Proper battery connections ??
My current setup has a hard-case Turnigy Lipo with the bullet connectors that plug down into the battery from the top.
What I did a long time ago was soldered those bullet connectors onto the wires off of the ESC. I then just basically directly plug the ESC right into the battery instead of having an intermediary connection point. Is that bad form?
I've seen a lot of guys that have these same batteries that have the bullet connectors that plug right down into the battery and then they come out of those to a deans plug.
Is that really necessary? Isnt the point to be able to disconnect quickly? If so - is pulling the bullet plug out of the battery pack not sufficient?
Generally, racers go with bullets directly to the pack. there are less points of failure. It's a higher risk doing it though because it's super easy to reverse polarity and fry your speed controller. If you are new or are worried about reversing polarity just throw a deans plug on. They are 100% fool proof.
R/C Tech Elite Member
The least amount of things you have soldered between your battery and esc the less resistance, the less of chance of a bad solder joint and less of a chance of failure you'll have.
At some point, we are all rushed to make a qualifier and the room for error increases. If the negative wire will ONLY reach the negative terminal of the battery, you won't be able to wrongly plug BOTH battery cables in the wrong holes at once. You'll recognize the error before it's too late, as the "other" wire won't reach.
And if possible, make either the positive or negative wire from the ESC long enough to reach its correct position but short enough to NOT be able to plug in the incorrect location with the battery strapped into the car.
You still have to watch that you plug the bullets into the Deans without crossing them. Unplug from the Deans every time and should be no issues. I soldered female bullet ends onto the backside of a Deans so I can use either battery with esc having bullets soldered on. Still have to watch plugging the bullets into the deans but after that, just unplug the deans.
Haha, yeah I remember back in the late 90's just soldering my Novak Cyclone DIRECTLY to my battery pack for each run. Just HAD to get every last bit of juice possible. But also meant I put myself at risk of a bad solder joint if done in a rush.
I always soldered an extra battery bar at each end of the pack, bent it in an L shape, and that's what I soldered the ESC wires to. Everyone did it that way.
