    Hide Wikipost
Old 12-26-2016, 07:51 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Xray XB2 2WD Buggy Thread
Last edit by: dgrobe2112
Instruction manuals: (C/O BentKa)
Xray XB2 Carpet Edition Instruction Manual
http://www.teamxray.com/xb2/2016/dow...ual_v2_low.pdf
Xray XB2 Dirt Edition Instruction Manual
http://www.teamxray.com/xb2/2016/dow...w.pdf?update=2
BentKa: Carpet Edition 4 gear to 3 gear laydown conversion parts:
  • Gearbox #323014
  • Motorplate #324012
  • 36T idler gear #324236
  • Brace for waterfall #324031
Socket: Bodies Available:
Xray has two OEM bodies, the .75mm and the .50mm light weight:
light weight: https://www.amainhobbies.com/xray-xb...329701/p492942
OEM .75mm: https://www.amainhobbies.com/xray-0....329700/p477762
Also, I've fitted the yz2 body, both the light and regular fit fine, just make your own cut lines:
https://www.amainhobbies.com/yokomo-...z2-101/p417674
[i] J Concepts S2 Body [i]
Penguin Racing makes a high grip body that fits the DE and CE:
http://www.ebay.com/itm/X-Ray-Xb2-Hi...oAAOSw1S9WewHV
Socket: Wheel fitment:
According to some, you'll require different offset rear hexes to use B5M wheels. According to my Hudy setup board, B5M wheels are the same offset. I measured the overall width of the car with XB2 wheels, and then again with B5M wheels, same measurement.
On the front, B5M wheels were 1.5mm wider. Xray offers hexes to reduce width -.75 on each side, or you could spend 3-5 minutes and sand your OEM hexes down .75mm.
edit by dgrobe2112
here are the hubs for losi and AE
for AE Front 365354 -0.75
for Losi rear 365358 +3.00 (4 stripe)
for AE rear 365359 +3.75 (5 stripe)
Socket: Flex and the XB2:
Flex screws are as follows:
Plastic bulkhead between motor and waterfall. Can remove screw in chassis, or remove bulkhead altogether.
Waterfall has 4 screws, can remove the inner two or outer two. IIRC, removing the inner two provides more flex, and thus more bite.
Removing the battery brace. This gives a tremendous amount of flex on the middle of the car, and can sometimes be inconsistent. I do this for outdoor racing on low bite. I like the feel over the 4 gear in 17.5 racing, since the 4 gear will take some snap away off the corner.
Rear C block - has inner and outer screws. I haven't played with this, as it's a crucial pivot point of the car.
Medium arms and towers -> I don't believe the carpet car has the rear medium tower available, however the DE DOES have an optional hard part. I think the hard parts are more consistent, especially when it gets hot (90+ degrees F). However, the medium parts do NOT break unless you're severely talented. They also don't wear out.
Socket: Avid/Schelle Slipper mod:
Credit to WillS, Matt Trimmings, and myself for figuring this out months ago.
Parts you'll need:
B5M V2 3gear compatible top shaft.
TKO Special 5x13x5 bear OR 5x13x6 bearing Either can work. This replaces the spur side bearing on the top shaft.
5mm shims, same shims used in 1/8th scale clutch bells. Look for protek .1mm and .2mm kit.
Avid or Schelle b5m top shaft kit, with spur gears of your choosing. (DE can't handle a 69, the CE can)
Shimming: You'll need to install the bearing in the front portion of the removable piece for the shaft. Make sure the bearing is pushed all the way in. With the TKO bearing, you'll need to shim approximately 1.4mm on the front side of the top shaft. Roughly .3-.5mm with the other bearing. This is a "feel" and tolerance setting. I urge you to watch videos about setting clutch bell play in 1/8th scale to get an idea of what yield you want for end play. Too tight, it'll eat bearings.
Outside of trans case: Use Avid/Schelle top shaft spacer plus .2mm shim to offset slipper from motor plate perfectly. Install slipper as instructed, and use Avid/Schelle spring and XB2 slipper nut.
- NEW - Schelle now sells Xb2 Topshafts. They include a spacer, so no need for shims in gearbox, and comes with the smaller bearing. Both methods work.
Socket: Yokomo Differential or MIP pucks:
Credit to: WillS for figuring out pucks, and as well fitting the Losi 22 diff with the same mods.
Parts needed: Yokomo Bmax2 or YZ2 complete diff OR Mip PUCKS outdrives
Xb2 diff gear
Bmax2 V3 Worlds rear dog bones, or Bmax 2 pucks dog bones
You'll use XB2 axles, and will require no other mods for the axles or dog bones.
You'll need .2mm outdrive/diff shims. Shim approximately .5mm on each side of the diff, behind the bearings. The top portion of the transmission is what "sets" the diff in place, not the bottom half. A little play back and forth is fine, the stock diff has some play from the factory.
dgrobe2112: CE to DE conversion:
along with the parts needed.. you MUST have these following hardware, or it wont work
https://www.teamxray.com/xb2/2016/do...conversion.pdf
(3) XRAY 902340 M3x40 button head screws. these are the screws that mount the motor mount to the tranny
(4) XRAY 903322 M3x22 counter sunk screws. these are for the rear diff case, to mount to the chassis. i think i used some M3x18 and they worked ok.
Socket: Best method for setting up the XB2 ball diff:
The XB2 diff is stellar when setup correctly. The spring is too short and soft, allowing the diff to slip. You'll need to glue the rings to the outdrives with just a drop of CA, then add a 1mm shim between the spring and the outdrive. This preloads the spring and stops the diff from slipping so easily.
OR, you can run the AE diff spring, which is both slightly longer, and stiffer. The overwhelming issue is the stock spring allows the nut to bottom out on the outdrive before the diff is tight enough.
This shim:
https://www.amainhobbies.com/xray-al...a303122/p12070
This diff spring (don't need a shim, then.)
https://www.teamassociated.com/parts...thrust_spring/
Functional Aftermarket parts: (Not just bling!)
Servo Horn: (The B5M sized horns are too short to get full throw)
https://www.amainhobbies.com/protek-...800-bk/p273496
Socket: Exotek has a full suite of parts, some bling, some not. Here's a list (all fit DE and CE, unless otherwise noted):
Titanium front axles: http://www.exotekracing.com/xb2-titanium-front-axles-2/
Rear Hanger, HD (Adds 4 grams): http://www.exotekracing.com/xb2-rear...75-heavy-duty/
Brass C block, 18 grams added: http://www.exotekracing.com/xb2-rear...-brass-weight/
Alloy front camber mount: http://www.exotekracing.com/xb2-fron...er-mount-7075/
Carbon Fiber Chassis: http://www.exotekracing.com/xb2-carb...m-plate-2-5mm/
Alloy rear hubs:http://www.exotekracing.com/xb2-allo...ub-set-2-7075/
Alloy servo mounts, allow for use of LP servo:http://www.exotekracing.com/xb2-xb4-...-alloy-1-pair/
Titanium shock mounts: http://www.exotekracing.com/xb2-xb4-...shock-posts-2/
Slipper Eliminator: http://www.exotekracing.com/xb2-direct-spur-mount/
Xray eliminator is #324100
dgrobe2112: 2016-2017 new 3 gear laydown
Gearbox #323014
Motor plate #324012
dgrobe2112: Xray Spring Rate Conversion:
front C WHT
368174 2 str 0.65-0.85 3.71-4.85
358184 2 dot 0.65 3.71
368185 3 dot 0.72 4.11
368186 4 dot 0.80 4.57
Rear
368273 2 str 0.35-0.45 2.00-2.57
368284 1 Dot 0.35 2.00
368285 2 Dot 0.40 2.28
368286 3 Dot 0.45 2.57
368287 4 Dot 0.50 2.86
Print Wikipost
Like Tree30Likes
Old 11-19-2015, 08:52 AM   #91
Suspended
Trader Rating: 61 (100%+)
As a massive negative nancy, I have to say this car is impressive.
Very impressive.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 11-19-2015, 12:59 PM   #92
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I've always been a big fan of the Xray touring cars... about time they bring that legendary quality to the 1/10th scale 2wd buggy market. I'm excited to see how this runs.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-19-2015, 01:08 PM   #93
ChrisP's Avatar
Send a message via Yahoo to ChrisP
TeamXray.com
Team Tekin
ChrisP is offline   Reply With Quote
Old 11-19-2015, 01:25 PM   #94
fullsyzz's Avatar
Trader Rating: 103 (100%+)
Will there be a carpet edition?
fullsyzz is offline   Reply With Quote
Old 11-19-2015, 01:49 PM   #95
ChrisP's Avatar
Dirt and Carpet editions were already confirmed in the Neobuggy interview....
That being said....arrival of the exterior packaging is a nice sign...
TeamXray.com
Team Tekin
Old 11-19-2015, 01:57 PM   #96
OriginalDonk's Avatar
Trader Rating: 41 (100%+)
Am I interpreting the photos right in assuming these are the three configurations referred to previously?
1) Laydown tranny 3 gear
2) Standard tranny 4 gear
3) Standard tranny 3 gear
Looks like most of the cars they're holding are standard tranny 4 gear with the spur location being the dead give away? Not completely sure on the standard tranny 3 gear.
OriginalDonk is offline   Reply With Quote
Old 11-19-2015, 02:04 PM   #97
ChrisP's Avatar
MY expectation is that the full presentation should be going live soon...however, the amount of review, clean-up, editing and multi-lingual translations that go into the product info presentations can sometimes cause delays...
Based on Martin's interviews I'm anxious to see what features they have designed into this kit!
TeamXray.com
Team Tekin
Old 11-19-2015, 02:11 PM   #98
Just re-read the interview on Neobuggy. Looks like you can run the layshaft in either direction to get 3 or 4 gear. Interesting that all of the standard "dirt" tranny kits are configured with the spur on the standard 4 gear side.
Look forward to hearing more.
Old 11-19-2015, 02:30 PM   #99
Id hazard a guess from looking at the pictures of the two gearboxes together that the 3 screws on the mid gearbox are passing through a spacer and that it will be case of flipping the layshaft around, swapping out the two smaller idlers for a bigger one and attaching the motor plate to the opposite side for the 3 gear mid Nothing radical it's what Durango did with the dex210
The low gearbox will be 4 gear same as a yz2
TLR 22 3.0
TLR 22 3.0SCT
Hobbywing
Sanwa
losi8lunie is offline   Reply With Quote
Old 11-19-2015, 08:42 PM   #100
Jack Smash's Avatar
Trader Rating: 29 (100%+)
LOL..... why are you stocking the XB2 thread?
Jack Smash is offline   Reply With Quote
Old 11-19-2015, 10:13 PM   #101
Trader Rating: 16 (100%+)
Why are you stocking fullsyzz stocking the xb2 thread?
krawlingxj is offline   Reply With Quote
Old 11-19-2015, 10:34 PM   #102
HSV427's Avatar
Trader Rating: 22 (96%+)
Originally Posted by avaldes View Post
Multiple gearboxes = cool feature!
Looks like they learnt from yokomo and the yz2. If you want to use the yz2 on loose clay you have to make a bmax 2 conversion which is a giant headache, im so happy xray gives you 2 options in the box its why i love xray, And nobody holds a gun to your head to upgrade every year thats your choice and people have to remember XRAY is a business first and for most and they have a massive out lay, and massive over heads, and if you feel you need to upgrade then XRAY'S marketing department is doing there job.
Serpent 988, OS speed shimo edition, Serpent 977 35th anniversary. OS speed shimo edition Serpent 977 evo2, Novarossi Mito WC35 2017, Shepherd Velox, O.S Speed r2102, Motonica p81rs2, REDS Racing M7 WCS V3.0, , CM 1/8 INFINITY O.S Speed 2103.
HSV427 is offline   Reply With Quote
Old 11-20-2015, 02:29 AM   #103
BentKa's Avatar
Bent
BentKa is offline   Reply With Quote
Old 11-20-2015, 05:56 AM   #104
How soon until we see the dirt edition?!
Hinecken is offline   Reply With Quote
Old 11-20-2015, 06:30 AM   #105
Trader Rating: 18 (100%+)
I was told by a team driver early January or maybe late December.
Dear Santa...
iTz Nicholas72 is online now   Reply With Quote
