    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree12Likes
Old 04-09-2016, 02:13 PM   #1471
justpoet's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Cuebulon View Post
I did and it feels great. I checked to see if the drag brag got turned back on somehow as well and nothings there. I did however replace the motors bearings before putting it on the kit. Could that have anything to do with it? I put the motor back together exact opposite of how i took it apart so it should be fine there.
Yep, new bearings often have a little more resistance than well worn ones. At larger angles like full droop when on a stand, CVDs and dogbones can also have more resistance than when in their normal running positions. Most 8th scale motors do tend to have a bit of a drag effect though, even without drag break turned on.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Sanwa, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 04-09-2016, 02:25 PM   #1472
Cuebulon's Avatar
Very cool! I appreciate the help and will post more after i get to run it. Sadly no racing this weekend since the track is being reworked.
Cuebulon is offline   Reply With Quote
Old 04-10-2016, 04:50 PM   #1473
Originally Posted by ezlight View Post
Skip the AE drivers, get MIP below:
http://www.ebay.com/itm/MIP-9502-Met...cAAOSwyjBW6jsm
Skip the black and decker...You need actual metric...Like these.
http://www.amazon.com/Pack-Essential...+driver+metric
Something needed for the build, and helpful for the toolbox is a 4mm reamer for the arms.
http://www.ebay.com/itm/Hudy-4Mm-Rea...AAAOSw--1Ws6RY
As for the tekno shock tool, it's one of my favorite tools, period... SOO helpful.
http://fiercercsolutions.com/TKR1115...um-TKR1115.htm
That combined with this will make shock building easy.
http://fiercercsolutions.com/TKR1116...ol-TKR1116.htm
thanks guys i got some tekno k=ones along with the 4mm arm reamer, good call on that cause i missed it as the required tools on the box.
will start the build next week and keep everyone updated
caffeine357 is offline   Reply With Quote
Old 04-10-2016, 09:39 PM   #1474
Slapjack's Avatar
Trader Rating: 19 (100%+)
Good idea getting these tools ahead of time. It sucks getting to a spot where a tool is needed and having to wait 3 days for it to arrive. I am currently waiting on my arm reamer. Today I just picked up a mini electric driver and some mip speed tips. Best thing ever especially for screwing in those long screw for the hinge pin hangers.
Speaking of the hangers I just put my front arms on to test fit them while waiting on the reamer and is there supposed to be this big of a gap between the arm and hanger? The arm can slide back and forth like 1.5-2mm - see pic
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 04-11-2016, 06:11 AM   #1475
I've been wondering about this too, I know the gap is expected, its just part of the design, but should we be shimming it out?
TEKNO SCT410.3; Hobbywing Sct-pro; Hobbywing 3656 4000kv; Protek 130S; SPC 70C 7200mAh 2s
TEKNO EB48.3; Hobbywing Xerun 150a; SMC 1900kv; Savox 2274SG; ECO Power 35c 4100mAh 4s
Associated B5R; Trackstar 120a turbo; Trackstar 8.5t; Solar D771; Reedy 65C 5800mAh 2s square
kyleman7 is offline   Reply With Quote
Old 04-11-2016, 02:24 PM   #1476
edonsohc's Avatar
i'm curious on the gap too. i shimmed mine to take up the slack. don't know if it's right to do that or not though.
Tekno sct410.3, tekin gen2 rx8, hobbywing 4700kv motor, savox 1258.
Tekno EB48.3sl, 4000kv hobbywing on 3s.
Losi scb, mmp, bhr 10.5 motor.
Ofna H4E, vta, usgt, & 17.5 tc
Spratt's Hobby Center, Hillsdale Michigan.
edonsohc is offline   Reply With Quote
Old 04-11-2016, 05:12 PM   #1477
Slapjack's Avatar
Someone will hopefully chime in... Although I am thinking it is supposed to be left alone so the arm has room to move and doesn't get bound up.
I am also wondering about the hinge pins again. I got my reamer today and I reamed so that when I drop the pin thru it falls thru flush to other end. When I hold the pin and move the arm it has very very slight friction still but very free moving. I read the pin is supposed to fall all the way thru. But I thought maybe I shouldn't go that far with it cause dirt might get in easier? Should I leave it how it is or keep going til the pin can fall thru all the way out the other end?
Old 04-11-2016, 07:58 PM   #1478
justpoet's Avatar
The gap is intentional. It only happens with the more angled hinge pin settings, and this can happen because of the huge amount of adjustability Tekno offers. If it didn't have the gap when at more of an angle, then it would bind up when straight center to center. It is safe to take some of the play out with a small shim so long as you still have SOME movement so as to not bind up even under flex and the full suspension compression movement.
Old 04-11-2016, 10:16 PM   #1479
im about to start my build of th eb48.3 and im unclear if i need to buy any of the nut drivers because they are listed as 1.2 11.32 etc instead of mm as they show on the tekno box.
these are the tools I have so im asking for input if i need to buy additional nut drivers.
http://www.amazon.com/Team-Associate...ef_=sr_ph&sr=1
http://www.amazon.com/Black-Decker-7..._7&s=hi&sr=1-7
second part of that is if i buy the tekno nut drivers should i just get one handle and the bits seperately? it doesnt look like theres a set. Im laos guessing i need the wheel and shock wrench no matter what in addition to the tekno shock tool.
thanks in advance guys!
I have mip and hudy hex bits (2 each of 1.5mm, 2.0mm, 2.5mm and 3mm), two 1/4" small handles from Lowe's, kobalt socket ends, those 1/4" shank things for using sockets with driver and a small 1/4" electric driver. I probably don't need two 1.5mm and two 3.0mm because I never use the 1.5mm in the drill and I rarely use 3.0mm hex. It works for me because everything is quick-change and interchangeable. I can use drill to do most the work and the use handles for final tightening. To me, a quality electric driver is a must. Wrenching on new plastic by hand is a pain and slow.
qstorm777 is offline   Reply With Quote
Old 04-12-2016, 12:51 AM   #1480
Carter Flotron's Avatar
Definitely want your hinge pins to fall all the way through your arms in every situation, it prevents the suspension from doing its job correctly if there is binding or friction.
Something the team has been doing is a simple mod to the suspension arms. The mod is to cut out the area around the hingepin but leave about 12mm on both ends to create H-shaped arms. This allows the arms to pivot far more freely under stress and flex while getting rid of an area that could load up with dirt. Arm strength is reduced but no one I know has had durability issues running their arms like this with the buggies.
Thanks to all my sponsors for 2016!
|Pro-line Racing|Hobbywing North America|Highest Servos|Fierce RC Solutions|
Carter Flotron is offline   Reply With Quote
Old 04-12-2016, 01:41 AM   #1481
werner sline's Avatar
if you run in dusty conditions like I do, you should often take you suspension apart and clean the hingepins : dust tend to pack and become hard.
I even use a round 4mm round file to rub the Inside of the arm. then I blow the dust out.
On every buggy I drill the arms with a 4.2mm drillbit.
werner's bunch of RC freestyle: werner's new video : hobao hyper MT trailer 2 : HIGHER!
https://youtu.be/CLPFyAtPCY0
werner sline is offline   Reply With Quote
Old 04-13-2016, 06:36 AM   #1482
Slapjack's Avatar
I am very annoyed by this and just wanted to see if anyone else had any issues with these. I got the TiNi coated shock shafts and delrin inserts and assembled my front shocks last night. The one shock has this rough feeling when the shaft is all the way extended then you start to compress it. I took everything apart twice and cleaned everything. I couldn't see any issues with the inserts, O-rings or piston. So it has to be an imperfection in the shaft itself right? I emailed amain for a replacement but I am sure they are going to want me to send back the one I have first which means I will be waiting another week before I can continue.
Also, I had a question about the manual. Manual says to use 400cst in the front shocks and 450cst in the rear. Isn't it more typical to use lighter oil in the rear than in the front?
Old 04-13-2016, 07:19 AM   #1483
It has to do with the length of the shocks and the pistons that are used. This is the only buggy with truggy length shocks so it is different from a standard buggy setup. It works though!
MX304 is offline   Reply With Quote
Old 04-13-2016, 08:36 AM   #1484
vwduud's Avatar
Trader Rating: 48 (100%+)
Also, shock mounting position. With the front shock mounted out further on the arm, it will gain in shock shaft speed, allowing it to pack up quicker with lower viscosity oil.
Jim Brown
Agama A215E, Rx8 G3, 1900kv, Savox 2273, SMC, 4PX
Sponsors: Agama, RC Crew Chief (chassis tuning S/W)
President of SCR (just outside New Orleans) - https://www.facebook.com/scr.raceway
vwduud is offline   Reply With Quote
Old 04-13-2016, 09:11 AM   #1485
Slapjack's Avatar
Ok, about the shocks. I just talked to Amain about the problem I am having with the TiNi shaft on the front. I bought TKR6017T for the front and TKR6061T for the rear. Amain is saying I need part number TKR6004T for the front and TKR6017T for the rear. But I think that would be the parts you use on the 48.2. I ordered the front and rear per the manual option callout. Am I wrong or what? TKR6017T says rear shaft and TKR6061T says X-Long rear shaft. But I am pretty sure that is what I need. Anyone have a contact at Tekno I can ask to be 100% sure?
