    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree12Likes
Old 11-22-2015, 08:24 AM   #736
suzukipro's Avatar
Trader Rating: 23 (100%+)
Originally Posted by rcnut87 View Post
I bought the new .3 hinge pin holders as well as the .3 upgrade kit from fierce rc last week. I went to start installing and when i pit the front together i noticed alot of front to back slop in the arms. Seems like the hing pin holders are not getting tight enough on the arm. Looks like i may have to shim these. Has anyone else had this issue upgrading there .2 to a .3?
I noticed there was slightly more play as well compared to the .2 when I did the upgrade. I didn't bother with adding shims and you should be fine without them.
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 11-22-2015, 09:07 AM   #737
rcnut87's Avatar
Originally Posted by RokleM View Post
There should be a small amount of forward/backwards play, but not excessive. New arms or old? Are they worn, specifically the bump out that would be near the insert?
Arms are brand new. I would say the slop is excessive. Kind of hard to see but heres a picture.
Tekno EB48.4 - Tekin RX8 gen 2 SMC 1900KV
Tekno SCT 410 - Tekin RX8 gen 2 SMC 4500 4 pole
Tekno EB410 (coming soon....hopefully) - tekin RSX TBD motor.
Losi 22sct 3.0 - Tekin RS gen 2 team scream 17.5, tuned by Rotor Ron
rcnut87 is offline   Reply With Quote
Old 11-22-2015, 11:26 AM   #738
rcnut87's Avatar
I will build without shims. Ill have to compare it to yours next weekend see if im just being to picky.
Old 11-22-2015, 02:31 PM   #739
Default Motor runs in reverse
Hey just got this thing all hooked up and motor runs in reverse, can change on remote but sensitivity is scary, please help asap thanks!!!
JOELD is offline   Reply With Quote
Old 11-22-2015, 02:45 PM   #740
rcgod's Avatar
Trader Rating: 27 (100%+)
Change motor direction on esc or reverse the diffs
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 11-22-2015, 02:50 PM   #741
How on tekin rx8 gen2 can't find in manual
Old 11-22-2015, 02:58 PM   #742
Got it thanks bud
Old 11-22-2015, 05:13 PM   #743
+1
Upgraded my 48.2 and your picture looks the same as my buggy.
jjl1 is offline   Reply With Quote
Old 11-22-2015, 08:22 PM   #744
justpoet's Avatar
Trader Rating: 16 (100%+)
Count me as another fan of SMC batteries. I normally charge my 6500 4s pack and my 7200 2s packs at 9 amps. I like to keep under 1.5c just to be nice to the packs, and as a result usually get more than 500 cycles out of them (though they're definitely starting to fade a bit prior, but no where near as much as many other brands). I've occasionally charged up at 20 amps though when late for a race. The only thing I had an issue with was a cheap charging lead that got too warm. If you want to charge fast, make good cables and connections.
For the Savox Servos, the older ones ARE power hungry. They made a conscious effort with the 227x series though to be much more efficient with those newer brushless models. I've run the 2274 in a few vehicles now (1 servo, it has been a backup and moved around) off of an RX8 Gen2 running HV and never had a glitch or brownout, despite using Spektrum gear.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Sanwa, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 11-23-2015, 12:25 PM   #745
Ruffdog1's Avatar
Is the Tekin 1900 KV motor enough for the EB48.3 or should I get the 2050?
Ruffdog1 is offline   Reply With Quote
Old 11-23-2015, 12:45 PM   #746
mkl
1900KV is plenty for the 48.3. I think most run one. I think it has very useable power. It is not over the top so the control is better. I think the power band is a bit smoother. I even use a Tekin 1900 buggy motor in my ET48 and it is plenty fast.
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 11-23-2015, 02:12 PM   #747
Anyone try going thicker then 5k in the rear to get it to loosen up a little?. The rear of mine is so planted running 775. I think maybe 7 in the rear will help it come around a little. Is it taboo to go over 5?
Dragonfueled is offline   Reply With Quote
Old 11-23-2015, 02:39 PM   #748
wrightcs77's Avatar
Trader Rating: 523 (100%+)
What set up otherwise. After Channing link positions and kick up, the rear rotates much better.
wrightcs77 is offline   Reply With Quote
Old 11-23-2015, 02:53 PM   #749
Front short camber link middle hole on tower inner on hub. Rear short link lower on tower second from inside on hub. No front sway. Front shocks inner most hole on tower rear outer most. Added 1 degree of kickup and least amount of rear toe
Old 11-23-2015, 03:37 PM   #750
Ruffdog1's Avatar
Is the shock oil that comes with the 48.3 manual cst or wt? Manual says 400wt front 450wt rear. Thanks
