Rx8 gen2 case swap?
Rx8 gen2 case swap?
I asked in the official Tekin rx8 esc thread but have had no reply in over a week. I'm just about to put an order in for a rx8 gen 2 buggy combo and I want to swap the white case out for a black one and I'd like to order the case at the same time I'm wanting to know if anyone can tell me if this is a straight forward swap or if it's more involved than a simple few screws and swapping them out such as de-soldering and so on
Tia
Tia
Easy as. 4 screws and unclip the circuit board and put it into the new case. It's easier if your wires are not soldered so the slide through the holes.
It's a piece of piss really 😆
Tia
Tia
I've also found that enlarging the screw holes in the new case slightly makes it a far easier job. I used a pin vise with a bit for drilling pistons- I think it was a 1.15mm bit but its been a few months since I did the case swap.
It's simple enough. The key is using a good quality #0 phillips screwdriver and not rush taking the screws in and out.
Thanks to all I will go ahead and put my order in now
