jr xr2i radio problem i think
i have jr xr2i radio in my losi xxx-t when i take a little off camber jump . my radio settings get reversed . only the thr& brk settings is this a receiver prob or esc it is a gm racing v3 ..
I used to have the same setup and the same problem. I dumped the V3 speedo and went with a used LRP v7.1. The problem went away. I guess that can attribute it to the speed control causing the problem. I still have the radio and servo and no problems have ever come up since then. If you're looking for an inexpensive upgrade look for the DuraTrax speed controls. The Streak is a good inexpensive upgrade. Check it out at Tower Hobbies.
Good luck.
Good luck.
thanks for the info other than that prob i like the truck.a new esc will be on the way
