    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree12Likes
Old 11-14-2015, 10:41 AM   #676
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Fasttrak View Post
Before you completely disassemble the unit, disconnect the two outboard steering turnbuckles and see that each hub and the steering rack can make a complete sweep left to right. This might show you where the trouble is located and help you solve your problem.
Did you try this yet? Just want to be sure it's the spindle hitting the carrier and nothing else
Originally Posted by jjl1 View Post
I had problems uploading the picture of the other side. Here it is.
There's nothing obvious in the picture that I can see. Can you tell me your other settings? Specifically- ackermann plate, front kick-up, arm sweep, and bumpsteer? Thanks!
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 11-14-2015, 05:27 PM   #677
Yes Matthew, I did check that the spindles and steering rack make complete and smooth sweep. I have set the car up with the Ryan Lutz's Barnstormers setup.
http://lutzinator.com/wp-content/plu...5%20EB48.3.png
jjl1 is offline   Reply With Quote
Old 11-14-2015, 05:31 PM   #678
Whoops wrong sheet
http://lutzinator.com/wp-content/plu...%207-26-15.png
Old 11-14-2015, 06:14 PM   #679
Trader Rating: 40 (98%+)
Any thoughts on the full option shock kit? I have a .1 and was thinking about upgrading them. Just trying to see if it's worth yet.
Team associated sc5m
Team associated t5m
Hobby wing
Trinity
Futaba 4px
wheres_yogi is offline   Reply With Quote
Old 11-14-2015, 08:52 PM   #680
Hey guys i have a question I just built my new eb48.3 and i noticed that the center diff is rubbing the motor mount. It looks like it is one of the screw heads but they are all the way down. I am asking only to see if there is anyone else that has had this problem. I fixed the problem by having to dremel down the motor mount just a little!
bigco66 is offline   Reply With Quote
Old 11-15-2015, 09:54 AM   #681
RokleM's Avatar
Trader Rating: 33 (100%+)
Many things have changed since the original. Just replacing the .1 shocks with the .3 would cause quite a few issues as the rest of the suspension geometry wouldn't be updated. New towers, new arms, etc.
Basically, the original and .2 vehicles were great, but the .3 takes it to a whole new level. It's really up to you to personally decide if it's logical to keep the .1 as is, sell it and get a .3, upgrade to .3, or change just some of the components. Personally I would lead towards selling the .1 and buying a fresh .3, but that's just me.
- Eric G. -
Tekno EB48.4, NB48.4, ET48.3, NT48.3, EB410
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 11-15-2015, 10:33 AM   #682
I just got done with mine too. The same thing is happening to me.
EricM is offline   Reply With Quote
Old 11-16-2015, 11:54 AM   #683
justpoet's Avatar
Trader Rating: 16 (100%+)
Make sure the screws are REALLY all the way down. If you just snug them up then the paper gasket doesn't compress and the diff is fractionally bigger. I've seen this happen several times. You can also end up with the gear rubbing as you mentioned, or rubbing the top of the diff holder in just 1 spot as it spins. This is usually attributed to one of the screws not being as tight as the others.
Lastly, to make sure this can't happen, add a small shim into the motor mount side of the diff so it makes sure if there is any play that the diff is further back instead of forward. If you didn't need all of the shims from the front/rear diffs when placing them, one of those works perfectly.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Sanwa, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 11-16-2015, 11:57 AM   #684
justpoet's Avatar
Coming from the original, without options, the full option shock kits are a great upgrade that will enhance the life of everything in the shock while also making a smoother shock. Just make sure you get the length of shock you intend to, as it is different from the EB48 and EB48.2 on the EB48.3, since the EB48.3 matches the longer truggy length shocks. If you intend to get the parts to upgrade to the EB48.3 suspension geometry (arms, hubs, shock towers, shocks), then you will be happy with both the new shocks and the new suspension geometry.
Old 11-17-2015, 07:34 AM   #685
MOE
MOE's Avatar
Trader Rating: 14 (100%+)
Has anybody swapped to the universals? If so what are your thoughts.
Tekno EB48.3/ET48.3 Tekin gen2 RX8/1900 kv KO PROPO EURUS
Sponsored by
Tekno Rc
Dialed-Rc Hobbies
Advantage Racing Products
MOE is offline   Reply With Quote
Old 11-17-2015, 10:17 AM   #686
I put the Kyosho universals in a few weeks ago figuring they'd help on our local, usually bumpy, track. I'm no expert driver, but I did like the feel. I can't describe it well, but it felt smoother. But even if they performed the same, I like the idea of lower maintenance.
Tampagoalie is offline   Reply With Quote
Old 11-17-2015, 10:28 AM   #687
RokleM's Avatar
I made a number of minor changes at the same time I added the universals. Driven the best it has so far. From design and maintenance wise, it was a no-brainer for me.
- Eric G. -
Old 11-17-2015, 11:11 AM   #688
MOE
MOE's Avatar
Ok thanks. That's basically what I figured. Thanks fellas.
Sponsored by
Tekno Rc
Dialed-Rc Hobbies
Old 11-17-2015, 11:52 AM   #689
Super Moderator
Trader Rating: 17 (100%+)
typically universals give more side bite and sometimes less forward. I don't know if that's the case here as I haven't tried it, but that's what I've found in every other car.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 11-17-2015, 06:44 PM   #690
Slapjack's Avatar
Trader Rating: 19 (100%+)
I don't know if there is a eb48.2 specific thread but I couldn't find it. Can anyone give me the link to the 48.3 upgrade kit for the 48.2? I found it before but can't remember where. ThAnks
I was also wondering if the 48.3 parts will fit the 48.2 individually? Like if I were to do one mod at a time. For example could I install the .3 arms then the .3 towers and shocks or are there certain things that need to be replaced together in order for them to work/fit?
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
