Like Tree3Likes
Old 07-14-2017, 12:58 PM   #286
dtr
dtr's Avatar
Has anyone tried the Proline enforcer nitro truggy body? How does it fit?
dtr is offline   Reply With Quote
Old 07-16-2017, 04:12 PM   #287
Hi All,
how many batt packs do you expect to go through before you have to start thinking about rebuilding the diffs?
I mainly run on a softish clay track.
thanks,
rbc626 is offline   Reply With Quote
Old 07-16-2017, 04:28 PM   #288
I rebuild every year
e-fanatic is offline   Reply With Quote
Old 07-16-2017, 08:05 PM   #289
how much use do you put into? (I suppose if electric in number of packs or if nitro how many tank full?)
Old 07-18-2017, 07:21 PM   #290
Originally Posted by waffleNchicken View Post
When its dry, try a set of Blue dot Reflex's by Jconcepts. They seem to work very well on our clay -like- surface when its dry.
When its wet, and muddy, youll need a larger more spaced pin, i would think. Like a PL blockade.
HI,
was able to try the pl Blockade and also the Cityblocks. both were good on the medium muddy conditions during the weekend.
thanks for the input
Old 07-27-2017, 05:17 PM   #291
First time i am rebuilding, what is standard/ neutral diff oil ( front centre and rear,) and shock oil(front and rear) should i use?
Old 08-03-2017, 11:13 AM   #292
Default Bodies that might fit my 8TE 1.0 ?
Hey guys, I dont know who else to ask. I bought a Losi 8T E 1.0 yo play with and now the body is trashed. Does anyone know where I can get a replacement body that will fit my 1.0 ?
calkurt is offline   Reply With Quote
Old 08-03-2017, 11:38 AM   #293
Last edited by e-fanatic; 08-03-2017 at 11:41 AM. Reason: Can't get images to post
Old 08-03-2017, 12:54 PM   #294
RCsHPI's Avatar
Originally Posted by e-fanatic View Post
Use imgur instead of Photobucket to upload and embed your pics. Or you can use the forum picture upload function.
▪ Losi 8ight-T E 3.0 ▪
RCsHPI is offline   Reply With Quote
Old 08-05-2017, 11:30 PM   #295
RCsHPI's Avatar
I know some racers use low kV / high voltage but can our diffs hold up to a high kV / high voltage setup? I can't find the post but someone said Horizon said no.
I'm wanting to run 6S / 2200kV but since the truggy was designed for racing and not bashing I'm not sure how it will hold up.
Edit: from horizon;
"Thank you for contacting Horizon Hobby.
It is only recommended that you run a 4S battery."
Old 08-10-2017, 03:22 PM   #296
take video and share us the result after your run with 6S
Old 08-10-2017, 04:39 PM   #297
I run 6s when I run on the oval track with the 1/5th scale trucks. It's the only way to keep up. The truck handles it just fine. I have the mmm with the 2200kv motor and a 13 tooth pinion
Old 08-16-2017, 12:25 PM   #298
RCsHPI's Avatar
I think they say no 6S with high kV to cover warranty issues dealing with diffs. Who knows but I upgraded anyway so we'll see how the diffs hold up.
Waiting for FedEx to deliver my 6S lipo from SMC. Hopefully I can run this by Saturday.
Old 08-16-2017, 12:37 PM   #299
Now that looks nice. What motor is that?
Old 08-16-2017, 12:47 PM   #300
RCsHPI's Avatar
Poseidon 1527.
Scroll to the bottom of their page;
Brushless Motor - Poseidon RC
