Old 01-28-2017, 07:06 PM   #16
Default tire wheel for Raider XL
'm interested in coping your tire wheel combo. I found the rims, can you tell me the scale and exact Bandito tires you used.
thanks,Rich
dice55 is offline   Reply With Quote
Old 01-28-2017, 11:37 PM   #17
fyrstormer's Avatar
http://www3.towerhobbies.com/cgi-bin...?&I=LXCNZD&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXCNZF&P=7
Check out Fyrstormer's Garage in the Chat Lounge.
fyrstormer is offline   Reply With Quote
Old 02-03-2017, 06:23 AM   #18
Default Tires
Thanks, those are the tires I ordered and received already. Also I ordered the rims from the UK. In the mean time I put those tires on on 1/10 Raider rims. Fit was 98%, not as smug as I hoped. Thanks for all your posts.
Rich
Old 02-03-2017, 09:32 AM   #19
fyrstormer's Avatar
Yeah, the stock Raider rims are slightly larger on the inboard side than the outboard side.
Old 02-03-2017, 09:56 AM   #20
tommynash's Avatar
Very cool
22 3.0 Dirt LD w/ XFactory Brace | Hobbywing Justock | Schuurspeed 17.5 SS | Spektrum S6240 | Sanwa RX-482 | Airtronics MT-4
tommynash is offline   Reply With Quote
Old 02-10-2017, 05:59 PM   #21
fyrstormer's Avatar
First update to this vehicle in months: I replaced the plastic steering assembly with an aluminum one from Hot Racing, to reduce slop in the steering. The plastic parts were starting to get worn out.
I reused one plastic piece from the original servo-saver, the "male" side of the V, so there won't be aluminum grinding against aluminum every time the servo-saver actuates. (the "female" side of the V needs to be aluminum because the plastic one stretches over time.) If you look very closely below, you can see I cut off the tips from the "male" side of the V, to ensure the two pieces would seat together as snugly as possible.
It's a good upgrade. The steering is much more precise now.
Old 04-05-2017, 02:17 AM   #22
fyrstormer's Avatar
A couple small updates: I replaced the stock ball-stud links with Traxxas captured-ball links to eliminate the suspension popping loose, I replaced the stock spur gear with an Associated spur gear and matching slipper pads, and I replaced the outer slipper plate with a SC10 slipper plate so I could use the superior SC10 slipper spring as well.
This lets me put enough pressure on the slipper pads without bottoming-out the stock spring, which only really worked with the sticky stock pads that had a tendency to glue themselves to the plates if the vehicle sat still too long. The Associated slipper pads don't have this problem, but require a stronger spring to work properly. The top-shaft doesn't accommodate the SC10 inner slipper plate, but the stock inner slipper plate works fine because the dimensions of Arrma's slipper assembly are identical to Associated's.
Old 04-05-2017, 01:23 PM   #23
monsterbrad's Avatar
this buggy looks awesome
thanks for all the info as my son wears his out I will start the mod process, but for now its going just fine.
Being thats its bigger its easier for a little one to handle
monsterbrad is offline   Reply With Quote
Old 04-05-2017, 02:05 PM   #24
fyrstormer's Avatar
Thanks! I'm happy with how it turned out. Less-sticky tires might be a good idea to reduce rollovers, but I'm willing to keep taking that risk despite the exposed shock towers.
Old 04-06-2017, 09:18 AM   #25
Default Idler gear washers
When rebuilding the metal gear box, i noticed two washers on either side of the idler gear (the center gear). Following the blx exploded view, these are not show in the assembly. However when i install them, they keep the idler gear planted in the housing and stops it from moving side to side. Did you guys install these or no?
Silomatic is offline   Reply With Quote
Old 04-06-2017, 01:17 PM   #26
fyrstormer's Avatar
This is my personal build thread, so I'm not sure if anyone else is going to reply to your question here. I don't think my metal-gear transmission had shims for the idler gear, but I always shim my transmissions when I put them together, so yes, I did end up using *something* to keep the idler gear from moving around. It shouldn't have a major effect, though; it's the top shaft and the diff that really need to be firmly secured. I just shimmed the idler gear because I like to be thorough.
Old 06-28-2017, 12:33 AM   #27
Can you post part numbers on front shock brace, rear shock brace and everything needed for the rear cv axle swap? I copied your wheel/tire combo, ordered some different shocks but had the dogbones popping out problem so I just ordered aluminum shock caps, solved the caps popping off problem. also did a brushless setup and wheelie bar on mine
Build Complete: Arrma Raider-20170623_211852.jpg
x_doug_x is offline   Reply With Quote
Old 06-28-2017, 07:03 AM   #28
Mine is running good as well...
Its a pretty awesome car for the money..
Wheels from the Kyosho 1/10 baja bug fit on it nicely as well...
The only thing with those rims are when its hot they are a bit flexy
Old 06-28-2017, 08:49 PM   #29
fyrstormer's Avatar
Better to be a bit flexy than a bit brittle.
Old 06-29-2017, 08:00 AM   #30
Are you going to be able to get me part numbers on everything needed for the rear driveshaft upgrade?
