    Hide Wikipost
Old 12-26-2016, 07:51 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Xray XB2 2WD Buggy Thread
Last edit by: dgrobe2112
Instruction manuals: (C/O BentKa)
Xray XB2 Carpet Edition Instruction Manual
http://www.teamxray.com/xb2/2016/dow...ual_v2_low.pdf
Xray XB2 Dirt Edition Instruction Manual
http://www.teamxray.com/xb2/2016/dow...w.pdf?update=2
BentKa: Carpet Edition 4 gear to 3 gear laydown conversion parts:
  • Gearbox #323014
  • Motorplate #324012
  • 36T idler gear #324236
  • Brace for waterfall #324031
Socket: Bodies Available:
Xray has two OEM bodies, the .75mm and the .50mm light weight:
light weight: https://www.amainhobbies.com/xray-xb...329701/p492942
OEM .75mm: https://www.amainhobbies.com/xray-0....329700/p477762
Also, I've fitted the yz2 body, both the light and regular fit fine, just make your own cut lines:
https://www.amainhobbies.com/yokomo-...z2-101/p417674
[i] J Concepts S2 Body [i]
Penguin Racing makes a high grip body that fits the DE and CE:
http://www.ebay.com/itm/X-Ray-Xb2-Hi...oAAOSw1S9WewHV
Socket: Wheel fitment:
According to some, you'll require different offset rear hexes to use B5M wheels. According to my Hudy setup board, B5M wheels are the same offset. I measured the overall width of the car with XB2 wheels, and then again with B5M wheels, same measurement.
On the front, B5M wheels were 1.5mm wider. Xray offers hexes to reduce width -.75 on each side, or you could spend 3-5 minutes and sand your OEM hexes down .75mm.
edit by dgrobe2112
here are the hubs for losi and AE
for AE Front 365354 -0.75
for Losi rear 365358 +3.00 (4 stripe)
for AE rear 365359 +3.75 (5 stripe)
Socket: Flex and the XB2:
Flex screws are as follows:
Plastic bulkhead between motor and waterfall. Can remove screw in chassis, or remove bulkhead altogether.
Waterfall has 4 screws, can remove the inner two or outer two. IIRC, removing the inner two provides more flex, and thus more bite.
Removing the battery brace. This gives a tremendous amount of flex on the middle of the car, and can sometimes be inconsistent. I do this for outdoor racing on low bite. I like the feel over the 4 gear in 17.5 racing, since the 4 gear will take some snap away off the corner.
Rear C block - has inner and outer screws. I haven't played with this, as it's a crucial pivot point of the car.
Medium arms and towers -> I don't believe the carpet car has the rear medium tower available, however the DE DOES have an optional hard part. I think the hard parts are more consistent, especially when it gets hot (90+ degrees F). However, the medium parts do NOT break unless you're severely talented. They also don't wear out.
Socket: Avid/Schelle Slipper mod:
Credit to WillS, Matt Trimmings, and myself for figuring this out months ago.
Parts you'll need:
B5M V2 3gear compatible top shaft.
TKO Special 5x13x5 bear OR 5x13x6 bearing Either can work. This replaces the spur side bearing on the top shaft.
5mm shims, same shims used in 1/8th scale clutch bells. Look for protek .1mm and .2mm kit.
Avid or Schelle b5m top shaft kit, with spur gears of your choosing. (DE can't handle a 69, the CE can)
Shimming: You'll need to install the bearing in the front portion of the removable piece for the shaft. Make sure the bearing is pushed all the way in. With the TKO bearing, you'll need to shim approximately 1.4mm on the front side of the top shaft. Roughly .3-.5mm with the other bearing. This is a "feel" and tolerance setting. I urge you to watch videos about setting clutch bell play in 1/8th scale to get an idea of what yield you want for end play. Too tight, it'll eat bearings.
Outside of trans case: Use Avid/Schelle top shaft spacer plus .2mm shim to offset slipper from motor plate perfectly. Install slipper as instructed, and use Avid/Schelle spring and XB2 slipper nut.
- NEW - Schelle now sells Xb2 Topshafts. They include a spacer, so no need for shims in gearbox, and comes with the smaller bearing. Both methods work.
Socket: Yokomo Differential or MIP pucks:
Credit to: WillS for figuring out pucks, and as well fitting the Losi 22 diff with the same mods.
Parts needed: Yokomo Bmax2 or YZ2 complete diff OR Mip PUCKS outdrives
Xb2 diff gear
Bmax2 V3 Worlds rear dog bones, or Bmax 2 pucks dog bones
You'll use XB2 axles, and will require no other mods for the axles or dog bones.
You'll need .2mm outdrive/diff shims. Shim approximately .5mm on each side of the diff, behind the bearings. The top portion of the transmission is what "sets" the diff in place, not the bottom half. A little play back and forth is fine, the stock diff has some play from the factory.
dgrobe2112: CE to DE conversion:
along with the parts needed.. you MUST have these following hardware, or it wont work
https://www.teamxray.com/xb2/2016/do...conversion.pdf
(3) XRAY 902340 M3x40 button head screws. these are the screws that mount the motor mount to the tranny
(4) XRAY 903322 M3x22 counter sunk screws. these are for the rear diff case, to mount to the chassis. i think i used some M3x18 and they worked ok.
Socket: Best method for setting up the XB2 ball diff:
The XB2 diff is stellar when setup correctly. The spring is too short and soft, allowing the diff to slip. You'll need to glue the rings to the outdrives with just a drop of CA, then add a 1mm shim between the spring and the outdrive. This preloads the spring and stops the diff from slipping so easily.
OR, you can run the AE diff spring, which is both slightly longer, and stiffer. The overwhelming issue is the stock spring allows the nut to bottom out on the outdrive before the diff is tight enough.
This shim:
https://www.amainhobbies.com/xray-al...a303122/p12070
This diff spring (don't need a shim, then.)
https://www.teamassociated.com/parts...thrust_spring/
Functional Aftermarket parts: (Not just bling!)
Servo Horn: (The B5M sized horns are too short to get full throw)
https://www.amainhobbies.com/protek-...800-bk/p273496
Socket: Exotek has a full suite of parts, some bling, some not. Here's a list (all fit DE and CE, unless otherwise noted):
Titanium front axles: http://www.exotekracing.com/xb2-titanium-front-axles-2/
Rear Hanger, HD (Adds 4 grams): http://www.exotekracing.com/xb2-rear...75-heavy-duty/
Brass C block, 18 grams added: http://www.exotekracing.com/xb2-rear...-brass-weight/
Alloy front camber mount: http://www.exotekracing.com/xb2-fron...er-mount-7075/
Carbon Fiber Chassis: http://www.exotekracing.com/xb2-carb...m-plate-2-5mm/
Alloy rear hubs:http://www.exotekracing.com/xb2-allo...ub-set-2-7075/
Alloy servo mounts, allow for use of LP servo:http://www.exotekracing.com/xb2-xb4-...-alloy-1-pair/
Titanium shock mounts: http://www.exotekracing.com/xb2-xb4-...shock-posts-2/
Slipper Eliminator: http://www.exotekracing.com/xb2-direct-spur-mount/
Xray eliminator is #324100
dgrobe2112: 2016-2017 new 3 gear laydown
Gearbox #323014
Motor plate #324012
dgrobe2112: Xray Spring Rate Conversion:
front C WHT
368174 2 str 0.65-0.85 3.71-4.85
358184 2 dot 0.65 3.71
368185 3 dot 0.72 4.11
368186 4 dot 0.80 4.57
Rear
368273 2 str 0.35-0.45 2.00-2.57
368284 1 Dot 0.35 2.00
368285 2 Dot 0.40 2.28
368286 3 Dot 0.45 2.57
368287 4 Dot 0.50 2.86
Print Wikipost
Like Tree40Likes
Old 01-03-2016, 10:43 PM   #856
STLNLST's Avatar
Trader Rating: 21 (100%+)
Drove the carpet version on our dirt/clay track today. It feels just like the YZ-2 to me. It did jump slightly better though. I'd love to run the dirt version or one with my own equipment in it. The body looks killer in person too. Good job on the design of it.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-04-2016, 12:35 AM   #857
Lazi's Avatar
Originally Posted by hairymuffin View Post
Already been covered, they say no because of the clearance over the gear, Bentka used the yoke body for early prototypes but still not a good fit he stated...Another month or so and you will see more options, stock one looks good...
I'm curious about the dirt edition,if it will have a gear cover/ different body? Not every one races indoors, and will the body keep out small debris?
the yokomo will fit.
it have to be a litle trim on the front but no problem at the gear area at all!
i will post pictures with a marked body, how to cut!
Lazi
Sponsored by:TEKNO RC-RC HOBBIES-JCONCEPTS-EXOTEK RACING-RADIOPOST-KALGARD-BOCA BEARING
Lazi is offline   Reply With Quote
Old 01-04-2016, 01:34 AM   #858
BentKa's Avatar
Dirt Edition will have a gear cover
We've raced outdoors for over a year not using a gear cover with the early bodies that covered less than the now stock body without issues.
You will have to cut the Yokomo body to sit higher in order to get it to clear the spur area.
The XB2 body is a much better fit (obviously), handles better on track and looks better IMO, so why you would want a YZ2 body on your XB2 I don't get
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 01-04-2016, 07:52 AM   #859
lewis4x4's Avatar
Default XB2 Bodies?
Anyone know of a place in the USA where the XB2 Carpet Edition Bodies are in stock?
Brian "B-Daddy" Lewis
XRay, Proline, Absolute Hobbyz, RC America, Airtronics, Murnan Modified Motors, Team Trinity, Kustom RC Graphics, Schelle Racing, MIP, LFR, StickIt1 Racing, Team Lewis Racing
lewis4x4 is offline   Reply With Quote
Old 01-04-2016, 07:54 AM   #860
gticlay's Avatar
I don't think any extra bodies came in with that first shipment - I ordered a body with the kit and the body didn't ship.
Thanks to Lunsford, Proline, Schelle, Xray, RCAmerica, and SMC for your support.
gticlay is offline   Reply With Quote
Old 01-04-2016, 07:55 AM   #861
lewis4x4's Avatar
I sent my Body off to Painter and I am not sure I will get it back i time for the First Series race... #NotGood
Old 01-04-2016, 10:42 AM   #862
Trader Rating: 33 (100%+)
Bent, can you post a picture of the XB2, with your wire routing? you mentioned you dont run your wires down the side..
thanks
Daniel Grobe
Sponsors:
Proline Racing / RC America / Xray
dgrobe2112 is offline   Reply With Quote
Old 01-04-2016, 10:50 AM   #863
OK, so i have been working on a Wheel/adapter list.. going through this forum, and finding what people are doing.. i still need AKA, and TLR front offsets.. if anyone has that info..
Wheel/adapter
XRAY Front/ 0mm 365353 (STOCK)
XRAY Rear/ +2.25mm 365357 (STOCK)
AVID Front/ i believe it needs -1.5 each side, can someone confirm
AVID Rear/ +1.50 365356
SCHU Front/ 0mm 365353 (STOCK)
SCHU Rear/ +2.25mm 365357 (STOCK)
PL B4 Front/ i believe it needs -1.5 each side, can someone confirm
PL B4 Rear/ +1.50 365356
PL B5 Front/ -0.75mm 365354
PL B5 Rear/ +3.00 365358
AKA Front/
AKA Rear/ +1.50 365356, plus 0.75 wheel shim
TLR Front/
TLR Rear/ +1.50 365356, plus 0.75 wheel shim
anyone feel free to correct anything i have on here.. im just putting this info from other post on this thread.. nothing is confirmed..
If anyone has more information, please let me know. i been working on a sheet for this, and can create a PDF, to share with everyone if they want.
Daniel Grobe
Sponsors:
Old 01-04-2016, 05:05 PM   #864
RC America's Avatar
The 2nd batch of XB2 Carpet Editions just arrived, so dealers will have them back in stock in the next few days. We also received the first batch of bodies with this shipment. As stated above, they did not ship with the initial batch of kits, so this is the first wave to hit the States.
- Bryan
RC America is offline   Reply With Quote
Old 01-04-2016, 05:45 PM   #865
- Bryan
Is the ball diff with this batch?
jswo is offline   Reply With Quote
Old 01-04-2016, 06:58 PM   #866
avaldes's Avatar
I wouldn't hold your breath on that one!
avaldes is offline   Reply With Quote
Old 01-04-2016, 07:12 PM   #867
I'm not but would be super happy if it did
Old 01-04-2016, 10:04 PM   #868
3srcracing's Avatar
Trader Rating: 25 (100%+)
For those who are interested, went back to the shock setup Brent suggest. Pretty dang good, definetly need just a little bit stiffer spring. Ordered 2 dot, should be money after that, I'll keep you posted.
1.6x2 500cst
1.7x2 32.5wt Associated
1dot all the way around
A Main Hobbies | Protek R/C | Team Powers R/C | Cheater Racing
3srcracing is offline   Reply With Quote
Old 01-05-2016, 12:25 AM   #869
Lazi's Avatar
Bent
the only reason because i cant get the xb2 body anywhere!
my friend ordered one from europe and its cost for him $45 with shipping
Lazi
Old 01-05-2016, 09:00 AM   #870
RCAmerica said they got bodies with this order.. so.. they should be available soon..
Daniel Grobe
Sponsors:
Currently Active Users Viewing This Thread: 10 (1 members and 9 guests)
justinchambers
