Team Associated's new RC8B3e
#1217
#1218
I know it's a bit expensive but the reedy 5200 is the perfect buggy battery. With the body on I have close to 10mm of room between the body and battery and it lasts for every bit of 15-17 minutes before cutoff. The top dementions are the reedy and the bottom are the 5200 smc. It's 10mm shorter.
Capacity: 5200mAh
Voltage: 14.8V (4S)
Dimensions (mm): 138.5 x 46.0 x 38.2
Max. Charge Current: 10.2A (2C)
Discharge: 55C cont., 120C burst
Weight: 447gr
Dimensions
Length 139mm / 5.47in
Width 48mm / 1.89in
Height 48mm / 1.89in
Weight 516gr /18.2oz
Capacity: 5200mAh
Voltage: 14.8V (4S)
Weight: 447gr
Dimensions
Width 48mm / 1.89in
#1219
What is the screw size to hold on the front piece of the body? I cant seem to find it in the instructions. Thanks for the help.
#1220
3x8. Be careful because if it's too long it'll go through the case. I did it.
#1221
For anyone that has them, do I need different shock standoffs if I order the ae carbon towers??
#1222
No you do not need different standoffs
#1223
Fantom makes a low profile battery as well, they go for $72 I'll probably pick one up here soon.
#1224
Just ordered a new RC8b3.1e from my local hobby shop to replace my MBX6 eco. Sounds like most are starting with the DNC setup?
#1226
I don't see a 3.1e sheet for the DNC?
Here is the only one I see....
Team Associated RC8B3e - Ryan Cavalieri - Dirt Nitro Challenge - 19-21.02.2016
#1227
#1228
Thanks!!
#1229
Still very happy with this 3.1 after another race day! I'm still trying to feel the car out to nail the setup down but I think it's really close.
#1230
I just picked up the 3.1 and was wondering, anything wonky with the build that you know of? Any misprints, missing parts, etc etc??
