Hobbywing 3.1/v10 vs Orion R10.1/VTS2 vs Reedy Blackbox 410r/sonic mach3
Hi all,
I need to buy new electronics for my 2wd and 4wd buggies and I am not sure which one of the following combos is the best one:
- Hobbywing 3.1/v10
- Orion R10.1/VTS2
- Reedy Blackbox 410r/ Sonic mach3
Which would be the smoothest and easy to setup combo?
Any inputs about pros and cons would be really appreciated.
Thank you very much in advance!
- Hobbywing 3.1/v10
- Orion R10.1/VTS2
hobbywing
pros-cost, smooth, easy to setup with program card
cons-some have had issues with warranty/customer support (i've had good experiences)
orion
pros- smooth, easy to setup with program card
cons-cost, horizon is hit or miss with customer service
reedy
pros-customer service is top notch
cons- people have had issues with blackbox so you may need that customer support
overall i'd go with hobbywing. great cost/performance. make sure you go with authorized us dealer to get the best chance at customer support should you need it.
orion
reedy
Thank you very much for the reply!
I am in Europe, but I have HW, Orion and Reedy/AE very close, so it should not be a problem.
I really like the HW combo but I have heard that the new Orion is really really good as well. Which one of those is smoother?
Thank you!
Thank you!
If I'm not mistake HW produce ESC as OEM for Orion too.
Orion just develops his own software.
Please someone correct me if I'm wrong.
PC Board quality?
The Orion r10.1 advertises having a thicker pc board that can take crashes better. Does the HB 3.1 use the same internal hardware like the claimed tougher r10.1 board?
Edit: thicker pcb is for lower IR not crash sustainability
Sorry... The thicker pcb isn't marketed for crashes it's marketed for lower resistance.
The HB3.1 has some awesome features the Orion doesn't have and vice versa.
Hobbywing V3.1 ESC
Orion is just too expensive and Reedy Blackbox can be (can ... depending on your own mileage) a bit more finnicky with motor sensors.
As for motors, I'm quite partial to the Muchmore Fletas or the Team Powers Plutonium V2 if running mod. Have no idea about stock because I've never run stock in buggy.
Hobbywing V3.1 ESC
I love the v3.1 function of holding the break for 7 secs to turn off. Wish the orion had that. The external switch mist be to accommodate the second sensor port.
I hate the function of holding the brake to turn off, a few times I have crashed in practice and my natural instinct is to hold the brake while I await a marshall or make my way down the stand. Numerous times a marshall has flipped me over only to realize that I have turned the car off...
Having experience with the Reedy and the HW I would recommend the Reedy. I like how the team posts setup sheets for the esc and, to me at least, I find it easier to work through the setup box and make changes with the Reedy.
I have quite a few 3.1s and never knew that function existed......turning off after 7 seconds.....that is awesome!!
You know, I'm kind of on the fence about the ESCs. They're all really good these days. I'm a hobbywing guy all the way but I'd use an Orion. The Blackbox is exactly that to me, a black box. I dunno. I've had one and it worked fine. It had a little too much "stuff" on it in terms of programming but I'd have no issue using one.
