cogging on start? when first squeezing throttle - Tekin RS + Viper 9.5 ; 2wd
I cannot figure out what is going on and seeing if other forum members have experienced this. btw, I went through the gearbox, replaced the two idler gears, went through all bearings, diff, etc... this is on a Associated/Centro c4.2 buggy which i use to run and race indoor. now teaching my two young boys to drive.
anyway, when first squeezing the throttle, there is what sounds like gears (but it is not gears) and a little squeal, i believe from the tekin rs pro esc. this just started happening. I re-programmed using the correct start and end rpm and timing curve (3).... no real changes there. motor is a viper 9.5
any ideas? thanks.
any ideas? thanks.
Btw... watching my boys (5 and 7) learn to drive on the centro is rough. slams into the curb, diff screaming in the grass, etc... lol.
Check all solder joints and sensor wire
