Carisma Racing 4XS Thread
#106
I’ve got a couple of pics, but they keep failing to upload when I try to post them
#107
#108
I think there must be a size limit for pictures, I ran them through the PC & made them smaller.
#109
#110
I normally run 40-42.5 in the front, with a 2x1.6mm piston & 30wt with a 2x1.7mm piston in the rear.
These are the blank pistons https://www.dms-racing.com/index.php...ategory_id=548
Or there are some new 2hole moulded ones https://www.dms-racing.com/index.php...ategory_id=548
I drilled the blank ones out before the others were available.
#111
blank pistons are available on the carisma website i think. i couldnt get any locally so i just glued and drilled as needed, took all of 5 mins to do
#112
Nice find, guys. Wish they would adapt to a common piston so aftermarket choices would be there.
#113
Do any of you guys have a shock piston bore or piston size? The thickness seems thinner than most others at the e clip.
#114
I don't think there is a need as they make several options now pre drilled or blanks or mod the kit ones....the short course world youtube video has the part numbers that he used to change pistons and shafts
#115
Factory ones would be best. Although some others interchange as noted, they may be smaller in diameter and contribute to some binding or reduced efficiency. Had this on my xb2 with associated pistons. That YouTube video didn't give any details on fit, just part numbers. May work fine with thicker oils than stock with stock pistons.
#116
Can the steering servo be mounted on either side? Anyone weigh and check weight distribution between the battery types?
#117
Yes I believe the servo can go on either side...and I only run shorty Batts
#118
Yes, the servo can be fitted either side, I built mine opposite to the instructions & put it on the right hand side of the car, so it was layed out the same as the B64 I was running before.
Haven’t got any saddles to check for different weight.
#119
Is a 2018 model coming?
#120
