    Hide Wikipost
Old 12-26-2016, 07:51 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Xray XB2 2WD Buggy Thread
Last edit by: dgrobe2112
Instruction manuals: (C/O BentKa)
Xray XB2 Carpet Edition Instruction Manual
http://www.teamxray.com/xb2/2016/dow...ual_v2_low.pdf
Xray XB2 Dirt Edition Instruction Manual
http://www.teamxray.com/xb2/2016/dow...w.pdf?update=2
BentKa: Carpet Edition 4 gear to 3 gear laydown conversion parts:
  • Gearbox #323014
  • Motorplate #324012
  • 36T idler gear #324236
  • Brace for waterfall #324031
Socket: Bodies Available:
Xray has two OEM bodies, the .75mm and the .50mm light weight:
light weight: https://www.amainhobbies.com/xray-xb...329701/p492942
OEM .75mm: https://www.amainhobbies.com/xray-0....329700/p477762
Also, I've fitted the yz2 body, both the light and regular fit fine, just make your own cut lines:
https://www.amainhobbies.com/yokomo-...z2-101/p417674
[i] J Concepts S2 Body [i]
Penguin Racing makes a high grip body that fits the DE and CE:
http://www.ebay.com/itm/X-Ray-Xb2-Hi...oAAOSw1S9WewHV
Socket: Wheel fitment:
According to some, you'll require different offset rear hexes to use B5M wheels. According to my Hudy setup board, B5M wheels are the same offset. I measured the overall width of the car with XB2 wheels, and then again with B5M wheels, same measurement.
On the front, B5M wheels were 1.5mm wider. Xray offers hexes to reduce width -.75 on each side, or you could spend 3-5 minutes and sand your OEM hexes down .75mm.
edit by dgrobe2112
here are the hubs for losi and AE
for AE Front 365354 -0.75
for Losi rear 365358 +3.00 (4 stripe)
for AE rear 365359 +3.75 (5 stripe)
Socket: Flex and the XB2:
Flex screws are as follows:
Plastic bulkhead between motor and waterfall. Can remove screw in chassis, or remove bulkhead altogether.
Waterfall has 4 screws, can remove the inner two or outer two. IIRC, removing the inner two provides more flex, and thus more bite.
Removing the battery brace. This gives a tremendous amount of flex on the middle of the car, and can sometimes be inconsistent. I do this for outdoor racing on low bite. I like the feel over the 4 gear in 17.5 racing, since the 4 gear will take some snap away off the corner.
Rear C block - has inner and outer screws. I haven't played with this, as it's a crucial pivot point of the car.
Medium arms and towers -> I don't believe the carpet car has the rear medium tower available, however the DE DOES have an optional hard part. I think the hard parts are more consistent, especially when it gets hot (90+ degrees F). However, the medium parts do NOT break unless you're severely talented. They also don't wear out.
Socket: Avid/Schelle Slipper mod:
Credit to WillS, Matt Trimmings, and myself for figuring this out months ago.
Parts you'll need:
B5M V2 3gear compatible top shaft.
TKO Special 5x13x5 bear OR 5x13x6 bearing Either can work. This replaces the spur side bearing on the top shaft.
5mm shims, same shims used in 1/8th scale clutch bells. Look for protek .1mm and .2mm kit.
Avid or Schelle b5m top shaft kit, with spur gears of your choosing. (DE can't handle a 69, the CE can)
Shimming: You'll need to install the bearing in the front portion of the removable piece for the shaft. Make sure the bearing is pushed all the way in. With the TKO bearing, you'll need to shim approximately 1.4mm on the front side of the top shaft. Roughly .3-.5mm with the other bearing. This is a "feel" and tolerance setting. I urge you to watch videos about setting clutch bell play in 1/8th scale to get an idea of what yield you want for end play. Too tight, it'll eat bearings.
Outside of trans case: Use Avid/Schelle top shaft spacer plus .2mm shim to offset slipper from motor plate perfectly. Install slipper as instructed, and use Avid/Schelle spring and XB2 slipper nut.
- NEW - Schelle now sells Xb2 Topshafts. They include a spacer, so no need for shims in gearbox, and comes with the smaller bearing. Both methods work.
Socket: Yokomo Differential or MIP pucks:
Credit to: WillS for figuring out pucks, and as well fitting the Losi 22 diff with the same mods.
Parts needed: Yokomo Bmax2 or YZ2 complete diff OR Mip PUCKS outdrives
Xb2 diff gear
Bmax2 V3 Worlds rear dog bones, or Bmax 2 pucks dog bones
You'll use XB2 axles, and will require no other mods for the axles or dog bones.
You'll need .2mm outdrive/diff shims. Shim approximately .5mm on each side of the diff, behind the bearings. The top portion of the transmission is what "sets" the diff in place, not the bottom half. A little play back and forth is fine, the stock diff has some play from the factory.
dgrobe2112: CE to DE conversion:
along with the parts needed.. you MUST have these following hardware, or it wont work
https://www.teamxray.com/xb2/2016/do...conversion.pdf
(3) XRAY 902340 M3x40 button head screws. these are the screws that mount the motor mount to the tranny
(4) XRAY 903322 M3x22 counter sunk screws. these are for the rear diff case, to mount to the chassis. i think i used some M3x18 and they worked ok.
Socket: Best method for setting up the XB2 ball diff:
The XB2 diff is stellar when setup correctly. The spring is too short and soft, allowing the diff to slip. You'll need to glue the rings to the outdrives with just a drop of CA, then add a 1mm shim between the spring and the outdrive. This preloads the spring and stops the diff from slipping so easily.
OR, you can run the AE diff spring, which is both slightly longer, and stiffer. The overwhelming issue is the stock spring allows the nut to bottom out on the outdrive before the diff is tight enough.
This shim:
https://www.amainhobbies.com/xray-al...a303122/p12070
This diff spring (don't need a shim, then.)
https://www.teamassociated.com/parts...thrust_spring/
Functional Aftermarket parts: (Not just bling!)
Servo Horn: (The B5M sized horns are too short to get full throw)
https://www.amainhobbies.com/protek-...800-bk/p273496
Socket: Exotek has a full suite of parts, some bling, some not. Here's a list (all fit DE and CE, unless otherwise noted):
Titanium front axles: http://www.exotekracing.com/xb2-titanium-front-axles-2/
Rear Hanger, HD (Adds 4 grams): http://www.exotekracing.com/xb2-rear...75-heavy-duty/
Brass C block, 18 grams added: http://www.exotekracing.com/xb2-rear...-brass-weight/
Alloy front camber mount: http://www.exotekracing.com/xb2-fron...er-mount-7075/
Carbon Fiber Chassis: http://www.exotekracing.com/xb2-carb...m-plate-2-5mm/
Alloy rear hubs:http://www.exotekracing.com/xb2-allo...ub-set-2-7075/
Alloy servo mounts, allow for use of LP servo:http://www.exotekracing.com/xb2-xb4-...-alloy-1-pair/
Titanium shock mounts: http://www.exotekracing.com/xb2-xb4-...shock-posts-2/
Slipper Eliminator: http://www.exotekracing.com/xb2-direct-spur-mount/
Xray eliminator is #324100
dgrobe2112: 2016-2017 new 3 gear laydown
Gearbox #323014
Motor plate #324012
dgrobe2112: Xray Spring Rate Conversion:
front C WHT
368174 2 str 0.65-0.85 3.71-4.85
358184 2 dot 0.65 3.71
368185 3 dot 0.72 4.11
368186 4 dot 0.80 4.57
Rear
368273 2 str 0.35-0.45 2.00-2.57
368284 1 Dot 0.35 2.00
368285 2 Dot 0.40 2.28
368286 3 Dot 0.45 2.57
368287 4 Dot 0.50 2.86
Print Wikipost
Like Tree30Likes
Old 11-20-2015, 07:12 AM   #106
symmetricon's Avatar
Trader Rating: 27 (100%+)
A little birdie told me.....
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 11-20-2015, 07:13 AM   #107
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 11-20-2015, 07:39 AM   #108
suby723's Avatar
Trader Rating: 21 (100%+)
Just preordered mine from Rc America. The car is confirmed to come with an optional ball diff on the carpet car and will have tuning option spare parts. The kit is $349 and should be ready to be shipped out the first week of December. Can't wait!!!
suby723 is offline   Reply With Quote
Old 11-20-2015, 08:04 AM   #109
I got mine ordered too.... cant wait, hopefully it will work for me as well as my RB6..
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 11-20-2015, 08:48 AM   #110
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 30 (100%+)
Ordered.
lagcisco is offline   Reply With Quote
Old 11-20-2015, 09:15 AM   #111
anthonyjesmond's Avatar
Trader Rating: 86 (100%+)
how do i preorder this. I went to rc america and I don't see a link or pre order area
Anthony Jesmond
CT
Schumacher KF, KR, Mi5 Evo
Kyosho ZX6, Xray XB4 SCTE Ten 2.0,
Kyosho Scorpion, Monster Beetle
anthonyjesmond is offline   Reply With Quote
Old 11-20-2015, 09:18 AM   #112
pickle311's Avatar
Trader Rating: 31 (100%+)
This car is going to be good. Can't wait to get my hands on one.
Thanks to my sponsors and friends
RC America l Xray l Hudy | Pro-Line |KO Propo | Avid | VP Powermaster
pickle311 is offline   Reply With Quote
Old 11-20-2015, 09:18 AM   #113
suby723's Avatar
Call them. They have great customer service.
Old 11-20-2015, 10:11 AM   #114
gticlay's Avatar
I haven't heard anything about tuning option spare parts?
Thanks to Lunsford, Proline, Schelle, Xray, RCAmerica, and SMC for your support.
gticlay is offline   Reply With Quote
Old 11-20-2015, 11:04 AM   #115
suby723's Avatar
The rep at rcamerica told me the car with come with different material arms for tuning and the ball diff will be a nice aid also. I can't wait to see some setup sheets now.
Old 11-20-2015, 11:21 AM   #116
gticlay's Avatar
Well, that'll be super cool. I can't wait to see the setup sheets either.
Old 11-20-2015, 11:30 AM   #117
suby723's Avatar
I don't think I've ever been this excited to get my hands on a kit! Lol
Old 11-20-2015, 11:57 AM   #118
seth556's Avatar
Trader Rating: 42 (100%+)
Well, here we go. http://www.neobuggy.net/2015/11/20/x...ed/#more-66608
I'm most excited about the 4 screw diff access, about time someone did that.
seth556 is offline   Reply With Quote
Old 11-20-2015, 11:58 AM   #119
RCHamburg's Avatar
Me too!
https://www.youtube.com/user/RCHamburg
RCHamburg is offline   Reply With Quote
Old 11-20-2015, 12:12 PM   #120
suby723's Avatar
Wow just wow! This 2wd is a game changer with the simplicity of the diff access. Sure makes all the other company's look bad! That's what I was talking about with all the extra tuning parts. Mind blown right now haha
