    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 – Yellow Low Frequency Rear Springs and TKR8762 – Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 – Orange Low Frequency Rear Springs and TKR8763 – Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B – HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 – Hinge Pins (inner, front/rear)
TKR6061T – Rear Shock Shafts w/ TiNi Coating and TKR6017T – Front Shock Shafts w/ TiNi Coating
TKR5286 – Front Suspension Arms and TKR5184 – Rear Suspension Arms
TKR5194 – Spindle Carriers
TKR6009 – Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree12Likes
Old 03-20-2016, 11:59 AM   #1351
mkl
Originally Posted by shein95 View Post
I bent on in my first race with it and I've just found one on the front. I'm really not liking this trend. This car has only been raced 4 times. I ran a whole season with my sworkz and only bent one on that car during a fast head on when another buggy crossed the pipe onto the straight. I just don't understand how a car of this quality has this issue. Are they just too long for a buggy?
I'm still running my original shafts on my SCT since the day it was released and he same on my EB that I got shortly after. Crash a lot and no issues on either.
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 03-21-2016, 10:47 AM   #1352
I think ill pay the extra money for the 6500s then. thanks guys.
caffeine357 is offline   Reply With Quote
Old 03-21-2016, 10:49 AM   #1353
I know that tekin is the best but id like to hear from you guys that run trackstar and smc and get your take on why you didnt justify the extra 150 for tekin because thats what im battling with right now.
I know people have said the tekin cs is great and thats one thing i take into consideration. have you guys had motors ever fail and then just trade them in? id imagine this is out of the question for trackstar. which might justify the extra money
Old 03-21-2016, 11:15 AM   #1354
jmcelroy42's Avatar
There is at least 3 of the SMC 1900 motors in Tekno buggys at my track, one of them is my old eb48.2 and I liked it a lot.
EB48.4 - TEKIN RX8 & SMC 2100
EB410 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 03-21-2016, 11:40 AM   #1355
can the SMC motors be run with a trackstar speed controller or do they have to go with SMC speed controllers?
Old 03-21-2016, 01:25 PM   #1356
edonsohc's Avatar
i run the smc 1900 w/ the trackstar 150 amp esc. no issues. great running motor and esc.
Tekno sct410.3, tekin gen2 rx8, hobbywing 4700kv motor, savox 1258.
Tekno EB48.3sl, 4000kv hobbywing on 3s.
Losi scb, mmp, bhr 10.5 motor.
Ofna H4E, vta, usgt, & 17.5 tc
Spratt's Hobby Center, Hillsdale Michigan.
edonsohc is offline   Reply With Quote
Old 03-22-2016, 10:57 AM   #1357
I run the SMC 1900kv with Gen 2 RX8..No issues.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 03-22-2016, 11:22 AM   #1358
any reason you dont run the SMC with their SMC speed controller? I have trackstar stuff already with a program box so im leaning doing the same as you, im just curious.
Old 03-22-2016, 11:32 AM   #1359
jmcelroy42's Avatar
The SMC Speed control is meant for 1/10
Old 03-22-2016, 02:15 PM   #1360
ah ok got it. Yea ill go with the trackstar ESC then
Old 03-22-2016, 02:16 PM   #1361
can you guys recommend your favorite medium tire that wears the least for practice? ill use good ties on the days i am practicing right before the race but for non race day practices i want to use something that will wear the least
Old 03-22-2016, 02:54 PM   #1362
werner sline's Avatar
just a little detail about trackstars ESC : they only deliver 6v to the radio and the servo
the tekin rx8 can deliver 6v or 7.4v to the radio+servo
I depends if you have a radio that can take 7.4v but most modern servo will work much better on 7.4v
check this detail out
tekno says the eb48.3 requires a strong servo ( don't remember how much torque they say , check out the manual )
werner's bunch of RC freestyle: werner's new video : hobao hyper MT trailer 2 : HIGHER!
https://youtu.be/CLPFyAtPCY0
werner sline is offline   Reply With Quote
Old 03-22-2016, 07:37 PM   #1363
justpoet's Avatar
Trader Rating: 16 (100%+)
Generally, there are two ways you can go about a longer wearing tire. Since an AKA Impact is a common tire to find being run in a lot of places, I'll use that as the example. Let's say a Soft AKA Impact is the tire of choice, but they only last a race day and some practice laps. There are 2 ways to go about getting longer life. One way is to just go with a harder compound, such as the Medium or the newer extended life compounds (which are a mix of 2 compounds, such as soft and medium). This gives you similar handling, but with just less traction all around. On MOST track surfaces, this will give you a lot longer life span, but on some abrasive surfaces, you'll actually get less due to having more wheel spin and slide.
The second way is to put more rubber on the tire, so that would be to go from an Impact to an Enduro, where the lugs are all larger. This will generally make the car more stable, but have less forward bite. The effect is a longer lasting tire, but without quite the same loss of traction as a harder compound would've had. It probably won't last quite as long as the harder tire compound though.
If you're running eBuggy though, and just want to last longer, look at what the nitro guys run for their 45 minute or hour long mains. That tire choice is probably what you want for practice.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Sanwa, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 03-22-2016, 07:42 PM   #1364
justpoet's Avatar
I've run both the Tekin and SMC motors. The SMC has a little more grunt down low and the Tekin is a little smoother in the middle. Both have about the same top end and are quality motors that you'll be happy with. The SMC runs slightly warmer for some folks.
As for ESCs, I always keep going back to the Tekin RX8 (now the Gen2) after trying others for one reason or another. That being said, SMC should be having an 8th scale ESC out soon™ as well (as mentioned above, they don't yet have an 8th scale ESC). I've been testing it and like it a lot, but it has a couple things being worked on in the firmware to handle random issues in random motors before it is ready for release.
Old 03-23-2016, 05:10 AM   #1365
jmcelroy42's Avatar
That's awesome news, I'm in need of an esc for my ET48 for this summer, I will be looking forward to seeing this!!
