Old 05-19-2016, 01:10 PM   #196
johnnyshore's Avatar
Trader Rating: 72 (100%+)
Anyone else have a slight transmission binding issue in their V3? I've had the trans apart 3 times now, and everything looks fine, but it's just not "free" when assembled. The car has a bit of a whine on the track as well. Am I missing something obvious? The diff spins free, and the idler and input shaft/gear spin free, but put together, something is just a little bit off, and I can't find it for some reason. Tried running the case with the bolts loosened, no difference.
The car handles great, but this trans issue is a bit frustrating. Any suggestions would be helpful.
Thanks!
John Schroer
Check out Shamrock R/C Raceway
Minnesota's only outdoor astroturf off-road track!
https://www.facebook.com/ShamrockRC/
johnnyshore is offline   Reply With Quote
Old 05-19-2016, 01:14 PM   #197
the incubus's Avatar
Trader Rating: 17 (100%+)
Have you inspected the outdrive bearings to ensure they sit absolutely flush as they should?
I had a similar issue with my old B4.2 and the bearings sat ever slightly too far out and it caused some binding. By the time I figured it out the bearings were toast and I had to replace them. i suggest you remove them and then look at the recesses carefully to see if you don't spot any excess flash from the molding process or any portions that are raised and take them down if you find any.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 05-21-2016, 01:19 AM   #198
Originally Posted by the incubus View Post
Well what can I say? Those are the instructions from the manufacturer and both bearing ID's remain unchanged in the manual. Are the bearing sizes different on the v3?
The V3 have different offset for rear hubs and different wheelhexes than V2.
Ass B5 wheels will work on the rear but will bind on the front but the best is still PRīS own wheels.
evo6tme73 is offline   Reply With Quote
Old 09-02-2016, 12:27 PM   #199
Just gotten this car.
Anyone uses the new lightweight chassis? Any difference as compared to the stock chassis?
Another thing is, where do you guys get the titanium turnbuckle from?
mezan91 is offline   Reply With Quote
Old 09-02-2016, 12:57 PM   #200
What country do you live in?
Rich O'Hara
Bellgate Distributors, LLC
Absima | Triton RC | MIP | Maclan Racing | PR Racing | Highest RC | JQRacing | Modelix Racing | Prospeed
Bellgate is offline   Reply With Quote
Old 09-03-2016, 11:57 AM   #201
bring it on's Avatar
I think most are running AE titanium turnbuckles
Toro ESC - SkyRc - Caster Racing USA - Pr Racing USA - Gens Ace - Ares Motors - Highest Servos - Radiopost
Thanks to my sponsor at crpplus.com
bring it on is offline   Reply With Quote
Old 09-06-2016, 10:58 PM   #202
IntegraMark's Avatar
Are you looking to use the car for stock racing?
Lunsford makes a set of turnbuckles but I believe PR makes them as well. I know they have a set for the 4wd buggy Im not certain for the 2wd.
Hotrod Hobbies
Instagram: IntegraMark
IntegraMark is offline   Reply With Quote
Old 09-07-2016, 08:27 AM   #203
Singapore
Thanks @bring it on. Will definitely have a look at it.
@IntegraMark, no idea on that yet. Just starting out and still learning. Thanks for the help, I will check with local distributor here on the parts.
Thanks for the help.
Old 09-07-2016, 08:11 PM   #204
don't order the chassis unless you need it.
Hotrod Hobbies
Old 10-10-2016, 06:16 AM   #205
Default Will V3 tranny mount into v2
Hello has anyone tried putting a v3 tranny in a v2? I've already modded the dirt guards so I can run my battery horizontal. Will the v3 mounting holes on the tranny case line up to the v2 existing mounting holes? This would be a fun modification if it would work with moderate modification. I love the v2, always gets a lot of looks but would like to be able to build a hybrid, just something different.
57ratrod is offline   Reply With Quote
Old 10-10-2016, 02:27 PM   #206
I think it would work. I know of a guy that put a v2 trans in his v3 fm (before the new MM car came out). So I have to assume it wouldn't be to hard to do it the other way. You would have to drill holes in the chassis for the waterfall though.
rcgerber is offline   Reply With Quote
Old 10-11-2016, 09:18 PM   #207
markt311's Avatar
Trader Rating: 32 (100%+)
It can be done. The rear holes on the v3 transmission will line up. Just drill 2 more holes to mount the transmission and 2 holes for the waterfall.
PR Racing Bellgate Distributors
Caster Racing Parts
311 RC Graphics
markt311 is offline   Reply With Quote
Old 10-12-2016, 05:20 PM   #208
Any pics of the mod? I'm going to order the parts and try it
Old 10-12-2016, 05:29 PM   #209
One other ?, will my gear diff in my v2 work in the v3 case? Any other gears in v2 work? What other gears would I need to order for complete tranny? Thanks
Old 10-13-2016, 01:51 PM   #210
markt311's Avatar
Gear diff will drop in. V2 gear set includes v2 and v3 style idler gears, v2 top shaft is the same as v3 also.
Caster Racing Parts
311 RC Graphics
