Like Tree4Likes
Old 08-27-2015, 06:23 PM   #46
Razorbelly's Avatar
What would be some good servos to use in this kit and what Tekin truggy motors do people use for some of the biggest tracks?
Razorbelly is offline   Reply With Quote
Old 08-27-2015, 09:16 PM   #47
Trader Rating: 15 (100%+)
I'm going to try a Savox 1270TG on high voltage using a Castle 10 amp bec. (Edit: Actually I'll get the new HW esc with high voltage bec probably) Similar setup that I use in my e-buggy that I'm real happy with.
Figured at one point I'd just run what Lutz uses because I like Futaba, but the servo he uses (S9353HV) is $230. Dang.
Tommygun1 is offline   Reply With Quote
Old 08-28-2015, 01:19 AM   #48
bwillenb's Avatar
Trader Rating: 52 (100%+)
I am going with a HiTec HSB-9370TH servo.
Hopefully I chose wisely.
Would appreciate feedback if I did not.
The most important thing in life is to always be yourself. Unless you can be Batman, in which case, always be Batman.
bwillenb is offline   Reply With Quote
Old 08-28-2015, 09:06 AM   #49
rcgod's Avatar
Trader Rating: 27 (100%+)
That's a good servo but honestly imo for the $ there are better options. This servo is a beast. Compare the specs to the hitec.
http://www.amain.com/rc-cars/protek-...k-170t/p265048
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 08-30-2015, 11:43 PM   #50
bwillenb's Avatar
Horizon now shows them in stock!
Hopefully shipping soon. =)
Old 09-01-2015, 04:32 PM   #51
Trader Rating: 25 (100%+)
i saw on neo-buggy tlr 8ight electric clutch ? what you think ?
taztal3 is offline   Reply With Quote
Old 09-01-2015, 06:15 PM   #52
I want this kit so bad but its the end of outdoor season so not needed
B5M - Hobbywing v3.1 Stock Spec, Team Scream 17.5, Team Scream Battery
B6 - Hobbywing v3.1 Stock Spec, Team Scream 17.5, Team Scream Battery
Ronisonce is offline   Reply With Quote
Old 09-01-2015, 06:23 PM   #53
This new clutch is the bomb diggity! It should work on most cars, due to it essentially being an extension of the motor shaft, and it will be able to smooth out the sugared up twitchy feel of the instant electric power.
Ready, fire, aim!
RC8.2e- 150a 2200kv HW + 1283sg
rcbuggies is offline   Reply With Quote
Old 09-03-2015, 08:19 PM   #54
I wonder what the length is on the battery tray.
(I just bought a E-converted 3.0 and new battery. I got the battery and it's longer than normal. Don't have the truggy yet to see if the battery will fit.)
Old 09-04-2015, 05:55 AM   #55
bwillenb's Avatar
I will be getting mine today and will measure it for you. From what I understand there is no "tray" in the 3.0 the battery us strapped to the chassis.
Old 09-04-2015, 02:11 PM   #56
Moderator
mxwrench's Avatar
The 8ight-T E 3.0 certainly does have a battery tray!
the inside dims are: 160mm length x 53.5mm width.
Brian Kinney
TLR Design Engineer
2016 Sponsors: Team Losi Racing, AKA Tires, Orion, Nitrotane, Horizon Hobbies, Fast RC Paint.
mxwrench is offline   Reply With Quote
Old 09-04-2015, 10:39 PM   #57
Thanks I appreciate it. My battery is 164mm. Sounds like it might fit. If not, a little dremel work should do the trick.
Old 09-08-2015, 07:51 PM   #58
Anyone got photos off there yet
coombes is offline   Reply With Quote
Old 09-09-2015, 08:48 AM   #59
bwillenb's Avatar
Finished building mine. Still working on body the painted.
Old 09-13-2015, 09:28 AM   #60
Very nice bwillenb. Cool skid plates.
