    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree12Likes
Old 11-08-2015, 01:18 PM   #616
Originally Posted by EricM View Post
I just got done building my buggy last night. It went surprisingly fast. It was a nice build. I have to pick wheels and tires now. I'm going with the tekin motor and esc combo. What size pinion gear would be good?
what KV motor?
Thanks for the info guys!!
JOELD is offline   Reply With Quote
Old 11-08-2015, 02:02 PM   #617
The 1900kv motor
EricM is offline   Reply With Quote
Old 11-08-2015, 02:50 PM   #618
Is it just me or have tekno parts gone up in price quite a bit?
turtle189 is offline   Reply With Quote
Old 11-08-2015, 03:04 PM   #619
The 1900kv motor
what made you pick that over 2200?
Old 11-08-2015, 03:55 PM   #620
R1Joel's Avatar
2200 is way over powered for buggy imo.
R1Joel is offline   Reply With Quote
Old 11-08-2015, 04:49 PM   #621
1900 kv is about the best you could ask for. I usually stick with a 20 tooth
Dont Hack Me is offline   Reply With Quote
Old 11-08-2015, 06:48 PM   #622
werner sline's Avatar
so people, what did you break on your EB48 so far ?
werner sline is offline   Reply With Quote
Old 11-08-2015, 08:21 PM   #623
my bank account
Old 11-09-2015, 06:27 AM   #624
RokleM's Avatar
Trader Rating: 33 (100%+)
Originally Posted by justpoet View Post
My only comment on this that is seriously important is to avoid the Castle ESCs. ...
Agreed, also add the Reds motors to the list. Incredibly powerful, reliable, and come off cool.
Not that I've seen.
Land speed records
Originally Posted by JOELD View Post
my bank account
- Eric G. -
Tekno EB48.4, NB48.4, ET48.3, NT48.3, EB410
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 11-09-2015, 08:15 AM   #625
Only things that went south on mine were a few bearings and a shock shaft bent.
You guys have me wanting to try a Tekin esc. All I run is castle esc's lol
Dragonfueled is offline   Reply With Quote
Old 11-09-2015, 08:21 AM   #626
What temp is your motor after the run? I'm running a SMC 1900 kv and HW XR8 (4 degrees of timing) with a 17 tooth pinion and it gets a little warm. Motor comes off track around 170 after a 12 minute run. I feel like a 20 tooth would cook the motor. You're not too hot?
Thanks.
Tampagoalie is offline   Reply With Quote
Old 11-09-2015, 08:30 AM   #627
RokleM's Avatar
Seriously though, there are some common wear/tear parts that you can stock once you get a feel for the vehicle. Hinge pin, hinge pin inserts, shock boots are the most common things I replace, but not too often.
- Eric G. -
Old 11-09-2015, 01:01 PM   #628
vwduud's Avatar
Trader Rating: 48 (100%+)
Same here. Wears extremely well. Have never DNF'd due to parts breakage in over 2 years running Tekno (EB, NB and ET). Built like tanks.
Jim Brown
Agama A215E, Rx8 G3, 1900kv, Savox 2273, SMC, 4PX
Sponsors: Agama, RC Crew Chief (chassis tuning S/W)
President of SCR (just outside New Orleans) - https://www.facebook.com/scr.raceway
vwduud is offline   Reply With Quote
Old 11-09-2015, 02:15 PM   #629
8ight-e's Avatar
Trader Rating: 58 (100%+)
With the .2 buggy for two years I replaced shock boots two rear braces and a chassis. My guess is the chassis wearing lead to the slightly weaker rear end and the two rear braces breaking. The m2c chassis is a nice upgrade though. Ohh and several sets of bearings. i'm not sure how well the new .3 arms and parts are holding up yet.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 11-09-2015, 04:02 PM   #630
What do you guys recommend for a steering servo?
