Like Tree1Likes
Old 10-28-2015, 07:43 PM   #16
thanks. are there options to make it 30 or 35?
I wonder if they'll be full arm options?
is there a way to put the front shocks behind the shock tower like the v2?
sealander is offline   Reply With Quote
Old 10-29-2015, 04:24 AM   #17
lewis110's Avatar
Honestly I know there's options to make it have more caster. But I don't know all the options off the top of my head.
+5mm +7* brass front bulkhead would make it 32.
I know there is a +3* caster blocks. I also believe there are +3* C hubs also. So I'm sure you can get to 35 with a couple option parts.
I'm assuming you're talking the Shocks behind the tower in the Rear not the front? The rear Shocks can be mounted in the front or rear of the tower. The front Shocks are only behind the tower like on the V2.
Hobbywing of North America/FalconSekido www.falconsekido.com
Hobby-Pro USA www.hobbyprousa.com
Dialed RC Hobbies/VP Pro USA www.Dialedhobbies.com
lewis110 is offline   Reply With Quote
Old 10-29-2015, 04:26 AM   #18
lewis110's Avatar
The standard v2 full length arm is a direct fit part. The high bite arms are an option part for the v2. They are the exact same thing except 1 or 1.5mm shorter width.
Old 10-29-2015, 01:11 PM   #19
RCMamba's Avatar
Anyone know what the major differences are from the V2 and the V3?
RCMamba is offline   Reply With Quote
Old 10-29-2015, 01:51 PM   #20
Cleanwerkz's Avatar
I built mine.......
AND ITS SICKKKKK
Zachary Thompson
Cleanwerkz performance Cleaning Solutions
Columbia, SC
Cleanwerkz is offline   Reply With Quote
Old 10-29-2015, 04:39 PM   #21
The biggest changes are it's a mid motor only car, 3 gear low cg trans, chassis and side pods. The rear arms, hubs, and mounts are the same as well as the whole front end (towers might be slightly different).
rcgerber is offline   Reply With Quote
Old 10-29-2015, 05:16 PM   #22
RCMamba's Avatar
Is it worth upgrading the V2 to the V3? I am thinking about getting a used V2 but saw that Hobby Pro was releasing the V3?
Old 10-29-2015, 05:46 PM   #23
lewis110's Avatar
The V3 also comes with high bite arms so they are slightly shorter then the v2 arms. But the v2 are a direct fit if you want to go that route. The alum hubs are also different. The ones the preorders got a -2mm hubs. I've also heard the standard plastic hubs come in the regular kits now. The front tower is definitely different. I didn't compare but it looks like the geometry has been improved. Plus with the pro steering blocks the bump steer spacers aren't nearly as tall as the regular blocks.
Overall I feel like the car has been updated fairly well. If you run on any kind of medium to high bite this will be a great car for you.
Old 10-30-2015, 05:58 AM   #24
markt311's Avatar
Trader Rating: 32 (100%+)
The V3 comes with molded +3 caster blocks, so stock it has 28 degrees of caster.
+5 aluminum caster blocks are available too
On the steering make sure you use the inner hole for the steering turnbuckle and space your servo forward. If you use the 2nd hole you won't have enough steering throw. my Ace 1015 is spaced 3.5mm forward.
PR Racing Bellgate Distributors
Caster Racing Parts
311 RC Graphics
markt311 is offline   Reply With Quote
Old 11-02-2015, 09:54 AM   #25
markt311's Avatar
Sorry it took a few days to post pics. My car is stock except for aluminum servo mounts and brass rr block.
Caster Racing Parts
311 RC Graphics
Old 11-03-2015, 02:43 AM   #26
Trader Rating: 14 (100%+)
who has the best prices on these? Direct from Hobbypro?
Zak
TLR 22 4.0, Associated B64D
Team Absima UK
PR Racing UK
fivepointnine is online now   Reply With Quote
Old 11-03-2015, 11:45 AM   #27
Looks like direct from HobbyPro is the best price if they ship international.
Old 11-03-2015, 04:00 PM   #28
markt311's Avatar
http://www.rcnews.net/2015/11/03/ins...ing-to-the-uk/
Caster Racing Parts
311 RC Graphics
Old 11-04-2015, 12:53 AM   #29
Shipping is not a problem, I have a US address to ship to (APO) I don't think the UK prices will be cheaper. (although some buggies are, like TLR stuff and Xray stuff)
Zak
Team Absima UK
PR Racing UK
Old 11-04-2015, 12:56 AM   #30
Originally Posted by markt311 View Post
Thanks, I order from them all the time for Xray parts. It looks like their prices on the buggy wont be as bad as I thought!
Zak
Team Absima UK
PR Racing UK
