Graphics
Old 01-12-2016, 10:13 AM   #114
Jdubst13's Avatar
Ok, my buddy bought a V3 also and tried both and said with the shocks forward car was a lot to handle.
Yeah man I've lived in Vista for the last 6 years but grew up in Encinitas.
B6D/B6/B5m
Old 01-12-2016, 11:04 AM   #115
bring it on's Avatar
thanks for sharing
Toro ESC - SkyRc - Caster Racing USA - Pr Racing USA - Gens Ace - Ares Motors - Highest Servos - Radiopost
Thanks to my sponsor at crpplus.com
bring it on is offline   Reply With Quote
Old 01-12-2016, 07:05 PM   #116
Thanks for answering my question. I also had a question dealing with the axels. Is any one having troubles with them barely siting in the outdrives? And if so do they pop out at all at full droop?
Old 01-17-2016, 07:06 AM   #117
I just looked at pr s1 v3 and noticed that there are no spur gear cover as v2.
Is there optional part to avoid stones to break the spur gear ?
julieng is offline   Reply With Quote
Old 01-17-2016, 09:34 AM   #118
Can you post a pic?
Old 01-17-2016, 09:36 AM   #119
Humm, good question. I will try to look into that for you.
Old 01-17-2016, 09:49 AM   #120
Thanks.
I think it would look better finished with this cover (like Losi 22 3.0 or PR S1 V2 MM)
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Ty
