Xray XB2 2WD Buggy Thread >
Like Tree331Likes
    Hide Wikipost
Old 05-04-2019, 06:44 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Xray XB2 2WD Buggy Thread
Last edit by: dgrobe2112
Instruction manuals: (C/O BentKa)
Xray XB2 Carpet Edition Instruction Manual
http://www.teamxray.com/xb2/2016/dow...ual_v2_low.pdf
Xray XB2 Dirt Edition Instruction Manual
http://www.teamxray.com/xb2/2016/dow...w.pdf?update=2
BentKa: Carpet Edition 4 gear to 3 gear laydown conversion parts:
  • Gearbox #323014
  • Motorplate #324012
  • 36T idler gear #324236
  • Brace for waterfall #324031
Socket: Bodies Available:
Xray has two OEM bodies, the .75mm and the .50mm light weight:
light weight: https://www.amainhobbies.com/xray-xb...329701/p492942
OEM .75mm: https://www.amainhobbies.com/xray-0....329700/p477762
Also, I've fitted the yz2 body, both the light and regular fit fine, just make your own cut lines:
https://www.amainhobbies.com/yokomo-...z2-101/p417674
[i] J Concepts S2 Body [i]
Penguin Racing makes a high grip body that fits the DE and CE:
http://www.ebay.com/itm/X-Ray-Xb2-Hi...oAAOSw1S9WewHV
Socket: Wheel fitment:
According to some, you'll require different offset rear hexes to use B5M wheels. According to my Hudy setup board, B5M wheels are the same offset. I measured the overall width of the car with XB2 wheels, and then again with B5M wheels, same measurement.
On the front, B5M wheels were 1.5mm wider. Xray offers hexes to reduce width -.75 on each side, or you could spend 3-5 minutes and sand your OEM hexes down .75mm.
edit by dgrobe2112
here are the hubs for losi and AE
for AE Front 365354 -0.75
for Losi rear 365358 +3.00 (4 stripe)
for AE rear 365359 +3.75 (5 stripe) or add 1.5mm carbon avid spacers
Socket: Flex and the XB2:
Flex screws are as follows:
Plastic bulkhead between motor and waterfall. Can remove screw in chassis, or remove bulkhead altogether.
Waterfall has 4 screws, can remove the inner two or outer two. IIRC, removing the inner two provides more flex, and thus more bite.
Removing the battery brace. This gives a tremendous amount of flex on the middle of the car, and can sometimes be inconsistent. I do this for outdoor racing on low bite. I like the feel over the 4 gear in 17.5 racing, since the 4 gear will take some snap away off the corner.
Rear C block - has inner and outer screws. I haven't played with this, as it's a crucial pivot point of the car.
Medium arms and towers -> I don't believe the carpet car has the rear medium tower available, however the DE DOES have an optional hard part. I think the hard parts are more consistent, especially when it gets hot (90+ degrees F). However, the medium parts do NOT break unless you're severely talented. They also don't wear out.
Socket: Avid/Schelle Slipper mod:
Credit to WillS, Matt Trimmings, and myself for figuring this out months ago.
Parts you'll need:
B5M V2 3gear compatible top shaft.
TKO Special 5x13x5 bear OR 5x13x6 bearing Either can work. This replaces the spur side bearing on the top shaft.
5mm shims, same shims used in 1/8th scale clutch bells. Look for protek .1mm and .2mm kit.
Avid or Schelle b5m top shaft kit, with spur gears of your choosing. (DE can't handle a 69, the CE can)
Shimming: You'll need to install the bearing in the front portion of the removable piece for the shaft. Make sure the bearing is pushed all the way in. With the TKO bearing, you'll need to shim approximately 1.4mm on the front side of the top shaft. Roughly .3-.5mm with the other bearing. This is a "feel" and tolerance setting. I urge you to watch videos about setting clutch bell play in 1/8th scale to get an idea of what yield you want for end play. Too tight, it'll eat bearings.
Outside of trans case: Use Avid/Schelle top shaft spacer plus .2mm shim to offset slipper from motor plate perfectly. Install slipper as instructed, and use Avid/Schelle spring and XB2 slipper nut.
- NEW - Schelle now sells Xb2 Topshafts. They include a spacer, so no need for shims in gearbox, and comes with the smaller bearing. Both methods work.
Socket: Yokomo Differential or MIP pucks:
Credit to: WillS for figuring out pucks, and as well fitting the Losi 22 diff with the same mods.
Parts needed: Yokomo Bmax2 or YZ2 complete diff OR Mip PUCKS outdrives
Xb2 diff gear
Bmax2 V3 Worlds rear dog bones, or Bmax 2 pucks dog bones
You'll use XB2 axles, and will require no other mods for the axles or dog bones.
You'll need .2mm outdrive/diff shims. Shim approximately .5mm on each side of the diff, behind the bearings. The top portion of the transmission is what "sets" the diff in place, not the bottom half. A little play back and forth is fine, the stock diff has some play from the factory.
dgrobe2112: CE to DE conversion:
along with the parts needed.. you MUST have these following hardware, or it wont work
https://www.teamxray.com/xb2/2016/do...conversion.pdf
(3) XRAY 902340 M3x40 button head screws. these are the screws that mount the motor mount to the tranny
(4) XRAY 903322 M3x22 counter sunk screws. these are for the rear diff case, to mount to the chassis. i think i used some M3x18 and they worked ok.
Socket: Best method for setting up the XB2 ball diff:
The XB2 diff is stellar when setup correctly. The spring is too short and soft, allowing the diff to slip. You'll need to glue the rings to the outdrives with just a drop of CA, then add a 1mm shim between the spring and the outdrive. This preloads the spring and stops the diff from slipping so easily.
OR, you can run the AE diff spring, which is both slightly longer, and stiffer. The overwhelming issue is the stock spring allows the nut to bottom out on the outdrive before the diff is tight enough.
This shim:
https://www.amainhobbies.com/xray-al...a303122/p12070
This diff spring (don't need a shim, then.)
https://www.teamassociated.com/parts...thrust_spring/
Functional Aftermarket parts: (Not just bling!)
Servo Horn: (The B5M sized horns are too short to get full throw)
https://www.amainhobbies.com/protek-...800-bk/p273496
Socket: Exotek has a full suite of parts, some bling, some not. Here's a list (all fit DE and CE, unless otherwise noted):
Titanium front axles: http://www.exotekracing.com/xb2-titanium-front-axles-2/
Rear Hanger, HD (Adds 4 grams): http://www.exotekracing.com/xb2-rear...75-heavy-duty/
Brass C block, 18 grams added: http://www.exotekracing.com/xb2-rear...-brass-weight/
Alloy front camber mount: http://www.exotekracing.com/xb2-fron...er-mount-7075/
Carbon Fiber Chassis: http://www.exotekracing.com/xb2-carb...m-plate-2-5mm/
Alloy rear hubs:http://www.exotekracing.com/xb2-allo...ub-set-2-7075/
Alloy servo mounts, allow for use of LP servo:http://www.exotekracing.com/xb2-xb4-...-alloy-1-pair/
Titanium shock mounts: http://www.exotekracing.com/xb2-xb4-...shock-posts-2/
Slipper Eliminator: http://www.exotekracing.com/xb2-direct-spur-mount/
Xray eliminator is #324100
dgrobe2112: 2016-2017 new 3 gear laydown
Gearbox #323014
Motor plate #324012
dgrobe2112: Xray Spring Rate Conversion:
front C WHT
368174 2 str 0.65-0.85 3.71-4.85
358184 2 dot 0.65 3.71
368185 3 dot 0.72 4.11
368186 4 dot 0.80 4.57
Rear
368273 2 str 0.35-0.45 2.00-2.57
368284 1 Dot 0.35 2.00
368285 2 Dot 0.40 2.28
368286 3 Dot 0.45 2.57
368287 4 Dot 0.50 2.86
Print Wikipost
Old 03-20-2016, 10:08 AM
  #2071
Originally Posted by WillS
Teaser...
Was that done with a little handy work? Or the suggested b5m top shaft??
jake alton is offline
Old 03-20-2016, 10:15 AM
  #2072
WillS's Avatar
Trader Rating: 32 (100%+)
No handy work, bolt in swap.
WillS is offline
Old 03-20-2016, 10:16 AM
  #2073
Front spring rate is c=0.70. What does that equate to in lbs. rear is c=0.53 any conversions. And what is C??
Old 03-20-2016, 10:18 AM
  #2074
Bolt in swap?? Then assumed b5m top shaft. Or yokomo or kyosho slipper?
Old 03-20-2016, 11:09 AM
  #2075
Suspended
Trader Rating: 61 (100%+)
Avid Triad slipper. B5M v2 top shaft.
Socket is offline
Old 03-20-2016, 02:30 PM
  #2076
gticlay's Avatar
Trader Rating: 14 (100%+)
Oh, SWEET! I can run the Schelle slipper and gears. That'll be good for those wanting to run 64 pitch too.
gticlay is offline
Old 03-20-2016, 03:46 PM
  #2077
Suspended
Exactly...
Socket is offline
Old 03-20-2016, 05:45 PM
  #2078
avaldes's Avatar
I would guess that spring rate is in Newtons/millimeter, which would convert to about 4 and 3 lbf/in. But that sounds a little high.
avaldes is offline
Old 03-20-2016, 06:52 PM
  #2079
fast-ho-cars's Avatar
will this work on a DE?
fast-ho-cars is offline
Old 03-20-2016, 07:10 PM
  #2080
Suspended
Originally Posted by fast-ho-cars
Yea, it'll work.
I tried one back with my B5M in 17.5. It's horrible at hobbytown - especially if the watering isn't up to par.
Socket is offline
Old 03-20-2016, 07:56 PM
  #2081
It works well.
Old 03-20-2016, 08:47 PM
  #2082
Trader Rating: 36 (100%+)
Which one do you use?
1. http://www.amainhobbies.com/rc-cars-...c91606/p404377
2. http://www.amainhobbies.com/rc-cars-...hl1099/p451009
raved007 is offline
Old 03-20-2016, 09:17 PM
  #2083
Suspended
ASC91606
Socket is offline
Old 03-20-2016, 09:29 PM
  #2084
JAE
Trader Rating: 30 (100%+)
Everyone must still be building. I've only seen a couple people with detailed reviews (QDRHORSE, thx). Can anyone else opine on the performance in relation to a B5M? How about Dirt vs. Carpet? Looks great
JAE is offline
Old 03-21-2016, 07:24 AM
  #2085
13Maschine's Avatar
I'm still building my CE up, had to pause and wait for a set of Lunsford Titanium Screws. So far it's a really nice build, I've completed the transmission and shocks, not much else I can do without screws though. I do wish they would have given machined pistons though, pistons on a tree aren't generally very round and you always need to sand a bit to make them smooth, causing flat spots.
Overall the car seems really nice and I am really impressed with the design. Nice to see a motor mount that is fully secure by locking it into the waterfall in front of the motor. It's awesome that it comes stock with rear alum suspension holders with eccentric bushings. The transmission has alignment pins to keep your gear mesh in check. Quick swap diff? AWESOME.
Has anyone upgraded their pistons? I was considering the Avid 2+2 setup...
13Maschine is offline
